Author Topic: Sacrificial Fences CNC made and drawings  (Read 3705 times)
Offline MKintrup
« on: February 12, 2018, 10:19 AM »
Hello,
this is my first post here and I want to share my drawings of sacrificial fences for the kapex 120.
the drawing is in the svg-format with 72 dpi. The drawings are made to cnc the fences instead of building them by hand.
I made the fences using 6.5mm birch plywood und used M4 washers between the lower fence and the kapex to raise it to 7,5mm thickness. Works very fine. The drawing is quite precise as you can see from behind. I used M6 countersink screws, washers from the backside and big round nuts which can easily used without tools to dismount the rear fences. The fit exactly inside the green levers of the two back fences.
Hope, someone can use this to cnc his own, without creating the drawing, which was not as easy as I estimated before.
Best wishes from Bochum / germany
martin
Offline Mario Turcot
Re: Sacrificial Fences CNC made and drawings
« Reply #1 on: February 12, 2018, 10:34 AM »
Martin, this is pretty sweet. Any link for the svg file? I'd like to give it a try.
Mario
Offline MKintrup
« Reply #2 on: February 12, 2018, 11:25 AM »
Hello Mario, thank you I will try that later today.
martin
Offline rumble-chicken
« Reply #3 on: February 12, 2018, 11:52 AM »
Looks good,  thanks for sharing.  Will definitely give it a try if you get a chance to post the file.
Offline MKintrup
« Reply #4 on: February 12, 2018, 12:27 PM »
I hope this works:
SVG File with 72DPI
right click and save file
martin
Offline MKintrup
« Reply #5 on: February 12, 2018, 12:30 PM »
the rear fences are a bit long, my plan was to cut them  bit shorter from time to time, so I always have zero clearance without adjusting so close. But you only need to cut twice to make them as short as you want by the kapex itself ;)
« Reply #6 on: February 12, 2018, 01:44 PM »
Danke!  [big grin]
Mario
Offline MKintrup
« Reply #7 on: February 12, 2018, 02:05 PM »
Sehr gerne... you‘re welcome
Offline neilc
« Reply #8 on: February 12, 2018, 06:39 PM »
That's fantastic.  I just got my Shaper Origin and this will be a project I tackle.
Thanks for sharing!
Offline Gjarman12
« Reply #9 on: February 12, 2018, 09:10 PM »
Same. Thanks
Offline MKintrup
« Reply #10 on: February 13, 2018, 05:05 AM »
I´m glad to see that so many want to use my drawings.
I have used countersink screws M6x20mm for the rear fences, my cnc only drilled 6mm holes and I made the countersinks on my drillpress. The six M4 screws of my downfence came out a bit damaged, (they were glued in by Festool) so I decided to replace them.
« Reply #11 on: February 13, 2018, 06:50 AM »
I will definitively cut a few dozen of the insert part  [wink]
Mario
Offline mdamsma
« Reply #12 on: February 15, 2018, 05:43 PM »
MKintrup
Is it possible to put the drawings in a pdf ?
So that I can print them and stick them on wood
Menno
Offline MKintrup
« Reply #13 on: February 16, 2018, 02:06 AM »
@mdamsma
yes of course
 drawing as PDF 72DPi
I hope it works
Offline dicktill
« Reply #14 on: February 16, 2018, 10:14 AM »
Offline mdamsma
« Reply #15 on: February 16, 2018, 05:37 PM »
Offline jmbfestool
« Reply #16 on: February 17, 2018, 02:47 AM »
Sound that thank you.
You got a DXF file for it?
*********************************************************************** [thumbs up]UK members click me
Offline MKintrup
« Reply #17 on: February 17, 2018, 04:39 AM »
sorry no, I don‘t have a dxf file
Offline jmbfestool
« Reply #18 on: February 17, 2018, 03:18 PM »
Oh okay it’s fine
I’ll see if I can use the PDF or that SVG file....
I always use DXF for my cnc.
Offline newinwood
« Reply #19 on: February 19, 2018, 06:58 PM »
It is funny, I just create same svg file for Shaper Origin, and was planning to post it here.
Ed.
I love what I do
Offline RKA
« Reply #20 on: February 19, 2018, 08:47 PM »
@MKintrup
Thank you!  I had made aux fences but used nyloc nuts on the backside which of course meant I needed a socket and wrench.  After seeing yours I picked up a set of knobs from mcmaster.com with a 3/4” head and they fit just perfectly under the green levers.  Much better!
-Raj
Offline MKintrup
« Reply #21 on: February 23, 2018, 02:55 AM »
@RKA in my first tests I have used nuts also, but it was inconvinient.
thank you
