Festoller
Online
« on: August 03, 2011, 05:20 AM » |
Somone posted another version of this top a few weeks ago, but it was just a plywood board attached to the Systainer and you had to take it off to use the Festool clamps. This version sold on Ebay gives you the proper spacing between top and Systainer, to use the Festool clamps without lifting the top first. The most interesting part are the metal fittings used to attach the snappers. I don't think this is a Festool part, but it would be interesting to find out what kind of fitting this is for more easy Systainer attachment projects. http://cgi.ebay.de/Multifunktionale-Werkbank-Systainer-/180704759310?pt=DE_Haus_Garten_Heimwerker_Werkstattausr%C3%BCstung&hash=item2a12d7ce0e
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
Timtool
Retailer
Offline
« Reply #1 on: August 03, 2011, 07:41 AM » |
nice find, it would indeed be interesting to find out what hardware that is, though i only have T-locs. for those you would need a completely different design.
Alan m
Offline
« Reply #2 on: August 03, 2011, 09:11 AM » |
looks handy. i would like to know about the hardware. if it was mine i would put holes or a t track on the side. i could see myself putting this on top of the vac for site use
LostInTheWood
Offline
« Reply #3 on: August 04, 2011, 12:21 PM » |
I would also like to know about that hardware. Not only what it is, but will it wear out the plastic Festool clips? I would add a handle shaped cutout in the middle (or a pull up/out handle) so I could carry it with a few systainers attached.
bror
Offline
« Reply #4 on: August 10, 2011, 06:03 AM » |
it looks a lot like mine, which was patented in feb 2010. check it out on www.diafer.nl
Alan m
Offline
« Reply #5 on: August 10, 2011, 06:09 AM » |
 to the fog great idea. any chance of a translate or general jist of what it says. prices etc
Eli
Offline
A Yankee in Kangaroo Court
« Reply #6 on: August 10, 2011, 06:46 AM » |
it looks a lot like mine, which was patented in feb 2010. check it out on www.diafer.nlWell done. Get started on the T-loc one.....
Do nothing, stay ahead.
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #7 on: August 10, 2011, 07:37 AM » |
it looks a lot like mine, which was patented in feb 2010. check it out on www.diafer.nlDang!!! Another item to add to the NAINA list. Bummah!!!
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
Richard/RMW
Retailer
Offline
Location: Brigantine, New Jersey Member Since: Jul 2010
« Reply #8 on: August 10, 2011, 10:50 AM » |
From what I can see in the photo the hardware looks like the clip side of a draw latch, similar to ones sold by McMaster:
Festoller
Online
« Reply #9 on: August 10, 2011, 03:18 PM » |
it looks a lot like mine, which was patented in feb 2010. check it out on www.diafer.nlWell, yours looks much better with more features! Great design! Can you post more details (prices, dealers, order info)?
Festoller
Online
« Reply #10 on: August 10, 2011, 03:34 PM » |
I got a few photos of the hardware and I would guess it's some kind of wall / ceiling anchor or perforated steel tape. It was cut and bent to fit the snapper. If you look closely you can figure out that the tape has a repetitive pattern. Although in my first search I couldn't find this specific brand, but I'll keep looking. It would be great to use for a lot of different Systainer tops!
Festoller
Online
« Reply #11 on: August 11, 2011, 03:38 AM » |
bror:
I assume you used a more reliable hardware to attach your worktop to the Systainer snapper, than the DIY perforated steel tape or anchor solution shown on the photos.
I wouldn't trust this piece of metal to carry arround any of my Festools, and it also seems to be perfect for all kinds of injuires.
Would you share what kind of snapper hardware you used, or if it's your own design make it available for purchase. I guess we all have projects in mind where a proper Systainer connection might be helpfull.
And please post some information on how to pruchase your Systand!
bror
Offline
« Reply #12 on: August 11, 2011, 03:45 PM » |
optimistisch
Offline
« Reply #13 on: August 11, 2011, 07:36 PM » |
The metall parts look pretty good. Do you sell the tops to Germany? I would like to have one of them?
ETS125EQ+, TS55EBQ+, OF2200EB & Metric Set, DF500Q Set, C12 Li 1,3+, PRECISIO CS 50 with an Sliding table, RO150FEQ+ MFS 700 & MFS-VP 1000 and 2 x FS1400/2 in a wooden case, a self designed installers kit for CentroTec tools a self designed work bench in an MFT Style with a lot on enhancements
Twitter: @optimistisch
Festoller
Online
« Reply #14 on: August 12, 2011, 03:16 AM » |
Yes! I would like to have some too!
How about the price for the complete Systand?
TangoXray
Offline
« Reply #15 on: August 12, 2011, 10:38 AM » |
I would love to buy some of that hardware!
/Stefan
Alan m
Offline
« Reply #16 on: August 16, 2011, 09:05 AM » |
i too would love to buy some of those fittings. maybe sell the plans and a enough hardware to make 3 -4 tops. im sure you would sell them as shipping a ply box would get expensive.
Pyotr
Offline
woodworking rookie
« Reply #17 on: August 16, 2011, 02:08 PM » |
I asked, it's 79 euro excluding 19% VAT or shipping.
MFT/3 - TS55 - OF1010 - RTS400 - RO150 - C12 (NiCd)
optimistisch
Offline
« Reply #18 on: August 16, 2011, 02:15 PM » |
I got the same price too, that is far to much. I would pay 60 Euro incl. the VAT and a reasonable cost for shipping (some 7 Euro). But have the 79 Euro plus 19% and 19 Euro shipping ist pretty close to 129 Euro and this is to much for that "tricky wooden thing".
Alan m
Offline
« Reply #19 on: August 16, 2011, 02:59 PM » |
i PM and emailed the seller. i got the same price . its way too dear , especially when im not local. . i offered to buy plans and a few sets of the hard ware. i offered 30 euro for the plans( quiet a lot in my opinion) and 20 euro for 16 pieces of hardware(4 sets) . thats a very good offer that would net him ( him i think not sure) 50 euro for very little out lay or work. sadly he hasnt replied to either and has been logged into the fog since i sent the PM.
Peter Halle
Global Moderator
Offline
« Reply #20 on: August 16, 2011, 03:03 PM » |
It might be worthwhile to remember that it was posted that he had obtained a patent on this assembly. That might explain reluctance to sell plans or hardware separately.
Just a thought.
Alan m
Offline
« Reply #21 on: August 16, 2011, 03:14 PM » |
your probably right peter but a reply stating that (or even just a fob off story ) would be nice. .i dought there is a worldwide patent as we would known about the product sooner as he would be trying to recoupe some of the colosal investment needed to get the patent. can you not sell plans etc and still retain propety rights.
there is very little stoping me making some of these for my personal use only time. i feel there is some good benifits to this system as i could make up small tool stations for site use,(such as a jigsawcms type set up, router table, belt sander, pocket hole jig, etc) i am only persuing this properly because i would like to give credit where its due.
Festoller
Online
« Reply #22 on: August 16, 2011, 03:59 PM » |
I don't think 79 EUR is completely over the top and if Festool offered a Systand like this the price would be a whole new level. A new MFT top or some MFT clamping elements cost the same.
Although the idea is simple and many of us probably thought about it before, it takes a lot of time and money to design and manufacture a marketable product. Not to mention the cost for a patent.
The Systand looks very well manufactured probably high quality beech ply, CNCed and the hardware is a custom design. I don't think you'll be able to make your own version for this price if you include labour and you still need the proper hardware.
Anyway, I have ordered one and will write a little review as soon as it's here, probably by the end of the week.
Alan m
Offline
« Reply #23 on: August 16, 2011, 04:47 PM » |
great to hear that you ordered one. cant wait for the review, they look very handy if i was to make one i wouldnt be woried about it being exactly perfect .
to get one to my door all in would easily be 150 euro. +any import duties. i dont feel that at that price it is worth it. if i could get the hardware and plan(only to give credit for the design) for 50 euro and make it myself it would be worth it
