Pages: [1]   Go Down
  Print
Author Topic: Homemade Boom Arm  (Read 2894 times)
Noah Nordrum
Offline Offline
« on: November 06, 2011, 07:49 PM »
It's not portable by being on the vac, but made a boom arm for ~$6 with 1.5" pvc pipe and two 45 degree brackets.
I had to lift the vac up onto a table to get enough hose to be able to domino on the far side of the table, but you can't really complain too much about the minor shortcomings up a $6 boom arm Tongue Out
It's "attached" to the back leg of the table using zip ties.
MFT/3, CT26, TS55, OF1400, CXS, RO 90, RO 150, LR-32, Domino
greenMonster
Offline Offline
« Reply #1 on: November 06, 2011, 07:54 PM »
nice
Always wondered, isn't the pvc really floppy?
Also, it seems that just putting a couple hooks in the ceiling would work as well?
erock
Online Online
WWW
« Reply #2 on: November 06, 2011, 08:13 PM »
Nice job.  I made a boom arm with 1 1/2" pvc.  Worked good for me also.  I see that you have a Dremel multi-max.   How do you like it?  I had one.  It last about 2 months on the job sites and the motor burned up on me.
Eric
Kapex, Domino DF 500 Q set, Domino systainer,  HL 850 E plus with bench unit, OF1400, TS 55,  Trion PS 300, CXS set,  MFT 800, MFT1080,  MFT/3, CT 26, CT midi, DX93E, DX93 abrasive systainer,  DTS 400, DTS 400 abrasive systainer, Rotex 125,  ETS 125,  (2) ETS 125 abrasive systainer,  LR32 system, parallel guide extension kit, mini sys.,  multiple sys. 1-4,  sys toolbox, FS 3000/2,  (2) FS 1400/2,  FS 800/2, lots of clamps, tape measure, multi toolie, utility knife, safety glasses,  stein, folding rule, head lamp,  XL fleece, XL sweater,(2) XL t-shirt, XL long sleeve shirt, XL training shirt, XL polo shirt, beanie, hat, FOG cap,  banner, anti fatigue floor mat.
I got a blog, check it out!     http://dustfreewoodworking.blogspot.com/
Noah Nordrum
Offline Offline
« Reply #3 on: November 06, 2011, 08:20 PM »
1.5" PVC was the point where it became rigid enough to use. I might do the ceiling hook route when I move back into the shop area. I'm currently in a temporary area while I put up a wall in the shop.
I think if I used a multi-max at work I'd get fired (I work in IT though, so construction work at your is frowned upon Tongue Out). It's okay. I thought it had a much higher learning curve than I expected. Much more of a finesse tool. I used it to cut the PVC pipe and I used it upstairs to cut away some hardwood flooring to bring it back to even with the door (was under some carpet initially). Seems to work okay if you're patient as it works slower than I keep expecting it to.
Pages: [1]   Go Up
  Print
Jump to:
