Author Topic: What sealer to use  (Read 2661 times)
Offline onevw
  • its mostly carbon
What sealer to use
« on: October 09, 2018, 08:53 PM »
I finally got too building a cart to hold my two MFT and 13 systainer and two CMS units.
I used Russian burch plywood and need to seal the plywood.
I am not sure what sealer to use.
So any comments would be Nice
I will post some pics of the 8 ft long 6 wheel contraption, soon.
« Last Edit: October 09, 2018, 10:45 PM by onevw »
Offline jarbroen
Re: What sealer to use
« Reply #1 on: October 10, 2018, 10:48 AM »
That's a handy looking cart.  I have a similar setup - 2 MFT but one CMS.
I was trying to figure out how to store the CMS modules/parts.  That looks like a good solution.
I'm a huge fan of the baltic/Russian birch ply.  I've used OSMO Poly-x as a finish and I'm really happy with it.  Provides a nice finish and keeps water from penetrating.  I haven't tried getting glue off it yet but I'd bet it peels right off.
The other nice thing about Poly-x is you can spot repair/re-apply.
The one downside is Baltic ply tends to be yellow and Poly-x seems to enhance that... I'm not a yellowy fan.
Offline onevw
  • its mostly carbon
« Reply #2 on: October 10, 2018, 02:59 PM »
Thanks for the reply.
I would like to see your MFT system as well.
I had to change the pullout shelf slides from 100lb slids to 220lb slides and make platform to raise the saw CMS. I needed to overlap the lags on the CMS router to fit in the distance left. I used the whole 8ft sheet.
rick
Offline Birdhunter
« Reply #3 on: October 10, 2018, 05:37 PM »
I’ve been using MinWax Wipe-On Poly on everything from bed frames to jewelry boxes. It’s truly wipe on. I use a lint free cloth to apply. It dries flat and quickly. It’s easy to touch up.
Birdhunter
Offline cubevandude
« Reply #4 on: October 11, 2018, 04:55 PM »
I second that.
Offline Pnw painter
« Reply #5 on: October 13, 2018, 12:39 AM »
A hard wax finish such as Osmo or Rubio Monocoat would work well and they are easy to apply.
Offline JimD
« Reply #6 on: November 30, 2018, 04:42 PM »
I use shellac.  I would put poly on top, however, for this because it will see wear and tear.  I keep a brush in alcohol so all I have to do is drain it and start brushing.  No cleaning, just back in the alcohol.
