Pages: [1]   Go Down
  Print
Author Topic: Small Improvement to CT Dust Collection (Retention)  (Read 1649 times)
ccmviking
Offline Offline
WWW
« on: April 10, 2011, 08:00 PM »
    This is something that has bugged me for quite some time but until just recently I put up with it.  I'm sure a lot of you have experienced dumping dust out of the hose when unhooking the hose from the dust collector.  IMO the hose end on the 27mm needs a slight modification by Festool to eliminate this issue but it's something you can make some improvement to after just a few minutes.  I got in the habit of putting the vac in manual and pulling the hose loose but keeping it near the vac suction and tapping it onto the ct to break the dust loose and let it get sucked into the vac.
    You should be able to see from the pics below that the issue is with the 27mm hose end there is a pretty large recessed area that just attacts and retains the dust.  When you cut panels such as MDF (just one cut) this area will fill up and fall out of the hose once you disconnect it.  I just used some 5 minute west system expoxy to fill that gap and most of the problem is gone.  The 36mm hose does not have this recess so nothing mentionable collects on the 36mm hose connection.  There is still a dead zone created because the hose is so much small than the fitting and ideally this should be tapered from the small hose to the big outlet and no dust would collect.
    Just a simple quick mod to prevent some of this stuff from getting on the ground...
RvB
Offline Offline
« Reply #1 on: April 11, 2011, 02:58 AM »
nice improvement!
does it allow to swiffle the hose?
Rick
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 -  FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
Corwin
Offline Offline
« Reply #2 on: April 11, 2011, 03:41 AM »
nice improvement!
Rick
Good question.  This modification will still allow the fitting to swivel.  If you ever take apart one of these fittings, you will see it is made up of three parts;  a retaining ring, an inner sleeve and the adapter -- as shown in the photo below.  The recess that is being filled in this modification is within the adapter and filling that recess will not glue it to these other parts.
Note:  this photo is of the larger D36 hose and fitting, but the parts are similar other than size and, of course, the recess in the smaller D27 adapter that is the topic of this thread.  Heh, heh.   Wink
« Last Edit: April 11, 2011, 03:52 AM by Corwin » Logged
Shirt Size:  L
LostInTheWood
Offline Offline
« Reply #3 on: April 20, 2011, 10:36 PM »
Was about to make another thread, but saw this and figured I would add since this was a problem for me too.   My approach was a little different.  I wanted to seamlessly connect the 36 hose to my 27 without using the adapter (and without buying it).   I went and bought a 1-1/4 schedule 40 pvc coupling and bored out one end to slip/press fit into the 27 hose end.  The other end of the coupling was bored to fit the tool end of my 36 hose.  It also helps with the dust that builds up in that "dead zone."
Pages: [1]   Go Up
  Print
Jump to:
