Daviddubya
Offline
Arizona, USA
« on: January 23, 2007, 10:41 AM » |
I have read some threads about the Festool OF1400 router being less than stable when used on the guide rails. As many know, the OF1400 employs an outrigger to make the router level when used on the rails. This leveling outrigger is a major contributor to the complaints about instability.
I came up with a really simple idea to solve the problem. See the attached photos. I made a secondary base plate that attaches to the bottom of the OF1400 when used on the rails. I made the base plate from a piece of 1/8" hardboard with Formica laminated to both sides. The resulting thickness is .20", just right to level the router on the rails.
The first photo is the secondary base plate I made. The second photo shows the secondary base plate mounted onto the router using two threaded holes that already exist in the router base. The countersunk bolts were purchased at Ace. The third photo shows the router on the rail with the secondary base plate installed.
Some folks have leveled the OF1400 by allowing a portion of the base to ride on the rail. I have not tried this method, but I sure like the stability of having the entire router base riding on the material surface.
David W. Falkenstein in Cave Creek, AZ, USA
Dan Clark
Offline
« Reply #1 on: January 23, 2007, 11:53 AM » |
Dave,
Nice post! I've seen your post about this on another forum, but it's great to have it here for quick lookup.
Thanks,
Dan.
CharlesWilson
Offline
« Reply #2 on: January 23, 2007, 02:06 PM » |
I saw your post on that other site, but couldn't view the pictures. I didn't get any help from the moderator there, either. Thanks for posting it here.
Charles
Charles Wilson
Jason White
Offline
Location: Sherman Oaks, CA (Los Angeles) Member Since: Jan 2007
« Reply #3 on: April 04, 2007, 01:24 PM » |
This seems like a serious design flaw in the router/guide-rail system. Do others here have this problem? TP I have read some threads about the Festool OF1400 router being less than stable when used on the guide rails. As many know, the OF1400 employs an outrigger to make the router level when used on the rails. This leveling outrigger is a major contributor to the complaints about instability.
AMC
OfflineMember Since: Mar 2007
« Reply #4 on: April 05, 2007, 04:43 AM » |
I'm a bit perplexed by this thread. I've never had any problems with instability. Bit I run the OF1400 right on the rail, set so that the bit cuts to a whisker off the rubber strip. The outrigger works perfectly then - no instability in the router, a smooth run up the rail's friction strip. Is there any reason to do it any other way?
I notice that you have the outrigger guide block adjuster running inboard, on the rail. I have it sitting outboard, off the rail, leaving plenty of room for the router.
(Later: I see that Rick Christopherson's OF1400 manual recommends this. But I run one block on the outside rib, not the main rib, and put the adjuster offside the rail. The guide block fits perfectly between the ribs - no slop. It certainly works for me.)
Matt
Barryduck
Offline
« Reply #5 on: April 05, 2007, 05:16 AM » |
HI David, What a great solution. I have had a similar problem. I also find it is "tippy" when routing edges e.g tables etc due to the large hole in the base. This seem to be exacerbated when the chip catcher is fitted. Maybe I'm using the wrong technique. I'm hoping once I get my CT22 with boom arm attached that this may overcome the problem as hoses dragging on the floor may be the culprit. Any suggestions?? Cheers Barry Duck
Daviddubya
Offline
Arizona, USA
« Reply #6 on: April 05, 2007, 09:12 AM » |
Matt
In my experience you can place the OF1400 Guide Stop in either orientation on the rail - to the right (as shown in my photo, above) or with the left half off the rail to the left. I simply prefer to have the entire base of the router on the work piece, and therefore like to use the supplemental base method of achieving stability. Some folks use the LAF-OF 1400 base (part 492574). There is more than one way to get to the same end point.
mwinget
OfflineMember Since: Apr 2007
« Reply #7 on: April 15, 2007, 11:04 AM » |
This is very helpful. Would you mind identifying the (size of the) screws you found that exactly match the threaded holes in the router's base? I am thinking of making an auxiliary base for a sled application, and can't find any documentation that describes what screw precisely fits. Thanks for sharing your idea and taking time to respond.
Daviddubya
Offline
Arizona, USA
« Reply #8 on: April 15, 2007, 02:36 PM » |
Sorry, but I have no way to identify the screws (bolts?) that fit into the OF1400 base. I took my router to Ace Hardware and went through their metric collection and found what I needed. The receipt is long gone. Those that I bought have a countersink head.
mwinget
« Reply #9 on: April 15, 2007, 03:41 PM » |
Thanks, Dave. Knowing that you took your router to the hardware store is good enough for me. I will be doing the same. Thanks again.
Jim McFarland
Offline
MFTs provide excellent shade
« Reply #10 on: July 24, 2007, 07:04 PM » |
For those just reading the handy info in this thread and wanting to avoid taking their router to Ace Hardware...the screw size is M6-1.00 (6 mm diameter, 1 mm pitch). I used flathead screws approximately ~5/8" in length (15, 16, or 17mm -- I don't recall exact package specification).
I experienced the "tipping" problem when using the router/guide rail to joint a glue-ready edge on an 11 ft walnut panel (size made it difficult to get good results with either jointer or tablesaw) I tried the auxiliary base (p/n 492574) but the router was still a bit unsteady in this application. I used a 9"x12", 3/16" thick acrylic base from an older GCSS -- this gave more stability and the necessary thickness to level the router
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." - Bertrand Russell
Garry
Offline
Location: Fort Collins, Colorado Member Since: Sep 2007
« Reply #11 on: October 03, 2007, 12:20 AM » |
Has anyone just used the guide rail as and old school straight edge (backside)? Measure offset (which you have to do with the guide rail adaptor anyway) and let r fly. I just got the router with the attachement, but I haven't used either, yet.
Daviddubya
Offline
Arizona, USA
« Reply #12 on: October 03, 2007, 01:03 AM » |
Garry - You could certainly use the guide rail, or any other straight edge, as an edge guide for the router. However, I find using the router attached to the rail a better method of making accurate straight line cuts. The router has marks on the base that define the center of the bit. Using those centerline marks, I line the router up with the center of the cut, as in a dado, and make the cut. There is no need to calculate an offset, since I know where the center of the cut will be.
SRSemenza
Global Moderator
Offline
« Reply #13 on: October 04, 2007, 12:18 AM » |
Yup, no need to calculate the offset. I mark my center lines, then put a parallel line about two inches to the left. I use the extra line to place the rail perfectly parallel then just adjust the router center mark to the center line. Quick , easy and accurate.
Festool Service 800-554-8741
Tinker
Offline
« Reply #14 on: January 08, 2008, 09:58 PM » |
Matt
AMC, That's the way I have always done it. I never tried it any other way. but will look into Dave's method when i get a chance. As he says, there are several ways. That was one of the first things I learned when starting ut in the building trades.. Tinker
Wayne H. Tinker
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #15 on: February 02, 2008, 12:57 PM » |
They are 6 mm diameter. I purchased several pairs with phillips drive pan head and countersunk head styles in different lengths at a local (NE Ohio, USA) hardware store. HD and Lowe's normally stock them, too. Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
Monju123
Offline
Location: Katy, Tx (Katrina-ed out of New Orleans) Member Since: Mar 2008
« Reply #16 on: March 28, 2008, 05:11 PM » |
Maybe I'm a little sensitive right about now, having just spent the GNP of an emerging nation on green tools, but I don't see why we, the customers should HAVE to solve a problem as obvious as this. I thought we were spending what we spent on these tools to avoid such things.
TS55, Domino, OF1400, RO150,CT22, MFS 200-400-700, LR32,Parallel Guides
Dave Rudy
Offline
Coloroda Front Range, in the lee of Pikes Peak
« Reply #17 on: March 28, 2008, 07:48 PM » |
There is no problem, I believe. The outrigger foot, which I believe comes with the router, works just fine. Ingenuity being what it is, DavidDubbya came up with a more deluxe approach. Seems to happen every day on this forum. Tools work better with clever jigs and adaptations. Take Jerry's embelishment on the new MFK 700, which allows it to ride the MFT rail. (Can't wait to get my hands on that sucker). Didn't remove a defect or solve a problem, just enhanced the utility through thoughtful ingenuity. Most of us enhance most of the tools we use in similar fashion.
