Author Topic: Parf Guide mark 2 issues and questions  (Read 23243 times)
Offline ColossusX
Re: Parf Guide mark 2 issues and questions
« Reply #180 on: May 04, 2019, 08:28 PM »
Any idea when TSO or Axminster will get the Mk 2 back in stock?
Offline Jruks
« Reply #181 on: May 08, 2019, 10:29 AM »
Just got finished drilling about 200 holes (x2 if you count the 3mm) over the last 2 days... system works very well but darn I wish I had a Festool drill with removable chuck.
The stop collar shipping on mark 2 is still garbage. It stripped and fell off about 2/3 of the way through and I just had to keep the bit attached in my drill chick.
@TSO Products I bought from you guys but think you guys should go back to including your own steel stop collar if possible like you did with mark 1. The one included in aluminum is not durable at all over more than 1 MFT table worth of holes. The rest of the kit is solid though.
I haven’t tested the layout everywhere but checked a few spots across the table and seems good. There was only one column I found with a small rocking between 3 dogs. It wasn’t more than 1mm but I didn’t break out the deeer gauges to check. Other columns seemed fine so not sure what happened with that column but it’s not one I plan to use for cross cutting anyway. Will do more testing next weekend.
Overall very happy though.
Offline TSO Products
    • TSO Products
« Reply #182 on: May 08, 2019, 10:42 AM »
@Jruks – we really appreciate your comments about the Stop Collar. The Clamping Collar we have added for a time while AXMINSTER was still supplying the steel set screw version solved the problem. The cost to us was painfully high for two reasons: the high cost of supplying a US made Stainless Steel Clamping Collar, inbound shipping, receiving, then picking and opening the Parf Guide tubes to include the Clamping collar and an explanatory notice all added up. Before we could even overpack the PGS and return it to the warehouse shelf.
You can see how labor- and  transaction cost-intensive some harmless looking items actually turn out to be.
I will be in England later this month and meet with Axminster. I will take this matter up with them again. – thanks for your feedback!
Hans
TSOproducts.com
Offline Jruks
« Reply #183 on: May 08, 2019, 10:53 AM »
Totally get it. You guys went above and beyond on that one. Obviously the ideal would be for Axminster to include a better quality stop in the first place :).
Hans
    • TSO Products
« Reply #184 on: May 08, 2019, 11:58 AM »
@ColossusX  - According to Axminster they will be shipping our order next week. May 13 - 17. We are expecting to be able to deliver to customers May 24th.
Hans
TSOproducts.com
Offline ColossusX
« Reply #185 on: May 08, 2019, 11:38 PM »
Excellent.  Hope to place an order soon.
Offline mxn
« Reply #186 on: May 10, 2019, 04:05 AM »
Hello everybody,
I'm a quiet reader for some time now, this is my first post in this nice community. English is not my first language, but I think you get the point of what I'm trying to share  [wink].
I recently ordered the PGS Mk II after some trial and finally realizing I would not get the precision I was looking for with other methods (except a CNC which was not an option). I ordered from Axminster UK and got the package in under one week (UK to Germany). The sticks came with a silk print and unfortunately suffered from the issues some of you already mentioned: The sticks had a little curve showing a gap when placed side by side, when fixed in hole 1 and 6 the ends around hole 10 overlapped by about 0,5 mm and so on... A major problem I see with the line of holes not being parallel to the ruler's edge is that I can't get the first set of holes parallel to the benchtop's edge easily by positioning the ruler's edge - even if the hole would be perfectly in line...
I contacted the Axminster CS and got a quick and nice reply, a set of sticks that had been checked for accuracy had been shipped out to me free of charge.
