Author Topic: Routing Boxes and Furniture Handles  (Read 2051 times)
Offline clark_fork
« on: August 31, 2018, 09:24 PM »
Festool puts out No. 202: instructions for using a template for hand holes.
https://festoolcdn.azureedge.net/productmedia/Images/attachment/ae7918a1-e75f-11e4-80ca-005056b31774.pdf
The instructions mention a router bit for handles
FESTOOL HW S8 R16/NL32 (Hand hole cutter HW shank 8mm
I can't seem to locate a NA source.
Any thoughts?
Clark Fork
"A lot of people are afraid of heights. Not me, I'm afraid of widths."  Stephen Wright
"straight, smooth and square" Mr. Russell, first day high school shop class-1954
" What's the good of it?" My Sainted Grandmother
"You can't be too rich, too thin or have too many clamps." After my introduction to pocket joinery and now the MFT work process
"Don't make something unless it is both made necessary and useful; but if it is both necessary and useful,
don't hesitate to make it beautiful." -- Shaker dictum
Offline Alanbach
Re: Routing Boxes and Furniture Handles
« Reply #1 on: August 31, 2018, 10:14 PM »
Offline Gregor
« Reply #3 on: September 01, 2018, 08:21 AM »
From the linked Festool 202:
Quote
Set the routing depth. When doing this, ensure that the distance from the cutter tip to the middle of the radius is 19 mm. This dimension is important because the routing depth t is calculated as follows.
I'm no native speaker, but these sentences don't make any sense to me.
The second because what should it tell me (don't use another router bit?), the last as the word 'depth' can't be found anywhere else in the pamphlet and nothing follows regarding any calculation.
@SRSemenza could someone at Festool look at this to release a version that's making sense?
Offline Bohdan
« Reply #4 on: September 01, 2018, 08:31 AM »
@Gregor I agree that the statement makes no sense. But that is because the rest of the example showing the calculation for t is missing.
Offline SRSemenza
« Reply #5 on: September 01, 2018, 10:22 AM »
I don't know anything about the instructions. But if the question is whether or not the router bit is available in North America from Festool?  It is not. The router bit line was dropped from NA quite a few years ago. With the exception of a few particular bits.
I am guessing you can get a bit to do that job from another maker. Maybe a dealer still has one.