Dovetail65
Offline
« Reply #18 on: March 28, 2008, 07:53 PM » |
Festool sells a secondary base plate just like the one Daviddubya made.. It snaps in the existing base, so you can just buy that one if they still carry it.
nickao
SRSemenza
Global Moderator
Offline
« Reply #19 on: March 28, 2008, 08:15 PM » |
nickao
Hi, Do you have a link or pic of that? I don't remember seeing a partial base except for the new OF2200 one. Seth
Dovetail65
Offline
« Reply #20 on: March 28, 2008, 08:22 PM » |
Seth I will have to dig it out. I am re-working the shop and everything is in about 100 boxes and I am slowly putting back everything back in its place one piece at a time.
I do know I have it, but my brother is saying he is not positive it was made by Festool, I thought it was. It snaps into the existing base and just adds thickness. As soon as I come across it I will post it. Its not in the router systainer, of course that would be to easy.
nickao
Forrest Anderson
Offline
« Reply #21 on: March 28, 2008, 08:42 PM » |
Do you happen to have the part number for that? I can only see the "Hard fiber base runner with reduced centering bore size, LA-OF 1400, Order No 492574":  ..and the "Table widener OF 1400. Comes with black chip catcher Order No 493233":  What I find particularly interesting is that after David posted his idea on the Sawmill Creek thread back in Oct 2006, Bob Marino said "I sent the link to the CEO of Festool last night, who liked it so much and is forwarding the suggestion to Festool Germany". 18 months later, and one of the accessories for the new OF 2200 router is the Guide Rail Base (part of the Guide Rail Adapter Set, which is itself part of the Base Accessory Kit). The supplementary Guide Rail Base clips on to the bottom of the router and has a 5mm thick "step" to compensate for the height of the guide rail. That, in addition to the availability of imperial template guides (is this the first time that a Festool power tool has been "Imperialised"?), indicates to me that Festool does indeed listen to its customers and implement their ideas. Forrest PS. I've just noticed that Seth and Nickao have been discussing this whilst I was busy writing the above!
« Last Edit: March 28, 2008, 08:46 PM by Forrest Anderson »
Daviddubya
Offline
Arizona, USA
« Reply #22 on: March 28, 2008, 09:54 PM » |
nickao
I have one of the Festool base plates. It is not quite as thick as the one I made, and the router does not sit perfectly flat on the work surface with the Festool base. You could make up the difference with a shim between the router base and the secondary base.
SRSemenza
Global Moderator
Offline
« Reply #23 on: March 28, 2008, 10:07 PM » |
nickao
I have one of the Festool base plates. It is not quite as thick as the one I made, and the router does not sit perfectly flat on the work surface with the Festool base. You could make up the difference with a shim between the router base and the secondary base. Hi, David is it 492 574? If not do you have pic? Seth
Dovetail65
Offline
« Reply #24 on: March 29, 2008, 12:10 AM » |
Yes guys, I believe the one on the top is what I have. Sounds like someone is due some residuals for the idea!
nickao
« Last Edit: March 29, 2008, 12:12 AM by nickao »
Daviddubya
Offline
Arizona, USA
« Reply #25 on: March 29, 2008, 01:10 AM » |
Yes, I have 492 574. There was a thread a while back about this same topic. The Festool secondary base for the OF1400 is 3 mm thick. The base I made is 5 mm thick. Here's the earlier thread: http://festoolownersgroup.com/index.php?topic=1900.msg19420#msg19420
« Last Edit: March 29, 2008, 01:16 AM by Daviddubya »
petiegolfer
Offline
Southampton UK
« Reply #26 on: April 03, 2008, 01:08 PM » |
A bit of a faff but cant you run the inside on the guide you are following and the outside on a second guide running parrallel to the first?
Piers
"3 Its the Magic Number!"
Daviddubya
Offline
Arizona, USA
« Reply #27 on: April 03, 2008, 04:16 PM » |
Piers
Yep - there are several ways to skin this cat. I prefer the secondary base because it provides excellent stability for the router and requires no additional setup. And I know the router is always flat on the work surface. Running the router with the base partially on the guide rail and using the outrigger foot also works well in many situations.
SRSemenza
Global Moderator
Offline
« Reply #28 on: April 03, 2008, 08:39 PM » |
Piers
Hi, Oh, no, no. That would be far too simple. Guess I will try that next time  Thanks. Seth
Chuck Wilson
Offline
« Reply #29 on: April 06, 2008, 10:20 AM » |
As I am a novice, I would like to know if the secondary plat was difficult to make? Any hints or directions that you could pass along?
Chuck