The second set was indeed accurate, the holes seemed a little tight and I had to use quite some force to bring in the drill guide for the first times but for me that's ok and acceptable due to the tight tolerances. The second set had the embossed Logo in it. As far as I know from what I read, these should be the old ones, right? I could imagine that there's something wrong with the production line of the "new" sets, maybe that could even be the reason for the major stores being out of stock at the moment. However, I'm pleased with the result I now get with this set and do not regret buying it and - by the way - supporting Mr. Parfitt as the genius inventor!  [wink]
Another little thing I saw when I thought about a storing solution: The 25 mm head of the parf dogs fit the first gap under the drill guide bushing in the orange block but do not fit the second gap. Can anybody confirm this with his / her set?
Cheers, Max
Offline Mike Goetzke
« Reply #187 on: May 11, 2019, 11:48 AM »
@mxn Your rules appear to me to be the new ones.
"The 25 mm head of the parf dogs fit the first gap under the drill guide bushing in the orange block but do not fit the second gap. Can anybody confirm this with his / her set?"  Mine is like this too.
Mike
Offline Claimdude
« Reply #188 on: May 11, 2019, 09:09 PM »
Hans,
Would this stainless collar from Grainger work for those of us that didn't get in on the kits y'all sold with the updated collar?
https://www.grainger.com/product/RULAND-MANUFACTURING-316-Stainless-Steel-Shaft-30VK78
 Jack
Hans
    • TSO Products
« Reply #189 on: May 11, 2019, 10:05 PM »
Hans,
 Jack
YES, Jack - that is the Clamping Collar we have provided. Perhaps we should make it available for purchase. Wonder if there is enough interest to warrant the effort.
Any others interested?
Hans
TSOproducts.com
Offline jayshahu
« Reply #190 on: May 12, 2019, 08:03 PM »
axminister was out of the 20 mm drill bit till Thursday. They sent me a new one on friday. Waiting for it to arrive.
I seem to be having a run with bad luck. First the rulers, then the 20 mm drill bit shaft. I tried testing the bench dogs in the orange block and there is a little bit of a play . Once I get my drill bit I will drill a set of holes and see what happens.
This is crazy. I should have purchased from TSO. Though axminster has been great with regards to customer service but the shipping times are just too much.
Offline m. lindholm
« Reply #191 on: May 15, 2019, 10:51 AM »
Hans,
 Jack
Hans
I assume it merely looks similar, but isn't technically the actual one you got.  While the stainless clamping collar is an improvement over the aluminum setscrew one, it seems a disservice to choose a $32 part, versus a very similar, $12 one.  Including an item like that would certainly have explained some of the cost difference between you and ordering direct from Axminster.  [wink]
Kidding aside, even though I got the Mark II kit which now includes the clamping collar, the aluminum one got scratched and galled on its bottom surface after making my first top.  I had planned to order one of the stainless clamping collars (the $12 303-SS one, not the $32 316-SS one) to replace it, since I have a Grainger near where I eat lunch, so no shipping charge.
I think it's a reasonable idea to get a small quantity of the cheaper ones, and add them to your items.  Especially if a person doesn't have a Grainger nearby, adding that to a Parf guide order is a smart add-on idea.
« Reply #192 on: May 15, 2019, 11:33 AM »
Hans,
 Jack
Hans
Sorry but why is the aluminum stop collar not good. If it’s wear couldn’t we just add a $0.25 nylon wear washer in place of a $32 SS collar?
Offline tomp
« Reply #193 on: May 15, 2019, 12:00 PM »
Or, you could try something like this, shouldn't be too hard to open the bore up to 10mm
Nylon Split Collar
Offline jkc_WA
« Reply #194 on: May 16, 2019, 01:34 AM »
To follow up after having a chance to make a quick cutting station, I did a five cut test. I measured 0.934" at the top end, 0.928" at the bottom end. The offcut piece was 13 3/4" long (actually just shy, more like 13 47/64"). So it was 0.007" over 13.75". [0.007/13.75/4] gives an actual error of 0.00013 radians!
Offline jkc_WA
« Reply #195 on: May 16, 2019, 01:36 AM »
I just noticed my error in reporting 0.007 as the difference between .934 and .928. Should be 0.006 which would then yield an error of 0.00011 radians.
