Pages: [1]   Go Down
  Print
Author Topic: TS55 REBQ hose connector modification  (Read 2023 times)
promhandicam
Offline Offline
« on: May 02, 2012, 04:10 PM »
In comparison with my old TS55, the plastic connector for the dust extraction hose is very loose so that, unlike on my  old saw, you can't position it where you want it. When you connect a hose, the connector swings down so that the hose drags along the rail. Warren from Toolfest was good enough to confirm that this was also the case with other new saws and also confirm that his old TS55 was like mine in that the hose connector was quite a tight fit to the saw.
I therefore unscrewed the side panel - 5 torx screws -  and wrapped a turn of insulating tape round the plastic connector. It is a lot better but I think it might need a second turn.
Not sure if this is supposed to be an improvement but as far as I'm concerned it is a fault - albeit one that can easily be corrected.
Steve
jmbfestool
Online Online
« Reply #1 on: May 02, 2012, 05:07 PM »
No dont think it so much a fault.  It's  just something festool have not considered in their design  I think they should of made it tighter or a ratchet mechanism.
I did the same as you with both my saws TS55 and TS75  as it was winding me up massively that it kept rotating back down making my hose catch on the rail.   So much so I had to swear a few times heeehee
Jmb
Alan m
Offline Offline
« Reply #2 on: May 02, 2012, 05:38 PM »
very disapointing,
my ts55 does that sometimes (not always,got to do with where the vac is ) very anoying.
i would hate it if it did it all the time.
how do you find the rest of the new features.
congrates jmb on the 4000 posts
now
wish list
RvB
Offline Offline
« Reply #3 on: May 02, 2012, 05:40 PM »
My TS55 got the same issue.. Did the tapey thinghy to.. No biggy.. took like 2 nanoseconds..
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 -  FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
promhandicam
Offline Offline
« Reply #4 on: May 02, 2012, 05:56 PM »
. . . how do you find the rest of the new features. . . .
I'm happy enough with it - not a huge difference to the old TS55 although the dx is better. Can't say that the new depth adjuster makes that much difference - In fact I was ripping down some veneered mdf today - set it to 19mm and it left a ragged edge in places where the blade had obviously only just cut through the veneer. Possibly this was because I tend to use the saw one handed. I increased the depth to 21 and then problems - I cut onto an 8 x 4 sheet of celotex as a sacrificial support. Haven't yet had the need to cut to -1 degree or +47 degrees. At the end of the day it is a tool that does a very good job but not really worth upgrading unless you can get a good price on your old saw. I managed to sell my old one which was 8 years old - I'd had it for 4 - for more than I paid for it so it was a no brainer Big Grin
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #5 on: May 02, 2012, 05:58 PM »
When they get dirty, they tend to stop rotating freely. I had to take one apart and clean it to get it to rotate at all.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
jmbfestool
Online Online
« Reply #6 on: May 03, 2012, 05:02 PM »
very disapointing,
Cheers Alan!
Pages: [1]   Go Up
  Print
Jump to:
