Pages: [1]   Go Down
  Print
Author Topic: Making your own LR32 guide rail  (Read 6950 times)
Eiji Fuller
Retailer
Offline Offline
« on: April 05, 2008, 11:09 PM »
Has anyone thought about making your own holes in a longer guide rail by using the LR32 and router set up with the 1080 rail?
Just a thought, since I have a few rails kickin around and would love the longer rail with holes. I am just not in love with the price to get one at the moment. It seems as though the right bit would make quick work of this.
Eiji
Dovetail65
Offline Offline
« Reply #1 on: April 05, 2008, 11:15 PM »
I have thought about it. Even set up my drill press with stops But I haven't done it yet. I haven't determined which bit to go with. My drill bits are pretty bad. It is simpler for me not to use a router because my drill press is set up for repetive cuts like this already and would make really quick work of it. I have an incra fence on the press so the precision will be dead on.
I will search the forums and a few other places.
Nickao.
Scott W.
Offline Offline
« Reply #2 on: April 05, 2008, 11:32 PM »
Great minds think alike!
I was just noodling over this very thing earlier today. I have a rail with the holes, why couldn't I use it to put holes in my other rails.
Let me know if you figure out a good way to do it.
Scott W.
PA, USA
James Metcalf
Online Online
Memphis Tn.
« Reply #3 on: April 05, 2008, 11:35 PM »
One item to note is that the holes in the LR32 are not round. They are oval in shape.  I could have used a longer rail today.
Les Spencer
Offline Offline
« Reply #4 on: April 05, 2008, 11:40 PM »
This has been discussed before. The consensus, if I remember correctly, was that the holes in the LR 32 rail are not round but oval. This makes using the locating pin impossible without alterations. I purchased a second 1080 LR 32 rail and used the longitudinal stops, 485760, butted end to end in each of the 2 rails to locate them for the correct spacing, then used the rail connectors to lock them together. I was able to drill a row of holes over 6.5' long. It would be handy to have an extra set of the stops, $10.70.
Can't remember who originally posted this solution but it works quite well and is much cheaper if you already have one of the 1080 LR 32 rails.
Les (near Indy) XL
poto
Offline Offline
« Reply #5 on: April 05, 2008, 11:54 PM »
Not having seen the LR 32, this may be way out of line ... but ... if the holes are oval, what if you set up your drill press like Nick, and drilled one set of holes going one way (to get round holes), and then offset the holes very slightly going back - drilling slightly off the center of the already-drilled holes - to get almost oval holes. Bascially drilling each opening twice, with the second hole offset, and each hole equally spaced away from the "true" hole center (the center of the oval). Would that serve the purpose of the oval holes of the LR 32 drilling jig?
Qwas
Retailer
Offline Offline
WWW
« Reply #6 on: April 06, 2008, 12:46 AM »
To get oval holes, why not tilt the rail by 30-45 degrees?
Steve Adams  QwasProducts.com
Dovetail65
Offline Offline
« Reply #7 on: April 06, 2008, 01:00 AM »
Exactly poto, a stop on the left and a stop on the right of the fence. Push to the left drill, push to the right drill. Then reposition and repeat. It should work fine.
Nick
« Last Edit: April 06, 2008, 01:01 AM by nickao » Logged
Eiji Fuller
Retailer
Offline Offline
« Reply #8 on: April 06, 2008, 01:08 AM »
Poto,
I was thinking the same thing. This could be accomplished by moving the rail out 1 mm or so and re-routing. I think the router operation would work better than a drillpress operation due to the speed of the cutter.
James,
If you take a closer look at your rail you will notice that the holes are not oval but oblong. The pin in the LR32 plate is round. The oblong holes make it easier for the pin to locate the hole, since the holes only have to be accurate on the longetudinal axis of movement. The other axis is controled by the plate riding on the rib of the guide rail.
Eiji
Eiji Fuller
Retailer
Offline Offline
« Reply #9 on: April 06, 2008, 01:20 AM »
I will give this idea a try sometime this coming week. Wish me luck. Hey, the worst thing that could happen is that the test rail ends up a  little lighter. Grin
Eiji
Dovetail65
Offline Offline
« Reply #10 on: April 06, 2008, 01:22 AM »
Guys that metal is a breeze to cut with a drill press. When I get to mine I will post pictures. It should only take 20-30 minutes using a drill press max. The speed of the router may be faster, but on that guide it is not going to make a difference at all.
Nickao
poto
Offline Offline
« Reply #11 on: April 06, 2008, 01:37 AM »
Eiji
And holy. Or holey. Or something... Wink
Dovetail65
Offline Offline
« Reply #12 on: April 06, 2008, 01:50 AM »
It will come out great I am sure of it, you  have it all worked out.
Nick
Mirko
Offline Offline
« Reply #13 on: April 06, 2008, 01:38 PM »
Hey guys,
The best way IMO to drill these holes would be to use a indexing pin, for example:
set a pin 32 mm on center away from the drill bit on your press, then butt your rail to the pin, drill the guide,
now drop the hole you just drilled on to the pin, drill again. Once all the holes are drilled you can now move your back stop in or out to re drill the holes giving them the required "oval".
Mirko
Ned
Offline Offline
« Reply #14 on: April 06, 2008, 01:43 PM »
Compound error.
Just buy the rail.
Ned
poto
Offline Offline
« Reply #15 on: April 06, 2008, 04:03 PM »
I was thinking of the same approach, Mirko. However, if you wanted to do it with a router you could make a template out of mdf or something. Drill an oval to fit the guide bushing or copying ring of the router so that with the bit it makes the correct sized oblong in the rail. Put a piece of mdf along the underside of the template that would ride in the groove of the rail, and a pin that would register in the previously cut hole (taking into account the eccentricity of the hole). Then it should be zippiddy-do, and presto you have an LR32  Smiley
Michael Kellough
Offline Offline
Southern New York
« Reply #16 on: April 06, 2008, 04:13 PM »
Totally agree Mirko. I get exact measurement with the incra fence though so no added error.. One may not have the cash for the guide with the holes I think that is why we are talking about this.
Nickao
Is Incra metric? I think(?) the notches are 1/32". Close enough for a couple of holes but for a long series of holes adjustments will need to be made.  For an LR 32 the holes spacing is supposed to be 32mm even, as in 32, 64, 96...
But, who says you can't make an LR 1 3/16" if you want to?
Corwin
Offline Offline
« Reply #17 on: April 06, 2008, 07:03 PM »
Nickao
As a US company, Incra products use Imperial scales.  However, Incra does make some products with metric scales and also offers conversion sets that include 1mm racks and metric scales that will convert their 1/32" rack based products to metric.  Shortly I will post a review of these Incra tracks and show how easily these products can work in either Imperial or metric.
As to the LR 32 system, no matter how you go about getting the size LR 32 rail you desire, when used as a fence these Incra tracks work hand-in-hand with that system.  Even without the LR 32 system, these tracks could be used to accomplish similar tasks.  While this may or may not work as nice as the LR 32 system, using some of these  Incra products does allow one to create setups for various step-and-repeat type operations that are not limited to a multiple of 32mm for spacing -- rather, these products can perform these type operations either in steps that are a multiple of 1/32" with their Imperial products or a multiple of 1mm using their converted rack-based products.
« Last Edit: April 06, 2008, 07:23 PM by Corwin » Logged
Shirt Size:  L
Les Spencer
Offline Offline
« Reply #18 on: April 06, 2008, 08:13 PM »
Guys all  I can say is good luck. I was a Tool and Die Maker and I wouldn't try it. If you're going to go forward, instead of making oval/oblong holes, make the holes round and use a diamond locating pin. A diamond locating pin, for those who are not familiar, is a pin shaped like a baseball diamond. 2nd base and home plate are the radius of the pin and 1st and 3rd base are ground to a relief. The arc of the radius need not be more than needed to give you the longitudinal location.
Les (near Indy) XL
Eiji Fuller
Retailer
Offline Offline
« Reply #19 on: April 07, 2008, 01:10 AM »
The whole point was to use the LR32 and 1080 to rout holes in a longer guide rail. By using the 1080 rail you know the spacing of the holes will be correct. I just need to come up with the proper set up since the 1080 rail will over lap the rail to be drilled.
I havent even set up or used the LR32 yet, but....
I'm thinking a piece of 19mm MDF wide enough to accomodate both rails with a 5mm deep dado the width of one rail.
I think I will pull the splinter strip off the drilled rail so the dado can capture the rail with out it being hung up on the rubber.
The dado will enable me to use just one clamp for the drilled rail and I can move the clamp to the other side of the jig as I progress with the drilling. Ahhh so many words and so little time. I will make the jig and take some pics.
Later,
Eiji
Michael Kellough
Offline Offline
Southern New York
« Reply #20 on: April 07, 2008, 10:00 AM »
Later,
Eiji
So you would clamp the LR 32 rail on top off (sort off) the plain rail? The rail to be drilled/routed will be upside down (spines captured in the dados) so the rails are flat to flat? I think the rubber strips won't be a problem.
I think this would work, what do you think Les?
Eiji Fuller
Retailer
Offline Offline
« Reply #21 on: April 07, 2008, 08:56 PM »
Les,
 I didnt think of that. That might be a better idea than a dado the whole width of the rail.
[/quote]
[/quote]
polarsea1
Offline Offline
« Reply #22 on: April 08, 2008, 12:02 AM »
Mirko's scheme is what I've used to make drilling jigs, it's very fast and no worries about routing aluminum. Just be sure when you measure for the 1st hole it's from center to center and not from the edge of the pin to the center of the 1st hole. DAMHIKT.
Les Spencer
Offline Offline
« Reply #23 on: April 08, 2008, 12:17 AM »
Later,
Eiji
Should be a good way. Just make sure you are parallel and watch the end holes. You will want to join the rails and they must be the same distance from the ends in order to use the longitudinal stops to set the spacing. Instead of worrying about making the holes oval by moving the center line of the bit, I would just take a round file and make the holes oval. I'm still not sure it's worth the effort and worry. Seems like a lot of work to save $76. Having seen some of Eiji other posts, he is obviously talented enough to make it work.
Les (near Indy) XL
Eiji Fuller
Retailer
Offline Offline
« Reply #24 on: April 08, 2008, 08:14 PM »
I doesnt make alot of sense for the first one. But if you need more or if another Fezaholic needs one the set up is there and the cost per rail goes way down.
Eiji
Eiji Fuller
Retailer
Offline Offline
« Reply #25 on: April 08, 2008, 08:24 PM »
Guys,
It may be awhile before I can get to this. I've got some doors to build.
Eiji
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #26 on: April 13, 2008, 09:53 PM »
Beca;use the holes the router "drills" are offset off the LR-32 Guide Rail, it should be possible to butt the end of an LR-32 Guide Rail and butt the end of the Guide Rail into which you want to cut indexing holes against stops to ensure correct positioning of the holes you are machining relative to the end of the rail.  I own only a short LR-32 holed rail, and when I need to make a row of holes that is longer than the guide rail, I simply join it to another non-holed rail and slide the holed rail lengthwise using at least one of the already drilled holes in the workpiece for registration, reclamp the guide rails and resume drilling holes with my router.  But I don't make my living doing this.  If I did, I'd simply buy a longer holed rail from Festool.  I do wonder why Festool simply doesn't provide the holes in all their Guide Rails.  I note in the new catalogue there is a big discrepancy in the cost differential of the longer guide rails with and without holes, compared the cost very small cost differential between the short rails with and without holes.  Makes no sense to me.  Once setup, the machining should be fast and easy.
Dave R.
greg mann
Offline Offline
« Reply #27 on: April 14, 2008, 10:50 AM »
Dave R.
So it would seem, Dave, but the problem for Festool is that adding the holes in a small guiderail can be done with a small (read cheaper) machine, one which can be used for lots of other tasks as well. Adding holes to a long rail requires a larger, far more expensive, machine that holds no extra value since there are no other Festool product that readily come to mind for which a long bed machine would be useful. Ergo, a very expensive machine is needed for creating an occasionally purchased rail. They may actually farm this out, which is pure speculation on my part. Adding holes to all long rails would probably help amortization, but it would certainly add cost to already expensive long rails and inhibit some purchases.
Greg Mann
Oakland, Michigan
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #28 on: April 14, 2008, 01:06 PM »
True, Greg, but why not put holes in all rails that are 95" and shorter such that any two rails joined end-to-end would present a continuum of perfectly registered holes?  Since the 75" and shorter rails are supplied with MFTs and TS 55 and TS 75 saws, why not simply put the holes in these rails and then encourage all these Festool owners to add a Festool router and the hole drilling plate and side stops?  I would rather not have to have any more rails than absolutely necessary and have that money back to spend on other Festool products.  Of course, by now, I already have more than enough rails for anything I am ever likely to tackle, although I will have to index my LR-32 holed rail to drill for shelves in any tall closet system, and probably in shop-made Sysport substitutes.
Dave R.
Corwin
Offline Offline
« Reply #29 on: April 15, 2008, 03:53 AM »
I thought we had already covered this topic and it had all been explained...  As I recall, the LR32 rails are rather expensive to create with the holes, and the additional expense is not entirely passed on to the buyer...  If they were to offer more sizes with these holes, the entire line up of rails would probably go up in price to cover their costs.
Shirt Size:  L
Pages: [1]   Go Up
  Print
Jump to:
