Author Topic: 1. Routing a channel for LED lights using the MFS  (Read 1335 times)
Midnight Man and 1 Guest are viewing this topic.
« on: April 14, 2019, 10:37 AM »
I'm building some cabinets that will be placed in the knee wall of the loft. Each drawer will have LED lights recessed into a tie-bar above them. The lighting is controlled with micro switches so they'll activate automatically when the drawers are opened & closed.
The real issue is that because these cabinets will be over 10' long, I need to route out 20 tie-bars. That's definitely not a job for clamping and then unclamping the MFS. The tie-bars need to be loaded into a fixture, one at a time, indexed, routed, removed and then a new tie-bar loaded again. This fixture will also allow each tie-bar to be identical to each other and will dramatically speed up the process.
I've used a similar method in the past for producing multiples of HVAC vents and it works really well. The method centers around drilling holes in the MFS  [eek] [eek]  and screwing it to an indexing board. This indexing board will have 2 each 8mm dowels poking out the front and the tie-bars will have corresponding 8mm mortices for the new D8 knock down Dominos.
One end of the tie-bar will be open while the other end needs to turn 90º to allow the wiring to exit. The width of the slot is critical because a plastic lens will be snapped in place to protect the LED's and to more evenly diffuse the light. The 90º turn also necessitated a wooden spacer be designed & installed in the MFS.
Here's a photo of each end of the tie-bar.
The indexing board is a scrap piece of 18mm BB ply, the same material as the tie-bars. It uses 2 Dominos that have had one end smoothed and radiused with sandpaper to more easily engage the tie-bar.
Here the tie-bar is being engaged with the indexing board and then clamped in place.
The MFS has been set to the proper size and is placed on the indexing board. I used gauge blocks to properly place the MFS as they are more accurate than pencil lines and faster.
Two #9 GRK screws hold the MFS in place.
Another plus with this setup is that once the MFS is attached, the entire assembly can be moved around and the registration is never lost. If you suddenly need the bench for another job, just pull the assembly and move it.
This shows the underside of the MFS and indexing board because I needed the bench for something else.
« Last Edit: April 14, 2019, 11:29 AM by Cheese »
2. Routing a channel for LED lights using the MFS
« Reply #1 on: April 14, 2019, 12:01 PM »
The 90º turn necessitated that I hang the MFS off of the indexing board. Consequently, I had to fabricate a spacer strip that would allow the 90º turn to be made and that would be captured snuggly within the MFS slot. I again used 18mm BB sliced down to 16mm thickness, the thickness of the MFS, with a dado routed on each side.
The spacer strip is in place on the 90º turn end.
Now's where the fun comes in. The assembly awaits the arrival of the first tie-bar.
Each tie-bar is loaded from the RH side of the assembly.
Slid into place until the Domino engages with the mortise.
It's then pushed forward to engage the indexing board fully.
The middle clamp is tightened to force everything against the Woodpecker dogs and then the routing begins.
Here's a photo of the slot with the 90º turn.
Once the slot is routed the clamp is released, the tie-bar is disengaged and pushed to the right to be unloaded. Pretty simple & pretty quick.
Offline Slowlearner
Re: 1. Routing a channel for LED lights using the MFS
« Reply #2 on: April 14, 2019, 12:06 PM »
Awesome. Great what led lights are you using? I just recently something like this and i am going to copy it.
3. Routing a channel for LED lights using the MFS
« Reply #3 on: April 14, 2019, 12:21 PM »
Here the tie-bar has been removed and you can see the completed item with views of both ends. Once set up, the whole process takes only 3-4 minutes for each tie-bar.
Now it's time to start attaching the LED's to the tie-bars.
Online mike_aa
« Reply #4 on: April 14, 2019, 12:54 PM »
@Cheese
You are a true MFS Wizard!  Love your setups!  Great work.
Where did you source the plastic channels and the LED strips?  Did the LED's come off a roll?
Thanks, Mike A.
Offline TSO Products
    • TSO Products
« Reply #5 on: April 14, 2019, 01:38 PM »
@Cheese
Thanks, Mike A.
Hey Nick, your thread is a "keeper" for reference when I get to the LED strip design and installation in my long wife's long awaited display case.  So I am, like Mike in Cleveland, waiting for more details from you.
The whole approach of fixturing is a vast area of opportunity for woodworking and one newer woodworkers especially benefit from taking a closer look. There's more than power- and hand tools to productive and fun (!) woodworking.
keep it coming!
Hans
TSOproducts.com
Home of the GRS-16 and GRS-16 PE  plus TPG Parallel Guide -  the MTR-18 Triangle and Work Holding solutions plus AXMINSTER UJK in the USA
« Reply #6 on: April 14, 2019, 02:15 PM »
Hey @Slowlearner and @mike_aa
I usually use Diode LED light strips because I've had really good luck with their products. Their Ultra Blaze product is great for under counter task lighting in kitchens. It's very bright and the color is extremely uniform.
For this project I needed 50' of LEDs which would have cost about $650 including sales tax if I purchased the Diode LED offering.  [eek]
Considering that these LEDs will be on for only minutes in a day because the slides are Blumotion self-closing slides, I decided to cheap out. I purchased 3 each of these 5 meter rolls from Lighting Ever for $36 including shipping.  [big grin]  They use the 2835 SMD device so they're quite bright and they burn at 4100K. The part number is 4100057-DW and they're still rated for 25,000 hours. So that basically equals FOREVER. [big grin]
The covers are from Diode LED and come clear or frosted. They're available in 4' or 8' lengths. A frosted 4 footer costs $8.
The only negative thing about the Lighting Ever LEDs is that the connectors are rather cheap/funky with intermittent connections. I decided to solder the wire leads directly to the LED strip and that solved the problem.
Interestingly enough, I've also had some issues with the Diode LED connectors so I'll be removing those and directly soldering the wire leads to those also.
Here's what they look like when I fired one up last night.
« Last Edit: April 14, 2019, 02:19 PM by Cheese »
« Reply #7 on: April 14, 2019, 02:28 PM »
Thanks Hans... [big grin] ...stay tuned and tonight or tomorrow, I'll post some more photos on installing the LEDs into the tie-bars. The covers really make for a very slick installation. They'd look super in a display case. You just have to get the groove width correct because they have short legs and are a friction fit.
You can see how uniform the light pattern is when you install the frosted cover.
Offline ScotF
« Reply #8 on: April 14, 2019, 02:33 PM »
Very cool! Thanks for the pics and details!!
Offline Sparktrician
« Reply #9 on: April 14, 2019, 03:30 PM »
@Cheese, that's really a sweet job!!!   [smile]
- Willy -
Offline RKA
« Reply #10 on: April 14, 2019, 06:25 PM »
This is exactly what I want to do with a cabinet for my wife.  Ideally two doors each with a microswitch that can turn on a 20” or so light strip.  Looking forward to more updates!  Thank you!
-Raj
Offline ear3
« Reply #11 on: April 14, 2019, 08:11 PM »
Great work!
4. Routing a channel for LED lights using the MFS
« Reply #12 on: April 15, 2019, 10:33 AM »
Thanks to everyone for the comments.  [big grin]   I am rather surprised about the amount of interest this post generated.  [cool]
I was originally going to get into the assembly of the LEDs into the tie-bar in this thread, but I think I'll start a new thread because there is so much more information I've come across on installing and working with LEDs over the last 15 years.
So wrapping this up, here's a photo of the LE strip LEDs mounted on a heatsink and fastened to the tie-bar recess using 4 each #4 screws.
The Diode LED frosted cover is then press fit into place.
Here's an end shot of the cover pressed in-place. You can see the short legs that retain the cover. I machined the slot to .670" +/- .005" by .150" deep. I needed to stay at .150" deep because of the proximity of the 6mm Domino. I'd prefer the slot to be .200" deep instead.
Here are 9 of the 16 tie-bars finished. So 16 tie-bars plus 4 tops will yield 4 cabinets with 5 drawers each with full illumination.  [big grin]
As I mentioned earlier, the cabinets will be located in a knee wall in the upstairs loft.
Here's a shot of 1 cabinet assembled but without the trim or the drawer fronts.
And here's what the lighting will look like at night.
5. Routing a channel for LED lights using the MFS
« Reply #13 on: April 15, 2019, 11:24 AM »
One more item, when doing repetitive work like this it's very important to organize and align all of the products you're working on. Arrange them in order with the proper side up and the proper edges out. Then you can simply take the item, put it in your fixture and perform the work without having to think about it.
Here's a great example of not following my own instructions.  [doh]
I needed to machine mortises for a 6mm Domino at the +6mm setting. The center of the mortise had to be 10mm from the bottom of the tie-bar to avoid interfering with the channel for the LEDs. Here's a photo of the correct orientation. Notice the close proximity to the LED channel.
And this is the result when 1 of the pieces in the stack isn't oriented properly. If I had not caught this and routed the channel, it would have gone right through the 6mm +6mm mortise. I had to slice a couple of 6mm Dominos in half to remedy the problem.
Offline blaszcsj
Re: 5. Routing a channel for LED lights using the MFS
« Reply #14 on: April 15, 2019, 11:47 AM »
Nice work on the repair. Going to have to remember that one.
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline travisj
« Reply #15 on: April 15, 2019, 11:59 AM »
Nice work!
    • TSO Products
« Reply #16 on: April 15, 2019, 12:53 PM »
@Cheese  - sometimes it pays with smaller, complex set-up parts to make a few extra in anticipation of a machining defect later. Saves the pain of starting another set-up from scratch for a replacement part you hope matches the initial set up dimensions.
My good judgement in these matters comes from my bad experiences in these matters  [sad]
Nick, your "recovery" Domino is a crafty demonstration of your resourcefulness and skill!
Hans
TSOproducts.com
« Reply #17 on: April 15, 2019, 01:05 PM »
That's funny Hans...
