Pages: [1]   Go Down
  Print
Author Topic: A useful Domino jig for smaller parts  (Read 2733 times)
builderbob
Online Online
WWW
« on: January 20, 2012, 11:47 PM »
Good day all!  I have a larger built-in project coming up soon and I've found myself very frustrated trying to domino smaller parts.  I will first say that for 1/2" & 3/4" parts, I don't register the domino off of the work surface.  I use the domiplate...which I love...from RonWen!  The only issues that i have is with trying to put dominos into smaller surfaces.  I built this jig to lift my material off of the work surface so that i can safely domino my material and secure it as well.
Basically, I used a bunch of scrap ply...the main frame is all 3/4" thick and the top is 1/2" so that it would sit flush with the t-track.  I wasn't aiming to make this pretty...just functional!  I think my photos are pretty easy to understand...I tried to hold the Domino in one hand & take the photo with the other to give you an idea how it will be used.
The only thing I needed to purchase was the t-track and the woodpeckers hold downs.  I also implemented the Kreg bench dogs so that I am able to stand a face frame on edge without it pushing out while I'm domino'ing!
Let me know if you have any questions!
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Chris Has Flair
Offline Offline
I make sculptural furniture.
WWW
« Reply #1 on: January 21, 2012, 12:10 AM »
Bob,
You gave me a great (I think) idea.  I want to mount the Domino right-side-up to a flat surface with a T-track for stops and hold downs.  I think it will resemble a slot mortiser of sorts.
Chris Wong
http://FlairWoodworks.com
http://TimeWarpToolWorks.com
If it bothers you that the chair [you are building] is askew, just go to you local furniture store and look at chairs until you feel better. – Brian Boggs
builderbob
Online Online
WWW
« Reply #2 on: January 21, 2012, 12:16 AM »
Chris, I think that could be great...a semi-stationary domino of sorts.  I love the tool, there's so many possibilities with jigs (Rembo's is a great example of amazing domino jigs)!
Bob
SRSemenza
Global Moderator
Offline Offline
« Reply #3 on: January 21, 2012, 12:22 AM »
You mean something like this for a mounted set up?
 Biscuit Master
Domino kit
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
jussi
Offline Offline
« Reply #4 on: February 10, 2012, 01:53 AM »
 Biscuit Master
Domino kit
Does the Biscuit master work with different stock thicknesses?  Do you need to shim it?
Pages: [1]   Go Up
  Print
Jump to:
