Noah Nordrum
Offline
« on: November 06, 2011, 07:49 PM » |
It's not portable by being on the vac, but made a boom arm for ~$6 with 1.5" pvc pipe and two 45 degree brackets.  I had to lift the vac up onto a table to get enough hose to be able to domino on the far side of the table, but you can't really complain too much about the minor shortcomings up a $6 boom arm  It's "attached" to the back leg of the table using zip ties.
MFT/3, CT26, TS55, OF1400, CXS, RO 90, RO 150, LR-32, Domino
greenMonster
Offline
« Reply #1 on: November 06, 2011, 07:54 PM » |
nice
Always wondered, isn't the pvc really floppy? Also, it seems that just putting a couple hooks in the ceiling would work as well?
erock
Offline
Waiting for a new Centrotec installers set.
« Reply #2 on: November 06, 2011, 08:13 PM » |
Nice job. I made a boom arm with 1 1/2" pvc. Worked good for me also. I see that you have a Dremel multi-max. How do you like it? I had one. It last about 2 months on the job sites and the motor burned up on me.
Eric
Kapex, Domino, HL 850, OF1400, MFK700, TS 55, PS 300, CXS, C15, MFT 800, MFT1080, MFT/3, CT 26, CT midi, DX93E, DX93 , DTS 400, RO 125, ETS 125, LR32 set, parallel guide, FS 3000/2, (2) FS 1400/2, FS 800/2, Syslite, tape measure, multi toolie, utility knife, safety glasses, stein, folding rule, head lamp, XL fleece, XL sweater,(2) XL t-shirt, XL long sleeve shirt, XL training shirt, XL polo shirt, beanie, hat, FOG cap, banner, anti fatigue floor mat. I got a blog, check it out! http://dustfreewoodworking.blogspot.com/
Noah Nordrum
Offline
« Reply #3 on: November 06, 2011, 08:20 PM » |
1.5" PVC was the point where it became rigid enough to use. I might do the ceiling hook route when I move back into the shop area. I'm currently in a temporary area while I put up a wall in the shop. I see that you have a Dremel multi-max. How do you like it? I had one. It last about 2 months on the job sites and the motor burned up on me.
I think if I used a multi-max at work I'd get fired (I work in IT though, so construction work at your is frowned upon  ). It's okay. I thought it had a much higher learning curve than I expected. Much more of a finesse tool. I used it to cut the PVC pipe and I used it upstairs to cut away some hardwood flooring to bring it back to even with the door (was under some carpet initially). Seems to work okay if you're patient as it works slower than I keep expecting it to.
