Pages: [1]   Go Down
  Print
Author Topic: WCR1000 Shelf retention improvement  (Read 1132 times)
TomGadwa1
Offline Offline
« on: April 24, 2011, 09:20 PM »
After I almost knocked my new MFK700 trim router and shelf off of my new WCR1000 I decided it would be a good idea to improve on the mounting of the shelf. This is a very easy and cost effective way to prevent the shelf and a precious tool from taking a trip to the floor causing tears and heartbreak to the tool and owner. Just take some 8-32 machine screw hardware and install it in the top mounting recess where the shelf tab is inserted above the tab. This will lock in the tab which will prevent the shelf from coming out of its mounting.
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Pages: [1]   Go Up
  Print
Jump to:
