Pages: [1]   Go Down
  Print
Author Topic: Rolling Workbench; Systainer-Port; Tablesaw and Router  (Read 13477 times)
Arnd
Offline Offline
« on: April 05, 2011, 11:59 AM »
Hello,
I have got a small room for working with handtools in the house. For all the dusty work with machines, I use the garage.
And for that garage I builded a workbench. I have incorporated a circular saw, a stationary router and a lot of storage space for Systainer. So all my machines are good accessible. The bench has got wheels so that I can push it to the sidewall. It is enough room for the car then and it looks tidy.
I planned the project with SkechUp.
Characteristics:
  • Size: 248 cm x 125 cm Table height: 100 cm
  • 19 drawers for 29 Systainer
  • Carpenters Vise No. 53ED
  • 25 holes for the Veritas clamping elements
Material list:
  • about 4 plywood sheets 30×250 x 125 (gross € 26.24 / m²)
  • various pieces of scrap wood
  • 250 screws 5×80
  • several other screws
  • 300 wooden dowels
  • joinery vise. 53ED (134 € http://www.feinewerkzeuge.de/schraub.htm)
  • 4 x heavy duty wheels (used for 75 €)
  • 19 x full extension drawer (some for free from old desks (value: about 300 €), some drawer slides from ebay (50 €))
  • router fence (€ 100)
Costs
  • Material costs over all: 800 €
  • Time: 75 h
Here is the result:
The Base
The plates I have cut with the circular saw and guide rail.
The connections are made ​​with wooden dowels. For this I used the Mafell DuoDowel.
After seeing the examples by Roland Heilmann, I finally understood how to use the dowel template of DuoDowel.
90 holes in 45 minutes and with 12 measuring points on the surface.
And here I start with the first intermediate wall – with no marking.
Logically, I drilled the holes for the drawer extracts before the assembly. Thus, then 46 holes in a board.
But finally I was able to start assembly. I started by mounting the wheels and the longitudinal bars under the bottom plate:
The project is taking shape:
I started to get nervous.  Unsure Will fit all? Have I not made ​​a little too much? But then all the walls were bolted together. Phew!
But the tension wasn’t over yet!  Huh? OK, the walls fit. But was my work also accurate enough that the walls are exactly over the 72 dowel holes in the bottom plate?
Yes!  Big Grin With a heavy hammer from above and the attractive effect of Spax screws from the bottom all the plugs went into their holes. To screw I put the bench on its side. That was probably the last time I saw the bottom.
Setting up the work surface was no longer difficult. But first I had space for the saw to cut and drill the hole for the router.
The Router
My old table saw has robbed me of my index finger tip and some nerve. Therefore, it was a pleasure for me to discard it. The height adjustment and the safety switch I wanted to use for a router table.
SYSTAINER drawers
For the mark of the holes on the side walls I’ve made ​​a template out of plexiglass:
It I was surprised how many single wood for the drawers are needed. The good thing is that now there is room in the residual wood shelf again.
Another compartment is ready:
Here we see the working side moved out completely. The table does not wobble at all.
And here is the other side is extended:
Also the rear Systainer are in full access:
In addition to the vise handtools, cordless screwdrivers and bits are located. The drawer with the bits opens most often:
Thanks for looking. I hope someone else can learn form me as I learnd form others on the internet. Wink
Arnd
Frank Pellow
Offline Offline
Toronto, Ontario, CANADA
« Reply #1 on: April 05, 2011, 12:30 PM »
I very much like your design and you have done a good job dexcribing and showing how you built the unit.  Well done!  Thumbs Up
« Last Edit: April 05, 2011, 12:34 PM by Frank Pellow » Logged
Cheers,
               Frank (Festool connoisseur)
Frank Pellow
Offline Offline
« Reply #2 on: April 05, 2011, 12:32 PM »
Oh yes, I forgot in my post above -welcome to the Festool Owners Group forum. Welcome!
Cheers,
tjbier
Offline Offline
« Reply #3 on: April 05, 2011, 12:49 PM »
Arnd, welcome to FOG!
That is a fantastic piece.
I really like the design and layout, well done.  Thumbs Up
Oh, and thank you for rubbing in the Centrotec sys kit ....
Tom- ps, I read these.
jonny round boy
Offline Offline
« Reply #4 on: April 05, 2011, 01:07 PM »
Arnd,
I don't think there is a prize for the best first post, but if there was you would win it!
Well done, and welcome!!! Big Grin
skinee
Offline Offline
« Reply #5 on: April 05, 2011, 02:57 PM »
Arnd,fantastic project,is that a thien type cyclone separator you have connected to your extractor?,can you post some construction details and photos please
Mac
Offline Offline
A Scotsman living abroad
« Reply #6 on: April 05, 2011, 03:01 PM »
Excellent first post, and welcome.  I like this a lot, I'm thinking of ripping it off being inspired to do something slightly similar  Thumbs Up
Cheers,
Rick
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #7 on: April 05, 2011, 03:36 PM »
Arnd,
Great idea JRB!  And you are right, Arnd would win hands down.  I think Arnd is already in the Festool Hall of Fame.  Can't wait to see his next thread.
Shane, 'Best first post' would be an interesting contest!
Les Spencer
Offline Offline
« Reply #8 on: April 05, 2011, 03:56 PM »
Great design and work. Ingenious use of the table saw mechanism. Welcome to FOG. Big Grin
Les (near Indy) XL
Rob Z
Offline Offline
Contractor-Northern VA, USA
« Reply #9 on: April 05, 2011, 10:17 PM »
Arnd, well-done!  I could use something like that in my garage.   How many man-hours would you say you had in the construction of that?   And bonus points for using the old-fashioned brace and bit!
Edited...I see the total hours were 75.   And 800 euros seems like a reasonable amount to spend to get such a useful bench in shop.
« Last Edit: April 05, 2011, 10:20 PM by Rob Z » Logged
Delco
Offline Offline
« Reply #10 on: April 05, 2011, 10:38 PM »
Nice Arnd,
     I could see the German design and workmanship skills before I saw where you were from.
Very nice,
Dave
Sal LiVecchi
Online Online
« Reply #11 on: April 07, 2011, 03:52 PM »
What a fantastic first post and project. The design and layout are great. The workmanship even better.
Welcome to FOG and keep up the awesome work
Life is too short and the road is too long to drive anything less than a Festool
Alan m
Offline Offline
« Reply #12 on: April 07, 2011, 06:18 PM »
in the first sketch up drawing . what is the thing above the sideways sys4 in the farthest away opening.
great work surface. i wish i had a large enough shop to put some thing that large in
now
wish list
chayu
Offline Offline
« Reply #13 on: April 09, 2011, 06:08 PM »
awesome design
i just wish i could get a small table saw with a sweet slider like you have in the states
Arnd
Offline Offline
« Reply #14 on: April 13, 2011, 03:01 AM »
It's a paper roll. You can see it also on one of the real photos.
Alan m
Offline Offline
« Reply #15 on: April 13, 2011, 03:52 AM »
thank. even in the rel pics you wouldnt know for sure what it was
now
wish list
William Herrold
Offline Offline
"failure is imminent"
« Reply #16 on: April 13, 2011, 04:43 AM »
Great post! Who is the manufacturer of the small table saw? the colors look like Wolfkraft, but I haven't seen that in their catalog. And the rip fence? is that an extra?
"I don't believe anything, but I have a lot of suspicions"
 R.A.W.
Arnd
Offline Offline
« Reply #17 on: April 13, 2011, 05:55 AM »
The saw is from Kity, it is a Circular Saw 419. It is produced in france. The factory belongs to the german Schleppach Comany.
http://www.scheppach.com/no_cache/en/products/products-overview/categories/tischkreissaegen-3.html
Here is an other discription: http://www.kityuk.net/419saw.html
Chris Has Flair
Offline Offline
I make sculptural furniture.
WWW
« Reply #18 on: April 13, 2011, 01:43 PM »
Nice workstation!  But the real challenge will be keeping the top clear!
Chris Wong
http://FlairWoodworks.com
http://TimeWarpToolWorks.com
If it bothers you that the chair [you are building] is askew, just go to you local furniture store and look at chairs until you feel better. – Brian Boggs
Steve R
Offline Offline
« Reply #19 on: April 13, 2011, 11:53 PM »
What a wonderful post!
Great explanation of what you wanted and what you ended up with.
The steps you show and detail are wonderful and educational.
I would like to know what drawer hardware you used.
Dang you did great job on so many levels! design, documenting, photographing, posting....    Not Worthy
Keep up the good work!!!
Cheers,
Steve
Wonderwino
Offline Offline
« Reply #20 on: April 15, 2011, 01:37 PM »
Great design - it looks really stout!  Do you need a power tug to roll it around?   Big Grin
Water separates the people of the world; wine unites them.
jussi
Offline Offline
« Reply #21 on: September 07, 2011, 05:14 PM »
Nice design.  Just curious though.  I recognize the Mafell and Festool but what brand are blue/purple systainers?
Alex
Online Online
« Reply #22 on: September 07, 2011, 05:34 PM »
Tanos. Sister company of Festool. They make the systainers for Festool. And other brands.
Pages: [1]   Go Up
  Print
Jump to:
