Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 22, 2013, 04:28 PM
Home
Search
Login
Register
Login
Festool USA
Festool International
Woodworking & Power Tools Forum - Festool Owners Group
FESTOOL DISCUSSIONS
Festool Jigs & Tool Enhancements
Guide Rail Deflector Modification
Pages: [
1
Go Down
« previous
next »
Print
Author
Topic: Guide Rail Deflector Modification (Read 2487 times)
SRSemenza
Global Moderator
Offline
on:
September 14, 2007, 11:20 PM »
I cut a notch in one of my Deflectors and removed the side projection on the bottom. This allows it to be positioned in either Guide Rail slot. I thought this might help a bit when the hose is dragging from the left. I also plan to use a heat gun or something to heat up the plastic enough so that I can bend the sides out a little. A flare out may also help when the hose is coming from the extreme left or right. Not sure yet how much difference this makes but it is easy to do. I marked out the section to remove with an exacto knife and small saddle square. Went to a utility knife to get a good line / cut part way through. Then finished off with a hack saw. I am sure a band saw would make quick work of this.
srs
Last Edit: May 08, 2008, 02:10 AM by semenza
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Timmy C
Festool Dealer
Offline
Re: Guide Rail Deflector Modification
Reply #1 on:
September 15, 2007, 11:34 AM »
Hey S, what problems / issues were you having that prompted this modification?
Timmy C
Timmy C
www.FestoolJunkie.com
SRSemenza
Global Moderator
Offline
Reply #2 on:
September 15, 2007, 03:11 PM »
No real problem. I just like to try improving things whenever I see a possibility. If the deflector is over closer to the left side when the hose is coming from that direction , then it should be a little smoother. Also see my post on this in the Wish List.
Seth R. Semenza
Pages: [
1
Go Up
Print
« previous
next »
Jump to:
Please select a destination:
FESTOOL DISCUSSIONS
=> Festool Tools & Accessories
=> Festool Tool Reviews
=> Festool How To...
=> Festool Tool Problems
=> Festool Jigs & Tool Enhancements
=> Festool Wish List
=> Festool and Tanos Systainers
=> Ask Festool
=> Sales & Dealer Area
=> Fun, Games, Diversions
GENERAL DISCUSSIONS
=> Member Projects
=> Other Tools & Accessories
=> Other Tool Reviews
=> Hand Tools
=> Building Materials
=> Finishing and Painting
=> Various Woodworking & Crafts Topics
=> Home Improvement & Other Projects
=> Member Connections
FORUM TECHNICAL
=> Gallery & Attaching Images
=> Forum Features & Functions
=> Forum Rules, Guidelines, & Suggestions
OFF-TOPIC
=> Computers, Gadgets, Technology
=> Photography
=> Sports & Recreation
=> General Friendly Chat
=> Classifieds
