Author Topic: Ron Paulk relief cut out template set up for MFT systems  (Read 1328 times)
Offline Mgildersleeve
« on: January 12, 2018, 08:21 PM »
Here’s a video of a jig setup to make the cut outs for Ron Pailk’s table top system. This seems like a staple item for MFT systems, as it allows a user to reach in and clamp down threaded bench dogs. A necessity for using a hole system.
Online Scorpion
Re: Ron Paulk relief cut out template set up for MFT systems
« Reply #1 on: January 13, 2018, 09:36 PM »
That’s cool.  Thanks for sharing.
Sent from my iPhone using Tapatalk Pro
Online pettyconstruction
« Reply #2 on: January 13, 2018, 10:26 PM »
That’s a cool jig. I have recently been building my own paulk total station and had some less than desirable results on my template routing
My question to you though is why not reverse that and make the template the size of the hole then you don’t have to keep moving it? Or is that template built for a different application
Thanks Charlie
Offline bkharman
« Reply #3 on: January 13, 2018, 11:46 PM »
Thanks Charlie
This allows for all sorts of sized “ovals”. They can be the size of the template or much larger if needed. I like it, but not the clamping setup.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
