Pages: [1]   Go Down
  Print
Author Topic: Pliable, lay flat hose?  (Read 2636 times)
Upscale
Offline Offline
« on: March 01, 2011, 06:37 AM »
Hello, I really do hate the hose that came with with my CT22 vacuum. What I'm looking for is a pliable, lay flat hose that doesn't automatically coil up when it's dropped on the floor. Has anyone found a 3rd party replacement hose that will lay flat in a straight line when placed on a flat surface?
« Last Edit: March 01, 2011, 06:39 AM by Upscale » Logged
DF 500 Q, HL850E-Plus, CT22, 5 systainers and several accessories. I'm just a rank Festool beginner, but I'm trying hard. Smiley Oh yeah, now that I own a FOG hat 2011 edition, I guess I'm not such a beginner anymore.
jonny round boy
Online Online
« Reply #1 on: March 01, 2011, 06:45 AM »
If, by 'lay flat' you mean what I think it means (i.e. the hose itself flattens) then that's not possible for a vacuum. Lay-flat hoses do not work with negative pressure as the vacuum would cause the hose to collapse & that would block the airflow.
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - T12 drill - PS420 jigsaw - OFK500 trimmer
Upscale
Offline Offline
« Reply #2 on: March 01, 2011, 07:15 AM »
Poor explanation on my part. I'm looking for a hose that doesn't automatically coil up when it's dropped on the ground. In other words, if I choose to lay it on some surface in a straight line, it will stay as placed.
Alex
Offline Offline
« Reply #3 on: March 01, 2011, 09:06 AM »
Give it some time, the hose will relax eventually.
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #4 on: March 01, 2011, 09:34 AM »
If it really bugs you, run a hair dryer through the hose for 15 minutes or so, then hang it over a door to cool.  End of problem.
 Smile
- Willy -
MFT/3 x2, TS 55, Guide Rails x5, Parallel Guide Set, CT 22 w/Boom Arm, CT Mini, RO 90, RO 125, ETS 125, RTS 400, RAS 115.04, C 12 + Centrotec Imperial Bits, CSX Set, TI 15, DF 500 Domino Set, SCG-10, Domino Plate from RonWen, MFK 700 Set, CMS-GE, OF 1010, OF 1400, OF 2200 Set, LR 32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, more "Stuff"-tainers...
worknfool
Offline Offline
If you can't use a hammer, it must be electrical.
« Reply #5 on: April 04, 2011, 10:52 AM »
Like the urethane air hose, vinyl garden hose, et al...just drag mine out and lay it in the sun to relax...all better. I feel your pain though. First time out'a the box was like being attacked by an anaconda every
 time I walked past.
Maybe it's time to start building Gibbets in front our rulers' castles? Perhaps they'd get the hint.
Pages: [1]   Go Up
  Print
Jump to:
