Pages: [1]   Go Down
  Print
Author Topic: MFT as a sheet goods cutting table  (Read 4087 times)
dogutsukawu
Offline Offline
« on: May 27, 2010, 12:25 PM »
My MFT is 2 tables joined end-to-end so its almost 8' long.  By clamping 4' 2x4 boards across the MFT from underneath using holes in the boards, the MFT is easily put into service as a cutting table for sheet goods.  When not in service, the boards take up very little room in my one car bay garage shop.
My table is mounted on Noden Adjust-a-Bench legs so that when dropped down to its lowest height, I can easily reach across the table for a 4' wide cut.  The Noden legs also have wheels, so I can roll the MFT to the driveway and slide 3/4" MDF from my van right onto the table.
« Last Edit: May 27, 2010, 12:33 PM by dogutsukawu » Logged
waho6o9
Offline Offline
WWW
« Reply #1 on: May 27, 2010, 12:41 PM »
 Very nice!   Big Grin
mikeneron
Offline Offline
« Reply #2 on: May 27, 2010, 01:52 PM »
Am I missing something here?  Why not just put the sheetgoods directly on the MFT surface and make the cuts instead of fumbling with 2x4s?
dogutsukawu
Offline Offline
« Reply #3 on: May 27, 2010, 02:40 PM »
mikeneron:
Two reasons:
1. I want to use the MFT as a cutting table without removing the guide rail and the Incra rails
2. I don't want to cut into the MFT with every cut
Corwin
Offline Offline
« Reply #4 on: May 27, 2010, 05:49 PM »
I'm with Mike, but I'ld place a sacrificial piece of sheet material or some pink foam on top of the table.  The guide rail is easily removed and replaced to the same location, and you stated in your other thread that your Incra tracks remove quickly with just three bolts...  But, no matter -- whatever works for you.  In any event, I think it is a clever idea and it looks like you've done a nice job.
So... you must have at least a dozen of the FS clamps.   Eek!
« Last Edit: May 27, 2010, 05:52 PM by Corwin » Logged
Shirt Size:  L
John Langevin
Offline Offline
Springfield, MA
« Reply #5 on: May 29, 2010, 12:11 PM »
Nice idea and execution! To save your clamps for other uses I would use 20mm PVC pipe or solid dowel inserted into holes in the bottom of the rails so you just 'plug-it' Roll Eyes into your MFT. That should be nore than stable enough for panel cutting.
John
Practicing Mediocrity Never Begets Perfection
Pages: [1]   Go Up
  Print
Jump to:
