Acrobat
Offline
Location: Upper Right, Middle earth Member Since: Jun 2008
« on: May 06, 2012, 09:17 PM » |
Hi, after seeing a few videos around the place and in here, I am of the opinion to add some sort of t-track along the front of my workbench edge, to enable clamping vertical boards, and even perhaps a track on the front "top" edge too if there is a benefit to be had there also. What (if any) size t-track would take the (festool f-type if I am understanding it) clamps? I did see a vid of someones workbench where he used curtain track, so I assume it just has to be fixable and solid enough and wide enough to take the clamps and let them slide in and across easily. Any other alternatives?
In a perfect world, I'd just get the MFT table but since I already have a workbench thought I'd upgrade it's usefulness a tad. thanks
My Festool addiction fed currently by: Kapex 120, TS55R, DF500 & Domino accessories set, Rotex 125, ETS 150/3, DTS400, C12, Ti15 Impact Driver, Midi vac, Surefix Oiling/waxing Kit, OF1010 Router, Kapex 120 Wish List? Carvex420??, Belt sander with frame and planer with frame. Uncle Festool
builderbob
Offline
« Reply #1 on: May 06, 2012, 09:26 PM » |
The Incra T track works like a dream! Good luck & post photos please!
Bob
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Acrobat
Offline
« Reply #2 on: May 06, 2012, 09:44 PM » |
Hi, thanks for that suggestion of the Incra, but I'm not even sure where I'd get Incra here in NZ. (We're just a little bit away from you guys and just don't generally get the extensive range of goodies available like in the US!) I know of only 1 place that even sells t-track here in Auckland and thats miles away from where I live, so before I go off with a packed lunch I was hoping some other alternatives may be available from the big hardware type stores?.
Captainwrinkles
Offline
« Reply #3 on: May 06, 2012, 10:29 PM » |
You could try Ullrich aluminium. I'm not sure where exactly you are in Auckland, but they have stores in Otahuhu, Henderson, Silverdale and Manukau. Pretty much covers all corners of the city. They have an extensive range of aluminium extrusions in their catalogue, and they're bound to have something close to the t-track you need.  Benn
Acrobat
Offline
« Reply #4 on: May 06, 2012, 11:18 PM » |
Aha, I never thought of them. Ta. I'll look them up and see what's available. cheers
SRSemenza
Global Moderator
Online
« Reply #5 on: May 07, 2012, 12:44 AM » |
Here is a thread that discusses which brands of T Track are compatible with Festool clamps. Read through it to find additional brand updates. http://festoolownersgroup.com/festool-tools-accessories/clamp-t-track/If anyone knows other brands that are or are not compatible , it would Be great to add them to that thread. Seth
Festool Service 800-554-8741
barnowl
Online
« Reply #6 on: May 07, 2012, 07:02 AM » |
Incra T-track, and clamps.... One word of caution...the screws that come with Incra tracks have a fairly large head. I got #6 x 1/2" flat head screws.
best wishes,
Steve
TS-55, assorted rails, Domino, Kapex, OF1400, ETS 125 EQ, RO 125 FEQ, RO 90, PSB 300 EQ, CT-22, CT-26, MFT-3
SRSemenza
Global Moderator
Online
« Reply #7 on: May 07, 2012, 04:38 PM » |
Incra T-track, and clamps.... One word of caution...the screws that come with Incra tracks have a fairly large head. I got #6 x 1/2" flat head screws.   Yes, I changed out the screws when I put mine in too. I have seven tracks in my 4 x 8 bench top, running the 4' direction. Seth
Alan m
Offline
« Reply #8 on: May 07, 2012, 06:04 PM » |
Incra T-track, and clamps.... One word of caution...the screws that come with Incra tracks have a fairly large head. I got #6 x 1/2" flat head screws.   Yes, I changed out the screws when I put mine in too. I have seven tracks in my 4 x 8 bench top, running the 4' direction. Seth come on seth you must know the rules by now. we want pics
Acrobat
Offline
« Reply #9 on: May 07, 2012, 06:52 PM » |
Ooh that looks good. Exactly what I'm lookin at doin! Cheers guys.
