Pages: [1]   Go Down
  Print
Author Topic: Precision angle setting  (Read 1892 times)
Boatman
Retailer
Offline Offline
WWW
« on: February 28, 2012, 08:51 PM »
This topic came up on another forum so I thought I would elaborate on a new thread. I have dispensed with the miter head on my MFT and use a sine bar for setting angles.
A 12" caliper is needed as is a scientific calculator. I made my own sine bar using the calipers and it came out nicely. Not perfect, it is .001 off on length but that is of little consequence in wood working if you calculate the error. I can explain it's construction if needed. The reality is it doesnt matter what the length is as long as it is known. 10" is a good size, the math is easy ( you just move a decimal) all the gauge blocks can be made within the limits of the calipers and it doesn't take up a lot of room on the table or storage.
The other thing I did was to make a dog to use as a pivot for the fence, and set up my MFT with a near permanent fence set far back ( thanks Paul ).
So to set an angle, for this example I used 26 degrees. The dog is installed and the fence is dropped over the pivot. 26 is entered into the calculator and the sine function is entered and the result is .43837 etc. Move the decimal one place to the right and you get 4.3837 now dial that into the calipers. If it is a one time angle cut you can use the inside jaws of the caliper to angle the sine bar slide the works over to the fence till everything is snug and lock the fence down. You are now ready to cut 26 degees.
If this will be an angle you will use again or want to start a library of blocks for the future it is real easy to cut them to length with the calipers. Set the stop on the miter bar larger than the piece needs to be. Use the inside jaws of the caliper to space off a scrap piece to be cut.
Use that freshly cut piece as a new spacer and slide it next to the stop.
One last cut and if you miter bar has minimal slop you will have a piece of wood that is 4.384". Label it for 26 degrees and you will have a permanent, repeatable reference.
Hope this makes sense. Let me know if you need more info.
Jim
« Last Edit: December 08, 2012, 07:09 PM by Boatman » Logged
Check Out My Website:
http://ancorayachtservice.com/
NEW2FES
Offline Offline
« Reply #1 on: February 28, 2012, 11:36 PM »
Impressive to ay the least. That is some seriously accurate cuts.
One question, why do all the set up for mitering on the MFT moving the wood to obtain the angle rather then moving the fence (guide rail)? I know the fence is dedicated on the MFT but since we are modifying anyway?
Doesn't moving the guide rail (fence) vs moving the wood give more cutting capacity on the MFT like a miter saw does? Moving the wood almost always results in the wood hanging off of the MFT VS being supported by the top??
Boatman
Retailer
Offline Offline
WWW
« Reply #2 on: February 28, 2012, 11:49 PM »
If you move the rail the top really gets cut up. If the cut I need to make doesn't fit on the table set up very well I can still use the sine bar to set the bevel guide and use a free rail. I really like knowing that the table and rail are always set at 90 degrees.
greg mann
Offline Offline
« Reply #3 on: February 29, 2012, 02:22 PM »
Being a toolmaker I get the idea of using a sine bar but I think the real genius here is your pivoting fence. That strikes me as a game changer. It is pretty easy to verify the perpindicularity of you MFT fence to the rail, but once you move the MFT fence for setting an angle in a more traditional manner you cannot reference back to verify your original settings. You would need to do the sine bar between the MFT fence and the guiderail then re-establish your original square setting for other work. With this setup you can easily re-create your angular cuts exactly while never needing to disturb your original square set-up. Very cool, and I just happen to be the proud owner of my late stepfather's 10 inch sine bar, which I have kept for sentimental reasons but did not figure to ever use in my woodworking. Thank You.
Greg Mann
Oakland, Michigan
PaulMarcel
Offline Offline
WWW
« Reply #4 on: February 29, 2012, 05:12 PM »
Thanks for posting more details, boatman!  Like Greg, I love your use of the pivoting fence to do the setup.  I'll have to play with this someday.
Shirt size: L Cool
Twitter: @HalfInchShy
Pages: [1]   Go Up
  Print
Jump to:
