Pages: [1]   Go Down
  Print
Author Topic: MFT-Based Workbench  (Read 2184 times)
Phred
Offline Offline
« on: May 04, 2013, 01:19 PM »
Below is a design for an MFT workbench assembly.  I have been watching all of the other designs posted here as well as Guido's and came up with this variation on the theme.  My objectives were:
1)  Clean up my pile of systainers and make them more accessible.
2)  Create an ability to use handtools (planes mostly with some hand sawing) with my MFT's.  By using Quick Clamps in the front extrusions of the MFTs and a sliding deadman (the tracks run full width top and bottom), there is lots of flexibility for holding pieces on edge.
3)  Create storage for lots of small parts and tools
4)  Create an easy way to cover the table with kraft paper for glue-ups, finishing, etc.
I already have two MFT 1080s and one MFT 800.  Not shown is a Chop Saw hood mounted to the rear of the middle MFT (helps keep sawdust from blowing onto a car in the winter).  The overall assembly is sandwiched between a tire storage rack on the left and a bandsaw on the right--the later should help stabilize the assembly further during handplaning.  The wheels aren't really necessary but may prove handy when it comes time to reconfigure things.
The beast holds up to four Systainer 1, five 2, four 3, and four 4 (and that includes room for seven future Systainers).
I am still quite the novice with SketchUp so there are many errors in the models.  And I thank Brice, jonny, and others from whom I "borrowed" models of components (the MFTs, Systainers, paper holder, basic drawer design, etc.).
I would appreciate any feedback and suggestions from this august group of more experienced woodworkers.  Thanks for looking!
Fred
Front view
Rear view
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #1 on: May 04, 2013, 03:40 PM »
Great concept.  You might want to execute it so the overall height of the MFTs' work surface is 900 mm.  If you were to add any current MFT/3's or a CMS to the assembly, they would all be at the same height.  Also, think about making sure that the width of the carcase is no wider than the sides of the MFTs so you can clamp pieces vertically to the sides of the MFTs, and be sure to not use drawer handles that protrude further.  Just a thought.
 Smile
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
rnt80
Offline Offline
WWW
« Reply #2 on: May 04, 2013, 04:04 PM »
Fred, fwiw, I recently built two carts for mft3's very similar to yours.  The two mft's are joined together on the top of the carts.  I was going to include a lip/ledge like you have in your drawing to make sure the mft's stay on the top of the carts and don't slide around.  After using them for a few weeks (doing everything from crosscutting, routing, assembling, and hand planing) I've found it unnecessary to include something like that.  The rubber feet on the bottom of the mft's have kept the benches firmly in place.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
Michael_Swe
Offline Offline
« Reply #3 on: May 04, 2013, 04:06 PM »
Seems like a nice setup.
I'd hang the paper roll on the side at the end to avoid having anything protruding above the table surface. That way you can have beams and sheets hanging over the edge a bit if you need to.
Do you have a miter station else where? Other wise you might want to incorporate it in the concept since you have such a long bench anyway.
Phred
Offline Offline
« Reply #4 on: May 04, 2013, 04:18 PM »
Willy:  Good suggestion about the height--I hadn't even considered that and it's an easy change to make now before I have started cutting plywood.  The drawers are designed not to have any handles and the outer surface of the sliding deadman is designed to be aligned with the MFT side rails.  I didn't draw it (I stole a component someone else designed instead), but I'm thinking I'll probably use a deadman that includes a Bessey toggle clamp fitted to a slot (allowing for vertical height adjustments) instead of the pegboard.
Russell:  What rubber feet are you referring to?  I don't see any on my older MFTs (after removing the legs) and I just looked at some photos of the newer MFT3s and don't see them their either.  Were they something you added?
Michael:  Good ideas as well.  I keep going back and forth on blocking the end of the table for the paper.  Where it is currently located there is no room beyond the bench to hang something out further but I may want the flexibility for the future.  I don't have a miter station yet--another good idea to incorporate into the design.
Thanks to all of you for your input--these are exactly the sorts of suggestions I am hoping for!
Fred
greymann
Offline Offline
« Reply #5 on: May 04, 2013, 04:26 PM »
Fred,
I don't see any way of leveling the units in your design.  I'm looking at doing something similar and I know I can't get by without it in my shop.
Also, do you have the option of joining the two 1080's along the long sides?  I have two 1080's also and find I use them joined that way more often than not.
Dick
The difference between theory and practice in practice is greater than the difference between theory and practice in theory.
JayStPeter
Offline Offline
« Reply #6 on: May 04, 2013, 04:55 PM »
I agree that I'd put the paper roll on the side and not above.
Also, I don't know what the distance between the carcase top and the MFT top is, but is it enough to get clamps in from underneath?  Just doesn't seem high enough to me, but may be.
Jay St. Peter
Corwin
Online Online
« Reply #7 on: May 04, 2013, 05:10 PM »
Fred,
Dick
Yeah, that business about joining two tables along the long sides is something I was going to mention too.
The rubber feet Russell was talking (part no. 701230) came with the MFT 1080s and 800s, they fit on the bottom of the aluminum corner pieces and come into play when you set your MFT down with the legs folded up.
Shirt Size:  L
Phred
Offline Offline
« Reply #8 on: May 04, 2013, 05:45 PM »
I agree that the paper needs to move.
I'll have to look around for the rubber feet--I may have them rat-holed somewhere.  Thanks for the part number, Corwin.
Dick:  I am planning on joining all three tables together using the MFT table connectors.  If I need more stability to resist lengthwise racking (e.g., while planing) then I figured I could bolt the sidewalls together.  As for leveling, me the fudgehead hadn't thought about that issue.  I suppose I could shim under the wheels (better to do it at the bottom so the shelves are also level) or substitute leveling casters.  I'll do a search for some reasonably priced options.
Jay:  There's just enough room under the tables to fit Jorgensen hold-down clamps (image at Jorgensen Hold-Down Clamp).  I usually use the Festool clamps upside down (with the handle end sticking up into the air), so I didn't think I would need more room underneath.  Good point that I'll have to think about.
Thanks for the additional input--please keep it coming!
Fred
Kevin Stricker
Offline Offline
« Reply #9 on: May 05, 2013, 01:07 AM »
Unless your design is going to be modular I would build it so your bottom frame is one continuous unit and have some sort of retractable wheels on one side so the whole thing can rest on foot levelers when not being moved.  The casters are going to ruin the design if stability for hand planing is a priority.
CJ'60
Offline Offline
« Reply #10 on: May 05, 2013, 08:06 AM »
Instead of having the lip/ledge on the outside of the MFT feet you could consider to screw some blocks on the cabinet tops at the inside of the MFT feet, enabling to pair the MFT width-wise and length-wise. It will make your cabinets slightly smaller, so it might take some rework in sketchup.
AT-65 EB/1 Plus, CTL Mini, PS 300 EQ, OF1010 EBQ, Domino Set
sancho57
Offline Offline
« Reply #11 on: May 05, 2013, 09:14 AM »
I dont planning on building one those at this time or have built one. So Im not really qualified to give a option on this.
So this comment is coming from way out in left field.
But If I were to build one I would ensure the top of the MFT is at 900mm. If I read your DRG correctly you have it at 860mm.
The reason for the 900mm is for the height of the MFT to be compatible with other festool tools so you could use your MFT as a in-feed or out feed for the Kapex, CMS etc
Shhhhhh Dont tell the wife butttttt I bought another…….
Sparktrician
Offline Offline
« Reply #12 on: May 05, 2013, 03:24 PM »
Fred
Fred, you might want to look at this photo to see how I used 1/4" plywood blocks to keep the MFT from inadvertently sliding off the SysPort.  The top of the MFT was removed for the photo.  The feet that Russell is referring to are part of the MFT/3's base.  If the legs are folded up, the four corners will be sitting on light gray feet rather than have the aluminum corners sitting directly on the floor (or on top of the SysPort).  I'm not familiar enough with the older MFT 1080 to know if it has similar feet, but I can't imagine it not having them.
- Willy -
rnt80
Offline Offline
WWW
« Reply #13 on: May 05, 2013, 04:33 PM »
Fred, here's the thread that I started that shows the carts I built.  They are very similar to yours except for the fact that I have two benches together instead of three.  I strongly recommend the fence dogs that are sold on ebay.  I bought two pair and can now pull my two fences out in less than five seconds in case I need the entire surface of the bench to work.  Additionally it allows me to but the benches together without having to make room for the piece that locks the fence down at the end...not to mention I don't have the miter gauge sticking out from the bench all the time.
http://www.ebay.com/itm/Lock-Fence-dogs-for-Festool-MFT-pr-/281085610727?pt=LH_DefaultDomain_0&var=&hash=item4172020ae7
http://festoolownersgroup.com/member-projects/out-with-the-bad-in-with-the-good-(think-lloyd-christmas)/msg251870/#msg251870
« Last Edit: May 05, 2013, 04:36 PM by rnt80 » Logged
Russell Tribby
Gilbert AZ
Phred
Offline Offline
« Reply #14 on: May 05, 2013, 07:29 PM »
Thanks to everyone for the additional suggestions.  I like the alternatives for blocking the MFTs in place if needed (but I'll probably try it without anything at first--I had never noticed the rubber feet on the MFTs and it sounds like they were sufficient in Russell's set-up).  Russell, thanks for posting the link to your build--somehow I completely missed that thread.  Still haven't decided about the feet, which will impact the height of the sides so that I end up with a 900 mm finished height.  If I use casters, I'm thinking of Zambus style ones that sit on big rubber pads when lowered--I have them on my bandsaw and jointer/planer and they seem really solid to resist racking.
Thanks again!
Fred
fastbike
Offline Offline
« Reply #15 on: May 06, 2013, 09:51 AM »
I have found the same. In my case the rubber feet bracket the corners. No issues w/ the table sliding around.
I was so much older then, I'm younger than that now.
fastbike
Offline Offline
« Reply #16 on: May 06, 2013, 09:56 AM »
The Festool 4 1/2" clamps are just workable, but fiddly. I also use the Jorgensens when I don't want a handle sticking up.
Fred
fshanno
Offline Offline
« Reply #17 on: May 06, 2013, 04:13 PM »
It might be nice to rig it so that it could serve as a low-rise assembly table with the MFT's removed.  That can be very handy at times.
Pages: [1]   Go Up
  Print
Jump to:
