Author Topic: New Domino XL Thickness adapter project  (Read 23976 times)
Offline thlambermont
Re: New Domino XL Thickness adapter project
« Reply #30 on: July 27, 2017, 12:09 PM »
Hello everybody,
I'm new on the forum ! I'm looking for a way to use my domino XL nn finer thicknesses and I really like your prototype.
I made a fast prototype to change "clips". What do you think about it? I use the same process design as the LA-DF 500/700.
Here for exemple I used a wooden piece of 12mm. This way I can center the domino on a 16mm mdf board.
266192-0
« Reply #31 on: July 28, 2017, 03:26 AM »
It should be improved (a lot) but you can see what I had got in mind. We could imagine to put two tracks below with some screw holes (like LA-DF 500/700) and use it on smaller pieces. I'm going to look for a 3d printer near me and test it.
Offline sebcbien
« Reply #32 on: October 12, 2017, 12:45 PM »
Hello @thlambermont
Please open a new topic for your project. Mixing two different projects in the same thread will confuse readers.
Thanks.
« Last Edit: October 12, 2017, 12:50 PM by sebcbien »
Offline sebcbien
« Reply #33 on: October 12, 2017, 12:50 PM »
Hello everyone,
I've now sold some pieces of my prototype and the woodworkers are very happy with them.
Below is one plate being printed (+- 7 hours)
« Reply #34 on: October 12, 2017, 12:51 PM »
@sebcbien It's exactly the same tool, I copy the one you created and change the fixation system. But if your prototype works very well with the current fixation I would like to order one  [big grin] Thank you
Offline sebcbien
« Reply #35 on: October 12, 2017, 02:38 PM »
Ok, didn't get that, sorry. :-[
This design has some good points, but as disadvantages, I see those:
- one is that it will take more place on the fence and then reduce the "agility" of the machine to go in small places
- An other one, is that I think that the plastic would "bend" lighty with the pressure of the arms of the clamping system, the plastic used by festool is harder and made under pressure, it's not the case with the ABS used by 3D printers.
- About the clamps, they are metal and I cannot make them.
Seb
Offline sylthecru
« Reply #36 on: October 12, 2017, 03:14 PM »
Do you plan to release the .stl files or make the shims out of aluminum? I am interested in the .stl files as I have a 3d printer
Here is a video of my prototype of thickness adapter for the Festool DOMINO XL.
This solution solves two problems of the domishim.
I show you the use of the prototype for stock of 12 and 22 milimeters
The final product will have three plates to cover all common stock thickness:
Plate 1:  12 -22 mm
Plate 2:  9 - 18 -38 mm
Plate 3:  15 - 25 mm
It's easy to make also plate for imperial measurements. 1/2" 3/4" ...
It's only a prototype and I have still work to do to have the final product.
So please give your advice below and say if you would be interested by the final product.
Here is the video:
TS55 REQ, Mini Dust Extractor, OF1400, DF500 Domino, MFT/3, LR32, RO125, Kapex, CT 36, CMS, Carvex
Offline sebcbien
« Reply #37 on: October 12, 2017, 03:32 PM »
Hi sylthecru,
Building my prototype required to print between 15 and 20 plates and it's impossible to count how many hours and days it took me to design it.
As well as I'm someone who shares A LOT on internet (and in the real world [laughing] ), takes time and appreciate to help others, for this work, I will not release it because it tooks me more than time, I've invested in a good 3D printer (3000€) and the cost of printing the prototypes is not cheap (3D printing is usually 10€ per hour, and it's between 4 and 9 hours to print a plate...)
Releasing the STL files means also that others will be able to sell the plates to people who don't own a 3D printer.
Hope you can understand,
Seb
« Last Edit: October 13, 2017, 04:19 PM by sebcbien »
Offline sylthecru
« Reply #38 on: October 13, 2017, 09:28 AM »
I understand you are trying to recoup the cost of your investment. DO you have an idea of what the final adapter will cost? I am really interested.
Hi sylthecru,
Seb
Offline sebcbien
« Reply #39 on: October 13, 2017, 10:03 AM »
The prices depend of the number of plates and the shipping costs.
The thickness of the plates also changes the price, the 7.5mm takes more time and materials than the 4mm.
As for the exact price, I'm not sure I can talk about it here...
So please mail me at: sjauquet (Gmail) or PM
Envoyé de mon SM-N950F en utilisant Tapatalk
Offline Steven Owen
« Reply #40 on: October 13, 2017, 01:48 PM »
It looks cool.  Have you ever considered contacting Seneca to see if they will license your design to build this as a Domino accessory?
I think Seneca would be keen to develop your design.  They have the equipment to mass produce it with higher quality plastics.
Offline sebcbien
« Reply #41 on: October 13, 2017, 04:25 PM »
Hi Steven,
I didn't contact Seneca, maybe later, maybe it's a good idea.
@sylthecru , I forgot to answer about the aluminium, the current design uses the flexibility of the plastic (ABS) to stick to the fence. Doing it in aluminium would require another design with no major advantages.
Seb
Offline Steven Owen
« Reply #42 on: October 14, 2017, 04:06 PM »
Hi Steven,
Seb
You’ll have to get a couple of prototypes working that you can send to Seneca.  With international distribution, you’ll probably make more money selling or licensing your design to Seneca that you would trying to 3-D print them on your own.
Offline worldburger
« Reply #43 on: October 23, 2017, 11:59 AM »
hello,
Kuukkeli had a idea to enhance the thickness adapter.
the idea is to make a small piece of 3d printed thicknesses to modify the height of the fence to match perfectly other material height.
So I made some calculations and found a combinaison where with one plate and this cros  shaped piece the df700 can match those material heights: 30mm - 25mm - 22mm - 19mm (3/4 inch) - 18mm - 15mm - 13mm (1/2 inch) - 12mm
Here are some pics of a prototype:
@sebcbien this is a very creative solution.  I am curious: why not just create thickness modifiers like this instead of adding thickness to the fence? Can you not get the fence close enough as Festool sells it?
Offline sebcbien
« Reply #44 on: October 23, 2017, 04:14 PM »
The plate allows to go lower than the minimum of the cursor... The cursor cannot go lower than 0 and 0 means the center 20mm stock (10mm)
Seb :-)
