Pages: [1]   Go Down
  Print
Author Topic: OF 1400, deep chip catcher  (Read 2732 times)
ama
Offline Offline
« on: August 07, 2012, 03:18 PM »
Trying to post again. This forum software doesn't seem to like me, but it is completely mutual. Should this end up as a bunch of posts, apologies.
After getting some proper router bits to replace the cheap sets I have been playing with so far, I note that they will not fit with the OF 1400 rotating chip catcher. Festool could have solved this with a deeper catcher but since they don't have one, I chose to modify the existing one instead.
Some pvc tube that is just about the right diameter.
I'll make a cutout in the outer pipe,
cut away the bottom of the catcher
and fit two inner pipes to get an adjustable aperture. This way we can route with a very small opening,
a wider opening,
and/or a taller opening.
This is a very rough prototype. If it works well but I find things that could be improved, I might build a nicer one.
Deansocial
Offline Offline
« Reply #1 on: August 07, 2012, 03:55 PM »
Good idea, i like it
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #2 on: August 07, 2012, 06:11 PM »
What he said.  Please let us know how it works when you have tested it.
Alan m
Offline Offline
« Reply #3 on: August 07, 2012, 06:16 PM »
very nice.
could you attach the dc hose to the bottom of that and extract from there
now
wish list
jmbfestool
Offline Offline
« Reply #4 on: August 07, 2012, 06:21 PM »
very nice.
I think thats the idea...... well thats what I thought the idea was when I saw the pictures.
I like it!    If you are sticking the extraction on the bottom I recon the dust extraction would be 100% better for that job.
I have cut into mine couple times because its not deep enough.
Well when I get round to it I might modify mine like that also!
Cheers!
ama
Offline Offline
« Reply #5 on: August 08, 2012, 02:31 AM »
very nice.
I was planning on trying it both ways but I fear that attaching the hose at the bottom will interfere with the swiveling of the catcher. I'll let you know.
ama
Offline Offline
« Reply #6 on: August 21, 2012, 09:41 AM »
Now that I have had a chance to try this thing I can report that it works really, really well. I didn't try mounting the hose at the bottom but it would have been too clumsy for today's routing. Anyway, the dust collection was very good with the hose on top so I see no reason not to run it like that.
The longer chip catcher swiveled just as nimbly as the original.
TomGadwa1
Online Online
« Reply #7 on: August 21, 2012, 11:57 PM »
Well that looks like a great chip catcher for portable use. I came up with a chip catcher that is portable but slightly larger than the OP's design. I call it the MEGACHIP chip catcher. The beauty of this unit is that it will work with ANY router. I repeat it will work with ANY router of any size and make. It collects 100 percent of the chips and the router requires NO hookup to a dust collection system as the MEGACHIP catcher gets all of the chips. This is nice because the router is easier to maneuver with no hose attached to it. I can mill out dados grooves and what have you and there will be no trace on my clothing that I got near a router at all.
Full view of the MEGACHIP catcher.
Looking at the collection throat.
The four inch hose that goes to the 1.5 horse power dust collection unit.
View showing MEGACHIP catcher before the router guide and support plates are installed.
View showing the MEGACHIP catcher with the router guide and support plates installed and ready to route. The plates are clamped at the edges to insure that the router will have a stable platform and are made of phenolic coated plywood so the router will glide across for precise workage.
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Pages: [1]   Go Up
  Print
Jump to:
