Author Topic: Right Angle Adapter for Domino 500 & Domino 700 XL  (Read 16950 times)
Offline Birdhunter
« Reply #30 on: June 09, 2019, 06:09 AM »
Hans,
Are there 2 Bigfoot models (500 and 700 model) or does the Bigfoot fit both Dominos?
Birdhunter
Offline TSO Products
    • TSO Products
« Reply #31 on: June 09, 2019, 07:56 AM »
Hans,
-YES, the DBF-45 fits both 500 and 700 Domino machines.
Hans
TSOproducts.com
Online Cheese
« Reply #32 on: June 09, 2019, 11:40 AM »
And of significant importance to some people, it will still fit inside the DF 500 Systainer along with a Seneca Domiplate. Everything in one location.  [smile]
Offline rmhinden
« Reply #33 on: June 09, 2019, 12:20 PM »
It also fits very well in the XL systainer.
Bob
Offline rmhinden
« Reply #34 on: June 09, 2019, 12:27 PM »
Here are a few more pictures of it in use with my XL.   Also, including it in a Ramon domino dock I made based on his plans.
As you can tell, I like it.
Bob
Online Cheese
« Reply #35 on: June 12, 2019, 09:18 AM »
Bob
Even if the Domino containers are full, there's still enough room for the BigFoot.
Offline rmhinden
« Reply #36 on: June 12, 2019, 07:28 PM »
Many choices :-)
That's where I keep my DIY right angle adapter.
298999-0
Unfortunately my Ramon domino dock doesn't fit in the systainer :-(
299001-1
Bob
Offline TSO_Products
    • TSO Products LLC
« Reply #37 on: June 12, 2019, 07:30 PM »
-well with that much in the DF 700 Systainer, we should come up with another attachment to fill that space [wink]
Actually we are listening for customer feedback and suggestions for refinements.
and thanks for all the pictures being posted!
Hans
Online Cheese
« Reply #38 on: June 12, 2019, 11:13 PM »
Bob, I was interested in that 700 dock a couple of days ago...just have not had the opportunity to question you about it.
I’m very curious about your thoughts on it and would welcome your review.
For some reason I like it yet for some reason I’m still trying to identify a typical application.
The 700 is kind of klunky compared to the 500 so your thoughts are important.
Offline blaszcsj
Re: Right Angle Adapter for Domino 500 & Domino 700 XL
« Reply #39 on: June 13, 2019, 12:47 PM »
The domino dock is simply a means to take the workpiece to the machine. It makes quick work of rail and styles or other small part repeated mortises. The main reason is because you do not really have to deal with multiple clamps. Sennca Just came out with an accessory that is similar to the rail/style attachment, but allows for larger capacity.
https://www.senecawoodworking.com/products/dock-plate-xl
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Online Cheese
« Reply #40 on: June 13, 2019, 01:24 PM »
Thanks for the explanation and the Seneca link. I didn't know the dock plate even existed. I can see for small items this could save a lot of time and it's probably just plain easier to deal with.  [smile]
Offline rmhinden
« Reply #41 on: June 13, 2019, 01:51 PM »
The dock plate was just released, I first saw it on Instagram yesterday.
I think that for smaller pieces, it's much easier to bring the wood to the domino XL than the other way around.   I use this approach with the TSO Big Foot or my own right angle adapter when I need more support horizontally.   I can clamp the wood to the right angle adapter.  This combination also works well with the Seneca "Domi-Shims" for imperial stock.
Bob
Offline Mike Goetzke
« Reply #42 on: June 13, 2019, 02:59 PM »
That Seneca jig is like the shop made one I posted here November of 2015  [eek].
Offline ChuckM
« Reply #43 on: June 13, 2019, 04:15 PM »
Snip.
Tracked own this, but the image is no longer there:
http://festoolownersgroup.com/festool-how-to/how-to-mortise-12'-stock-with-trim-stop/msg429433/#msg429433
« Reply #44 on: June 13, 2019, 04:23 PM »
Snip.
Yeah - PhotoBucket, I refused to pay them. I'll see if I can dig up the photos and re-post them.
Found the photo. I had around 60 crib slats that were approximately 1/2" thick x 1-1/2" wide to put Domino mortises in both ends. I attached the Seneca 1/2" plate and made two blocks to center the slats. Worked like a charm. The Seneca looks like it can handle much wider boards (and looks much nicer):
« Last Edit: June 14, 2019, 08:28 PM by Mike Goetzke »
