Pages: [1]   Go Down
  Print
Author Topic: Source for 80/20 type extrusions  (Read 4920 times)
Richard/RMW
Retailer
Offline Offline
WWW
« on: June 10, 2012, 01:08 PM »
I use a lot of 80/20 type extrusions for shop fixtures/jigs, I just found a great source and thought I would pass it along. The company is Misumi and they offer cut-to-length extrusions for less $$ than I can get 80/20 on eBay.
The profiles I most commonly use are 40mm or 1-1/2", both fit the Festool clamps. Misumi's part number for the 40mm light profile (similar to 80/20 4040-LS) is HSFL8, their cost is +/- $3.90/foot cut to length. 4' of 80/20 4040-LS sells for $26 on eBay, and you have to cut it yourself.
They also have a great search tool for all their extrusions and compatible hardware at:
http://www.misumiusa.com/CategoryImages/AluminumExtrusions/Extrusion-Browser.html
RMW
Add-on products for Festool @ www.ripdogs.com
WarnerConstCo.
Online Online
WWW
« Reply #1 on: June 10, 2012, 03:48 PM »
I just drive over to 80/20 and sort through their off cut pile......
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #2 on: June 10, 2012, 04:05 PM »
Do you deliver...? Wink
ezdrive
Offline Offline
« Reply #3 on: June 10, 2012, 04:19 PM »
RMW;
I was just looking for this type of product.  I have seen systainer carts made from extrusions and thought able trying to build my own.  Unfortunately, the samples I saw were from Festool Owners from across the pond.  Thanks!
Ray
hobbes
Offline Offline
Work smart, play hard.
« Reply #4 on: June 10, 2012, 11:22 PM »
Thanks for sharing the source! I see some potential new projects for this...thinking router table or sys port.
Kev
Offline Offline
« Reply #5 on: June 11, 2012, 01:47 AM »
This stuff is truly "Big Boy Meccano".
What are the thoughts on KAPEX for cutting with the right blade?
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #6 on: June 11, 2012, 08:58 AM »
Kev,
I cut this stuff with a Freud blade in my metal chop saw at 1,500 RPM, no issues. Not sure the RPM on the Kapex, my blade is :
"Freud D1296N Diablo 12-Inch 96 Tooth TCG Non-Ferrous Metal and Plastic Cutting Miter Saw"
Comments on Amazon indicate that others are using this blade in wood-cutting saws with good results.
RMW
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #7 on: June 11, 2012, 12:09 PM »
I've cut a fair amount of aluminum and other non-ferrous metals with the Kapex.  I've had no problems cutting profiles with walls up to 1/8" (3mm) with the Festool non-ferrous metals blade.
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #8 on: June 11, 2012, 04:38 PM »
You can get very accurate cuts in aluminum with a Kapex and the Aluminum/Plastic blade. I have a customer that uses one to miter extrusions for large home theater screens. It makes a nice, tight miter.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
japanesewoodworker
Offline Offline
My Dog's Name=Blackie
« Reply #9 on: June 17, 2012, 07:52 PM »
Hello ,
Shouldn't this be:
HFSL8-4040 ...... ( or am I  switching around some letters....does HSFL8 = HFSL8 ?)
I price this at about $ 17.00 per meter (approx. 3 feet) precut + shipping from Indiana
On 06/17/2012....Happy Fathers Day. Smile
" The sweatness of a low price is soon forgotten when the poor quality is discovered.... Ben Franklin  Boston, Ma
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #10 on: June 17, 2012, 10:49 PM »
Hello ,
Shouldn't this be:
The HFSL8 looks to be their 40mm light extrusion, similar to the 80/20 40-4040 Lite. I purchased all my stuff off eBay and only recently found Misumi but their prices do look cheaper.
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
I did just notice that the Misumi profile has a wider slot, 10mm versus 8mm+ on the 80/20. If you are using the Festool Clamps you should double check them before ordering the Misumi profile, 10mm may be a bit too wide for the clamp.
I know the 80/20 40-4040 works great with the Festool clamps.
RMW
Christopher Robinson
Offline Offline
« Reply #11 on: June 21, 2012, 07:27 PM »
Does anyone know where in the USA I might find an extrusion (and which model number) that will fit clamps in a groove in addition to the V groove that you can clamp things like the kapex extensions to that the MFT3 has?
I'm looking to build a custom longer table for the shop and keep my mobile MFT3 in my trunk.
Want the exact same functionality in the shop but bigger...wanting a SINGLE piece instead of two MFT's...
Does anyone make the exact same extrusion custom length?
Christopher
WarnerConstCo.
Online Online
WWW
« Reply #12 on: June 21, 2012, 08:36 PM »
If some of you guys know what you need, I would not have a problem going on a little drive to get what was needed.
doc4som
Offline Offline
« Reply #13 on: June 21, 2012, 09:31 PM »
I am trying to accomplish the same thing Christofer. I would welcome the same info.
Christopher
jtparrothead
Offline Offline
« Reply #14 on: July 07, 2012, 12:28 PM »
just out of curiosity, does anybody know what size extrusion you would need for the guide rail supports that go on the mft/3 or any of the other accessories for that matter? I have never actually put my hands on one or even seen it in person so it may be the same as the clamps?
Pages: [1]   Go Up
  Print
Jump to:
