Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2013, 11:29 PM
Home
Search
Login
Register
Festool Websites
Festool USA
Festool UK
Festool Canada
Festool Australia
Festool Netherlands
Festool Germany
Festool International
Product Websites
CMS Router Table
Cordless Drills
DOMINO Joiner
HEPA Dust Extractors
Jigsaws
Planex Drywall Sander
Rotex Sanders
SysLite Work Lamp
Track Saws
Woodworking & Power Tools Forum - Festool Owners Group
FESTOOL DISCUSSIONS
Festool Jigs & Tool Enhancements
Rail and stile jig
Pages: [
1
Go Down
« previous
next »
Print
Author
Topic: Rail and stile jig (Read 3632 times)
clintholeman
Offline
Sonoma County, CA
Rail and stile jig
on:
January 31, 2007, 03:27 PM »
Here are some pix of my rail and stile jig. I have 2 - the other I use for pieces less than 2 inches. It is very simple - it is made of MDF for the base and mostly plywood scraps for the alignment pieces and back support pieces. I'm a little embarrassed at how shoddy it looks - and, as I said it is very simple - takes about 10 minutes to make one.
The strips/pieces in back are there to support the FesTool rail. I think that is one of the keys to the jig - the gude rail is well supported.
The key is to make sure the base strip is accurately aligned and cutting the 2 inch [actually 51mm] pieces so they as exactly the width you want them - one for each end. Clamp on the guide rail - which is nicely supported and you're off to the races.
In use, the biggest problem is to make sure that no sawdust gets between the piece you are cutting and the butting strip - as usual, the FesTool system dust collection [my CT-22], works very well - but double check to make sure. Even a little can make a pretty big difference [ahh, yes, the voice of experience talking...].
Last Edit: January 31, 2007, 03:29 PM by clintholeman
Clint Holeman
clint@clintholeman.com
http://www.clintholeman.com
Jim Dailey
Offline
Re: Rail and stile jig
Reply #1 on:
January 31, 2007, 05:40 PM »
I like you jig & follow what you are doing except one "key" point...
Or as you said it "The key is to make sure the base strip is accurately aligned and cutting the 2 inch [actually 51mm] pieces so they as exactly the width you want them - one for each end. Clamp on the guide rail"
How do you align for repeat cuts...
Do you measure & mark the 1st piece & clamp the rail, thus the remaining pieces to be cut are slid under the clamped rail.
Or are you using a 2" gauge block to set & clamp the rail? After the initial set up, do you slide the piece in under the rail or use the block & clamp each time?
Thanks, jim
Life is just a series of projects...
clintholeman
Offline
Sonoma County, CA
Reply #2 on:
January 31, 2007, 06:49 PM »
<snip>
That's what I do - set up the first piece using the gauge blocks, cut, double check for accuracy, then start ripping for real. I loosen one of the clamps if I need to and recheck with the 2" gauge block, just to be sure. Usually, I don't need to do anything but slide the piece in.
Clint Holeman
Jim Dailey
Offline
Reply #3 on:
January 31, 2007, 07:00 PM »
Great tip Clint!!
"Thank You" That's a jig that will come in "handy"
jim
Pages: [
1
Go Up
Print
« previous
next »
Jump to:
Please select a destination:
FESTOOL DISCUSSIONS
=> Festool Tools & Accessories
=> Festool Tool Reviews
=> Festool How To...
=> Festool Tool Problems
=> Festool Jigs & Tool Enhancements
=> Festool Wish List
=> Festool and Tanos Systainers
=> Ask Festool
=> Sales & Dealer Area
=> Fun, Games, Diversions
GENERAL DISCUSSIONS
=> Member Projects
=> Other Tools & Accessories
=> Other Tool Reviews
=> Hand Tools
=> Building Materials
=> Finishing and Painting
=> Various Woodworking & Crafts Topics
=> Home Improvement & Other Projects
=> Member Connections
FORUM TECHNICAL
=> Gallery & Attaching Images
=> Forum Features & Functions
=> Forum Rules, Guidelines, & Suggestions
OFF-TOPIC
=> Computers, Gadgets, Technology
=> Photography
=> Sports & Recreation
=> General Friendly Chat
=> Classifieds
