Pages: [1]   Go Down
  Print
Author Topic: My AP85E smoke began to pour!  (Read 1099 times)
bichodamadeira
Offline Offline
My Girl! Could you even make frames!?
« on: May 16, 2012, 05:54 PM »
Hello friends!
 I have a table saw AP85E.
 Today I started cutting pine with 2 inches (5cm) and it seems incredible that began to go out a lot of smoke of burning.
 Is it that the blade is dull?!
 Why does this happen?
 I wonder opinion.
 Thank you!
Alan m
Online Online
« Reply #1 on: May 16, 2012, 06:11 PM »
usuall reasons are
dull blade
build up of resin on the blade
fence not parallel to blade
too fine a blade
now
wish list
Timtool
Retailer
Offline Offline
WWW
« Reply #2 on: May 16, 2012, 06:20 PM »
Alan is right, also if you are cutting in the length of the wood then you must use a blade with few teeth, around 24.
bichodamadeira
Offline Offline
« Reply #3 on: May 16, 2012, 06:29 PM »
Thanks Alan, for your help.
 I believe also that the blade is blind.
 Soon I intend to replace the blade! Smiley
KorDes
Festool Dealer
Offline Offline
WWW
« Reply #4 on: May 17, 2012, 03:39 AM »
Is the blade on the right way? Its not the first time someones come in here and asked why their saw is smoking when doing a cut, only to realise they put the blade on the wrong way.
Pages: [1]   Go Up
  Print
Jump to:
