You can also use phenolic plywood for this purpose.
Pretty sure you already know about Euro Color Ply phenolic plywoods, in case not, here are some more info:
Euro Color Ply is an ideal material for the furniture and joinery industries. Its features provide smooth and superior surfaces that are ready for use. The panels are rigid and often used for making
jigs and
tooling as they are
extremely durable.
Size: 2' x 4' (24" x 48")
Thickness: 3/4" (19mm)
Color: Green, Light Brown, Dark Brown, Black, Red, White
Number of Plys: 14 Plys
Advantages:Environmentally friendly, durable, easily workable, hygienic, odour free, easy-to-clean, wear-resistant, weather- and water-proof, resists commonly used chemicals. Riga Form for shuttering can be re-used many times.
Characteristics of Overlay:Surface with an overlay is smooth, glossy and hard. It resists abrasion, it is weather and moisture proof and resists commonly used chemicals, dilute acids and alkalis. The surface is easy to clean with water or steam.
Applications:- Jigs and tooling
- Desks, table tops, shelves
- Fittings for kitchens, offices, shops
- Garden furniture
- Signs, billboards
Click here to order!
Anderson Plywood's
Layout Square for MFT Table is also made from the same material:
