mattfc
Offline
« on: June 14, 2011, 04:21 PM » |
Working on making my MFT and CMS more mobile for the workshop/garage I am using the same system as for my KAPEX Workstation built using plywood and aluminium profile systems from KJN Profiles, aluminium cost about £8.50 a linear meter for the 45mm x 45mm profile. Its pretty easy to use, KJN cut the profile as part of the above cost to the lengths you require so its just a case on drilling and bolting (bolts are self tapping M12 with a TORX 50 head). The slots are 10mm, so the 12mm ply is routed to slot into the profile groove. The drawer slides also bolt into the grove, I use a bolt through the slide with a t-nut in the channel, means its quick to slide the runners to whatever spacing you require Building the base frame  Base frame almost complete (took about 4 hours)  For the 6 uprights that support the CMS and MFT, I have a core screw to be able to level the top with other worskhop equipment  Getting there...  Full extention runners. The boxed in space under the CMS has slides for my addition CMS modules.. so its a mini ModPort!  Even has drawers on the otherside  Same system for my drill press, need to make the 2 drawers for the underside (as per the KAPEX workstation)  KAPEX and SYSPORT MFT side by side (plus lots of mess to sort)  I am also building a CMS based stand alone trolley based on this system.. shorts to follow soon
« Last Edit: July 14, 2011, 06:05 PM by mattfc »
Alan m
Online
« Reply #1 on: June 14, 2011, 04:49 PM » |
great job matt. cant wait to see more.
how much do it cost in total for the aluminium
Ken Nagrod
Restricted
Offline
« Reply #2 on: June 14, 2011, 05:03 PM » |
Really nice planning and execution, Matt. You'd be a good addition to the "Sysport Class".
tjbier
Online
« Reply #3 on: June 14, 2011, 05:57 PM » |
That is great Matt! Perfect for shop/home use, what do you think you had into the whole thing $ ? I like it!
Tom- ps, I read these.
Ocram
Offline
« Reply #4 on: June 14, 2011, 07:30 PM » |
Wow, this looks good.
mattfc
Offline
« Reply #5 on: June 15, 2011, 03:19 AM » |
In terms of execution, I did the design using Microsoft Visio (am a corporate worker by day). The stick man type isometric picture is important to to make sure you count the right number of pieces. I could have done this in Sketch-up I guess but would need to learn how to use it, so this worked fine (I did see there is already some profile inn the 3d warehouse. The stuff I used is Bosch Rexwroth  The costings are as follows:- | Item | £ | $ | | 19.85m of Aluminium | £205 | $325 | | Castors | £44 | $70 | | 60 core bolts | £29 | $46 | | Ply 2 sheets 12mm WPB | £32 | $52 | | 12x 350mm drawer slides | £72 | $115 | | Total | £382 | $608 |
So not cheap but will last, is configurable, can still change it a bit, wont rust or warp, very easy to bolt additions on. I have found that planning it out is very important. I have a blade to cut Alu on the KAPEX but wouldn't want to do lots of it, so have worked out all the lengths first and KJN cut it. They are pretty accurate, I would say to at least 0.5mm
Alan m
Online
« Reply #6 on: June 15, 2011, 04:24 AM » |
thanks matt i know you think it is expensive but i thought it would be a lot dearer. 400 pounds isnt bad when you think that you can re use 90 % of it. add bits. i might build something like this
mattfc
Offline
« Reply #7 on: June 15, 2011, 04:37 AM » |
I agree, I don't think its too bad either, total cost in vat and delivery of all the components to make what you see in the pics (exluding runners and plywood), the drill press and a router table which I will do a progress post on soon was just over £600. The cost of getting good quality timber to build it all wouldn't be hugely less, since the alu is 50% of the cost, runners etc soon add up which you need either way. I just prefer the rigidity and fixed nature of alu (no warping etc) for this sort of thing. Plus its light.. I could quite easily lift the complete subframe and had to to get some of the bolts in.. I would struggle with wood. Also having all the pieces of alu cut to size as part of the cost is a major time saver!!
justinmcf
Offline
Location: Gold Coast, Queensland, Australia Member Since: Nov 2008
Queensland Builder
« Reply #8 on: June 15, 2011, 05:20 AM » |
looks like a great job. 400 quid well spent.
if i could get my hands on some free aluminium, i would have a crack at his myself.
thanks for sharing, justin.
tjbier
Online
« Reply #9 on: June 15, 2011, 08:48 AM » |
Thanks Matt, that price here is 1 sysport, so I think you did great!
Festoller
Offline
« Reply #10 on: June 15, 2011, 09:54 AM » |
Thanks a lot Matt! A very inspiring design!
I was in the middle of building a Kapex Workstation (timber) and your design got me thinking if it actually wouldn't be better to use Aluminum like in your Kapex Workstation project. Did you use the same software to design the Kapex Workstation and could you post the drawing and parts list?
I don't use my MFT outside of the workshop very often, but there were some projects I had to. Is your MFT and the CMS screwed to the Aluminum frame or could it still be taken off in a few minutes?
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
mattfc
Offline
« Reply #11 on: June 15, 2011, 11:33 AM » |
Please see below pictures, plus I have included a couple of the KAPEX fixing, its leveled using the 4 threaded bars (the KAPEX platform is suspended) and then once at the exact height, locked into place using the quick connectors)   Mock up of KAPEX platform  Actual platform
cerv
Offline
« Reply #12 on: June 15, 2011, 11:44 AM » |
Matt, Very well executed! By the way, how did you do ISO with Visio? Is there any stencils out there? I pretty much use Visio when designing my own roller table. Cheers.
mattfc
Offline
« Reply #13 on: June 15, 2011, 12:02 PM » |
I did the iso by freehand, visio doesn't do much (other than to be able to set a line at 60/30 degrees)
cerv
Offline
« Reply #14 on: June 15, 2011, 12:18 PM » |
I see. Well, it came out really good.
b_m_hart
Offline
« Reply #15 on: June 15, 2011, 12:52 PM » |
pure hawtness. If I ever have the space, I'll definitely do something like this.
TS 55 EQ, ETS 150/5, RO 150 FEQ, OF 1010 EQ, DF 500 Q, C12, CT Midi, OF 2200 EB, MFT/3s, DTS 400 EQ, parallel guides, and seemingly growing by the day...
mattfc
Offline
« Reply #16 on: June 15, 2011, 04:16 PM » |
And the first pictures of the dedicated router table with the Wixey digital routout Still need to put the drawers in underneath, they will store my OF1100 and OF1400 plus router bits  Mounted on a post for easier reading
mattfc
Offline
« Reply #17 on: June 15, 2011, 04:52 PM » |
No it just rests, my precise measuring paid off, it a tight fit, has to be dropped on perfectly vertical. It's quick to take off, then just bolt the legs on. Took a while to get the legs off as there is a nyloc bolt. But if you were just popping off for a quick job I wouldn't bother, could probably convert it back in 5 mins or so
wintu
Offline
« Reply #18 on: June 15, 2011, 09:05 PM » |
very nice !!!!!!! anybody know where to get same profiles in the states? i will nee to build kapex workstation soon
Sal LiVecchi
Offline
« Reply #19 on: June 15, 2011, 09:17 PM » |
Wintu You could go do a search for 8020 on EBay and use their store to see what you need. This is a location for alot of their job left overs. I order from them often you Will lamazed at their inventory of goodies. The have T slot Alum rail in fractional and metric. They carry the 4545 and the 4590 series rails used above
Sal
« Last Edit: June 15, 2011, 09:20 PM by Sal @ Theshipstore »
Life is too short and the road is too long to drive anything less than a Festool
wintu
Offline
« Reply #20 on: June 16, 2011, 12:31 AM » |
thanks Sal . will check it out
mattfc
Offline
« Reply #21 on: July 14, 2011, 06:03 PM » |
Finally got around to just about finishing it. As others will know, there are a few shortcomings on the Festool CMS router module, one being to no fine adjustable way to move both faces of the fence back (just the right hand one can be recessed to use the fence planer style) plus keeping the fence parallel to the front of the module (and the sliding carriage I have) is a manual effort, so since Incra now do a metric version of their fence I have combined it into the design   Router bit storage in the 2 drawers  The Wixey digital readout was another addition.. has been great, wind the bit up to be level with the table.. press the "zero" button and you can quickly set the bit height to the nearest 100th of a mm  OF2200 mounting view  The Wixey does fractions for our imperial friends :-)  Onto the Incra.. I mounted it on pivots so it lifts clear of the table, in case I want to use a template bit and want a free surface.. or want to use the festool fence  Hinge detail  Incra LS positioner deployed, the red lever locks the fence in place one at the desired distance, it has an intermediate position for fine adjustment  Front view of the fence arrangement. I have the "Wonder" fence attached, which in addition allows you to adjust the mouth for the large bits, and move the left and right side back and forth to change their depth  To adjust the depth of the fence wings, there is a wedge system which allows very fine control  The whole fence can be moved back and forth (see the earlier pic with the big red locking lever), this knob is for fine adjusting  Festool fence can be used when the Incra has been pivoted away  I didn't find the CMS plate alignment was perfect with the surrounding CMS framework, so I used some profile below and drilled (carefully!!) through the CMS plate. These two countersunk socket screws bolt into the profile below and pull the whole assembly dead flat  Onto my CMS+ MFT sysport.. I created a cabinet below the CMS mount for my spare module to go in.. simple hinge door  The plate+tool not in use can be stored here  Side view  Drawers extend to allow access to systainers  Drill stand completed  Eagle eyes might spot the Zobo Festool drillbits in the drawer :-)  A couple of random additions... I was struggling to find a good way to put wheels on my workbench and wanted to take advantage of the stability of having the bench on the floor.. but be bale to move it. I found some jockey wheels that have a side wind mechanism (rated at 1000lbs each wheel).. so whilst not pretty, do a good job. Once wound down the castors go below the bench so they can rotate (the winding mech. has a travel of over 12")  2nd pic.. they wheels on ebay were £15 each so not much more that a good quality castor  KAPEX by night!
Festoller
Offline
« Reply #22 on: July 15, 2011, 04:05 AM » |
Great job Matt!!!!!!
How do you handle dust/ chippings with the Positioner on the CMS? Only with the super fence? To me it seems without, it could be difficult to control dust and chippings from routing.
mattfc
Offline
« Reply #23 on: July 15, 2011, 04:44 AM » |
The Wonderfence profile if blocked off on one end and the other has a 50mm port (you can see the black 90deg bend on the left hand side for extraction) and where the two fences split to adjust for bit size, there is also an inner lining to improve extraction. All that said, I tend to extract through the OF2200 as there is a pretty good dust shroud and get a good throughput with a 38mm hose
Alan m
Online
« Reply #24 on: July 15, 2011, 05:09 AM » |
you could put a y on the wonder fence and a 35 mm going to the router
mattfc
Offline
« Reply #25 on: July 15, 2011, 05:40 AM » |
Yes will probably do that... should work pretty well
Festoller
Offline
« Reply #26 on: July 15, 2011, 06:42 AM » |
Unfortunately I am using the OF 1010 and the extraction is really poor.
In addition I didn't buy the Wonderfence upgrade, just the normal fence and since then I am thinking about an extraction solution.
I guess for my setup the Wonderfence will do the trick.
Steve Rowe
Offline
« Reply #27 on: July 15, 2011, 08:44 AM » |
Fabulous job Matt! It looks like a great addition to your shop.
Those aluminum profiles are available in the US from 80/20 and they will even cut them to length for you. Steve
justinmcf
Offline
Queensland Builder
« Reply #28 on: July 15, 2011, 04:30 PM » |
awesome job matt!
i might have to make something similar based on your amazing design.
justin.
FestoolMike
Offline
« Reply #29 on: July 20, 2011, 10:44 AM » |
Matt,
Reading throught he thread. Very impressive.
I like what you have done with those profiles. I did have one question though... Where is the 45x90 profile located in the sysport w CMS and MFT? I see you call out 3 pieces and I dont see where they are in the drawing. They are essentially 2 of the same profile togehter??
Thanks,
Mike
mattfc
Offline
« Reply #30 on: July 20, 2011, 10:56 AM » |
Matt,
Thanks,
Mike
Hi, if you look at this post http://festoolownersgroup.com/festool-jigs-tool-enhancements/sysport-cms-mft-(work-in-progress)/msg157775/#msg157775 and look for the thicker lines in the isometric line drawing top left you can see the 3 x 45x90 uprights in the middle. I used the 45x90 here so that I two slots next to each other for the rears of the drawer runners to connect into.. if that makes sense? The 45x90 is essentiall the same as two 45x45 as you say, the only difference is interally, obviously no slots just a void internally where the two join
deadplumb
Offline
« Reply #31 on: November 22, 2011, 01:14 PM » |
These guys should fill the bill... http://www.faztek.net/index.asp
rookie08
Offline
« Reply #32 on: January 16, 2012, 08:53 PM » |
Matt,
Was looking for some ideas on a router table with an incra ls positioner and fence and came across your design. Fantastic! Can you please tell me where you got the pivots for the incra or how you made them
"so it lifts clear of the table, in case I want to use a template bit and want a free surface.. "
I need to do the same thing with mine.
Thanks!
James
Squasher
Offline
« Reply #33 on: January 20, 2012, 05:57 PM » |
Mattfc,
I plan to make a similar table for my MFT (1080) and am going to use your design. Before doing so, however, I have a few questions.
1) I assume that your table is sized for an MFT/3 (plus CMS) and not a 1080..... Obviously, I'll need to measure my 1080 to see if the dimensions are the same. 2) Do you have any issues with way you mount the MFT to the adjustable levelers that protrude from the extruded aluminum? Have you thought of alternative ideas for more rigidly attaching the MFT to the extruded aluminum? 3) Does anyone have any suggestions on where I could buy the Extruded aluminum? I bought T-slotted aluminum from an online company a number of years ago that provided an online shopping cart where you could order the aluminum (to exact size) and specify machining operations (with running costs in the shopping basket), etc. Unfortunately, I can't remember the company URL or can't find anyone with this service anymore.... 8020 and faztek seem to be manufacturers/distributors and/or don't offer the same type of service.
Thanks in advance.
Richard/RMW
Retailer
Offline
Location: Brigantine, New Jersey Member Since: Jul 2010
« Reply #34 on: January 21, 2012, 11:44 PM » |
Mattfc,
Thanks in advance.
Squasher, I stumbled onto a trick with 8020. They don't sell direct as a rule, only thru distributors as you noted. They do, however have an eBay store, ostensibly for "surplus" but I am seeing more stock items added all the time. The trick is to order whatever you can thru the eBay store from the inventory they have listed online. After that you contact them thru eBay and give them a list of the other materials you want (their entire catalog is available online, along with a price list you can download). They will add those items to your eBay order and issue you a combined invoice on eBay. Hope this helps. RMW
mattfc
Offline
« Reply #35 on: January 22, 2012, 08:12 AM » |
Matt,
Thanks,
Mike
They are in the middle as uprights, provides 2 slots for the drawer runners to fit back to back
Mr Handyman
Offline
« Reply #36 on: January 23, 2012, 04:37 AM » |
Mattfc,
The MFT 1080 is both wider and longer than the MFT/3, but lower. Very nice job Mattfc! The stuff looks great.
mattfc
Offline
« Reply #37 on: January 23, 2012, 08:51 AM » |
Mattfc,
Thanks in advance.
Yes it's an MFT3. With regards to mounting, the uprights do protrude into the corner casting stopping lateral movement as its a very snug fit, that tight fit along with gravit holds it down fine on the levelling bolts
mattfc
Offline
« Reply #38 on: January 23, 2012, 08:55 AM » |
Matt,
Thanks!
James
This is the link to the hinges http://www.aluminium-profile.co.uk/acatalog/Aluminium_Profile_Joints.htmlIt's a UK company, think you have 8020 in the US who must do similar, else Bosch Rexwroth how make most the stuff KJN sell
richard.selwyn
Offline
Normandy, France
« Reply #39 on: February 05, 2012, 07:40 AM » |
Check out the blue tooth drill from Bosch in the link below. It records how many screws you've driven etc. scary. Richard Matt,
Thanks!
James
Kev
Online
« Reply #40 on: February 05, 2012, 10:12 AM » |
Thanks!
James
This is the link to the hinges http://www.aluminium-profile.co.uk/acatalog/Aluminium_Profile_Joints.htmlIt's a UK company, think you have 8020 in the US who must do similar, else Bosch Rexwroth how make most the stuff KJN sell Let's hope some doesn't decide to try and put a cellular phone in a jig saw - that could be messy
rookie08
Offline
« Reply #41 on: February 05, 2012, 12:55 PM » |
Thanks Matt!
I'll do a search to see if I can find a local based company/dealer to source the from
Cheers,
James
Manish11122
Offline
« Reply #42 on: February 26, 2012, 02:15 PM » |
Hi, wow what a great job I am so impressed thank you for your post. I have been looking for a solution for my small shop for a while to combine my Incra wonder fence with MFT and possible the Kapex Kindly could you email me your Visio diagrams with layout and measurements or materiel list? for this and any other that may help in a small shop. I know Visio better than sketchup thx again Manish manish11122@yahoo.com
tonycartercraig
Offline
« Reply #43 on: February 26, 2012, 03:03 PM » |
A few questions about your project.
I'm planning a similar type build for my shop cabinets. I think the use of the aluminum extrusion in strategic locations will allow for the use of clamps, featherboards etc. whether it be on the face of a cabinet or topside. In comparing the t-slot in some of the products on the market, i.e. Kreg's track systems and the Incra track systems, with the track in the aluminum extrusions it appears that the accessories would be interchangeable.
My question for you is do you use your slots for different attachments?
Next question. You say that is a 45mm x 45mm profile. In the pictures that appears to be larger than 1.7" square aluminum tubing. If it is only 1.7" square, is it enough strength for the spans that you are doing or is there some reinforcements being made that aren't in the pictures?
Also, I would like to see some more pics on your drawer slides and points of attachment for them. Where did you source the slides?
Your project pictures are a great inspiration for me. Thanks for posting them in such detail.
One other note, ALUMINUM IS EXPENSIVE.
SRSemenza
Global Moderator
Offline
« Reply #44 on: February 26, 2012, 06:10 PM » |
Hi Tony & Manish, Welcome to the FOG!  Good luck with your projects. Lots of great homebuilt things on here. Please post build threads so we can all enjoy. Seth
Festool Service 800-554-8741
mattfc
Offline
« Reply #45 on: February 28, 2012, 05:42 AM » |
Hi, wow what a great job I am so impressed thank you for your post. I have been looking for a solution for my small shop for a while to combine my Incra wonder fence with MFT and possible the Kapex Kindly could you email me your Visio diagrams with layout and measurements or materiel list? for this and any other that may help in a small shop. I know Visio better than sketchup thx again Manish manish11122@yahoo.comHave sent you your e-mail, sorry for the delay, forgot to check this thread
mattfc
Offline
« Reply #46 on: February 28, 2012, 06:14 AM » |
Re using the slots, I do use them for a long fence on the KAPEX workstation (I have some profile bolter on the top inline with the KAPEX Fence), and I have used the T-Bolts for this, they make it easy to clamp any jig in place, since you just drop them into the profile and twist by 90 degrees to lock in place. The 45x45 slot also allows for the Festool clamps to slide in place if required, providing you leave the end of the profile exposed to slide the clamp in. The 45x45 is 1.7", but very strong (modulus of elasticity is about 7 times that of oak for example). There is no additional re-enforcing, apart from it being bolted into the square grid that you see which helps stiffen it, that said even on a 2 m section if you stood in the middle you would be hard pushed to deflect it by more than a mm or 2. For the heaviest item I have, the KAPEX workstation with all the drawers full you can see that the base profile is a 90mm x 45mm section which all the weight bears down on, that profile could support a heavy car no problem.. this stuff is very strong, the weakest points will be the connections. Re the drawer slides, they are just standard fully extening drawer slides (these ones to be exact http://www.ironmongerydirect.co.uk/Products/Cabinet_Furniture_and_Hardware/Runners_and_Cabinet_Systems/1524/Ball_Race_Drawer_Runners_Double_Extension). They are fixed by drilling through the sides at the front and back of the slide with a spacing to match the centre of the slots in the profile, then I just pop a bolt through the whole and into a t-nut which sits inside the profile T-Nuts
tonycartercraig
Offline
« Reply #47 on: February 29, 2012, 04:31 PM » |
One other question. What are your thoughts on having the crown stop with base extensions included on the Kapex and allowing the space for the complete assembly to fit into your Kapex workstation? I noticed that your workstation just allows for the saw without any additional width.
mattfc
Offline
« Reply #48 on: March 01, 2012, 07:45 AM » |
Would be easy enough to design it as such, I didn't as I wanted to build my own fence, as I intend to add a digital read-out
Coxworth
Offline
« Reply #49 on: March 03, 2012, 01:07 AM » |
Hey Matt! This is exactly what I was looking for and the amount of detail you provide is awesome. I am planning out my workshop for my new home and will Try to replicate something similar here.
The only thing I could not figure out is how you connected your corners. You mention that you drilled and used hex bolts.
This makes sense for 2 pieces joined at a 90 but how to attach the third piece without running into the previous bolt?
You can by 3 sided connectors for this profile but that drives up the cost!
Also, you said all of the bolts were self tapping. Does this mean that you did not need to tap anything? Even the leveling screws?
Thanks for your help, and your great design!
mattfc
Offline
« Reply #50 on: March 03, 2012, 04:12 AM » |
re the 3 pieces connecting in a corner, you can do this fine since the bolt head sit in the outside channel/slot (e.g. the core bolt only extends about 5mm from the end of the profile you tap the bolt into and then you slide it into the slot of the other profile) and doesn't go right through profile, you have to drill 2 holes that go right the way through though. Make sense? If not I can post a picture The core bolts are all self tapping, they only tap into the end section of the profile though
Richard/RMW
Retailer
Offline
« Reply #51 on: March 03, 2012, 10:42 AM » |
Coxworth, This may help to clarify. This graphic shows the position of the hex screw itself, the access hole is drilled through the t-slot in the top extrusion, directly above the centerline of the extrusion you are attaching to. Then you can reach a hex key through the access hole to tighten the hex screw. I am not sure if I am explaining this clearly but basically the hex screw does not pass through the drilled hole, only the hex key does to tighten it.  This is one of the cheapest hardware options for connecting these extrusions and it is easy to do yourself in the shop. RMW
Kodi Crescent
Offline
« Reply #52 on: March 19, 2012, 03:01 PM » |
For anyone planning a bench like this...
I tried configuring one of these using 8020 profiles from eBay. I have a relatively unsophisticated shop with just a MFT, no drill press, no chop saw.
You need to have a way to get good square cuts on the profiles, and a way to drill nice straight holes. The 8020 folks on eBay will NOT do this for you, even for a charge.
Finding the connectors was really a pain. There is a $2 or so per connector option on eBay, but again, you have to be able to machine a 10mm hole through the profile with some precision.
The cost of building one of these using the cheapest 8020 profiles and connectors I could find was $320 + shipping, + cutting, + drilling. This is for the bench only, and does not include the drawer slides. Again, this was the cheapest I could get this to. By the time I was done building this I could have bought a new MFT/3.
I decided to attempt to replicate this in wood. So far I'm only $100 into it, and I think that will provide enough material for the build. All the joints will be Dominos. I'll provide details as I complete it.
Thanks to MattFC for the design and dimensions.
Richard/RMW
Retailer
Offline
« Reply #53 on: March 19, 2012, 06:14 PM » |
You are absolutely right that using their stuff has a learning curve and it probably is not worth it for a one-off use. I think 8020 only sells through distributors (other than what you can get on eBay) and in my case there are 3 or 4 distributors who service my area. I have not tried to buy direct from them because I can cut/drill myself. What I learned is that I can buy some of their stuff on eBay and then send them a list of anything they don't offer on eBay and they will add it to the order.
There is another company selling similar stuff (less complete product line) called Faztec, I believe they will cut to length, drill etc. for one-off projects. You just send them a sketch. Still costly.
RMW
nsc
Offline
« Reply #54 on: March 19, 2012, 09:18 PM » |
anyone know where you can get that kind off aluminium in the US?
Corwin
Offline
« Reply #55 on: March 19, 2012, 10:11 PM » |
http://www.8020.net/PostalLookup.asp
Shirt Size: L
Kodi Crescent
Offline
« Reply #56 on: March 20, 2012, 07:29 AM » |
RMW
That may be the case. If you are not using those end tap connectors, then the cost really goes up for these. I wanted to use the drill through bolt connectors because I could position a profile anywhere perpendicular to another profile without having to drill into the second profile. These allow adjustability. I finally got 8020 to commit to cut to length for about $2 per cut. They would not drill the holes though. They said it was an easy job, but that the eBay side of things only deals with getting rid of surplus. I'd have to contact a local distributor. The "local" distributor was 3 or 4 hours away. It was just too much hassle and too expensive for a home hobbyist to be worth it. I figure that making it out of wood would be a better opportunity to learn woodworking, using the Domino, and be a heck of a lot cheaper to boot.
Michael_Swe
Offline
« Reply #57 on: January 11, 2013, 11:59 AM » |
Hi. I'm on the fence to build some work benches out of 45x45 Rexroth profiles. The 45x45 profiles has a 10 mm groove.
But I just noticed that the Festool clamps and other common wood working accessories uses 8 mm grooves. That means that the Festool clamps probably are to small for the 100 mm groove. I think they would fall out.
Matt, have you tried the clamps in the groove? Or have you fond any other clamps that fit in the 10 mm grove?
Thank you for your thorough post on this. It made me change my mind from welding the frames. The extrusions will be a heck of a lot easier to build with.
//Michael
mattfc
Offline
« Reply #58 on: January 11, 2013, 12:10 PM » |
I do use festool clamps in the grooves, its not a tight fit (you can probably move the clamps about 30degrees side to side, but does work ok)
If in doubt, just get a sample of the profile sent through, most have offcuts knocking about.
Michael_Swe
Offline
« Reply #59 on: January 11, 2013, 12:13 PM » |
Thanks. Can you even get the clamp into a closed groove if you tilt it? My thought was to mill some at the start of each groove to widen it. But that might not be needed, or?
greg mann
Offline
« Reply #60 on: January 11, 2013, 01:42 PM » |
I originally built an MFT knockoff with 8020 about 10 years ago. (Man, has it been that long?) It was cheaper for me because I had access to the material. I still have a workbench I made from the stuff and need to find a way to use it more as it is a good bench. Right now it is a tool collector. I have a problem with horizontal surfaces as I cannot keep myself from piling things on them, but that is just me.
The bores used in the 8020 system to connect extrusions at a right angle can be machined with a router and a template. I have done this and they come out beautiful, but one needs to really understand the force vectors developed and not get too greedy. I believe they are 13/16 diameter but don't take my word for it. Measure one made by the factory before you try machining any yourself. I do also believe you could do them on a drill press with a carbide tipped Forstner bit. I think one can get such an animal from Rockler with a 3/8 shank. They are too long as is and would need to have the shank cut shorter so the tool would be much more rigid before use. You would essentially be turning it into an end cutting end-mill. Either way, patience is a virtue but there is nothing that compares to fabricating the components for yourself in exactly the lengths you need. Even when I did mine with arouter it was more for the kick involved as I have access to plenty of equipment to do it easily, such as a Bridgeport mill.
Greg Mann Oakland, Michigan
Svar
Offline
« Reply #61 on: January 12, 2013, 04:02 AM » |
Sgryd, 45x45 Rexroth profiles with 10 mm slots will hold Festool clamps. However, they engage the very edge of the slot and it may get damaged and wear off quickly. You cannot insert the clamp in there by tilting it. Also, in Rexroth profiles T-slot edges are square (which is better), while in 80/20 they are rounded.
jonny round boy
Offline
« Reply #62 on: January 12, 2013, 01:17 PM » |
No, it's not just you.
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - T12 drill - PS420 jigsaw - OFK500 trimmer
Peter Halle
Global Moderator
Online
« Reply #63 on: January 12, 2013, 01:22 PM » |
No, it's not just you.  I include the floor. Darn gravity prevents me from easily using the ceiling. Peter
Alan m
Online
« Reply #64 on: January 12, 2013, 02:17 PM » |
i used to be like that until i took down the 24"deep bench all around the shop. it was handy but the amount of crap it had on it was amazing. i originally planned to build a series of cabinets under it but the thought of all the crap on top scares me. removing it made ht esmall shop so much bigger. yes i lost 30-40 feet (totalfrom a few walls) of work surface but i could only ever use 10 feet because i wouls end up moving crap from one bench to the other. it was such a big jobs to tidy it that i didnt bother. with it all gone i now have to put stuff away because i have nowhere else to put it
Richard/RMW
Retailer
Offline
« Reply #65 on: January 13, 2013, 12:11 PM » |
No, it's not just you.  I include the floor. Darn gravity prevents me from easily using the ceiling. Peter Peter, Easily solved, when I ran out of horizontal spaces I started screwing seldom used jigs to the rafters... RMW
Massemannen
Offline
« Reply #66 on: June 11, 2013, 03:52 PM » |
Thanks for inspiring me to go into the wonderful world of aluminum extrusions  I stumbled across a free software that makes building with Al extrusions a breeze! Drawings and BOM lists are automatically created! Can´t recommend it enough, http://www.framexpert.com/
Kev
Online
« Reply #67 on: June 11, 2013, 06:42 PM » |
Thanks for inspiring me to go into the wonderful world of aluminum extrusions  I stumbled across a free software that makes building with Al extrusions a breeze! Drawings and BOM lists are automatically created! Can´t recommend it enough, http://www.framexpert.com/Pretty cool - don't like the scary $ value it gives you as you design though ... that stuff isn't cheap. I'm normally against "big box" stores, but I think this is the sort of stuff that would penetrate far better if there was significantly greater volume and lower price.
Massemannen
Offline
« Reply #68 on: June 12, 2013, 02:41 AM » |
Hear hear... You´re right about the price. But I made a BOM list and checked the prices from an European supplier and was relieved when I found out that I could buy it much cheaper than the price given in the software.
Woodmatt
Offline
« Reply #69 on: June 14, 2013, 05:46 AM » |
Matt, Really like the router table.Is there any particular reason why the hinges holding the Incra fence are fixed to the small uprights and not to the horizontal extrusion.I am considering doing something similar but would like to be able to remove the fence arm from the locking system and produce a flat top.obviously the 2 uprights would stop me having a totally flat top.
Matthew
If you are not living on the edge you are taking up to much space.
