Author Topic: Woodpeckers framing square  (Read 4469 times)
Offline bryan1982
« on: April 20, 2017, 07:10 AM »
Hi Guys
can anyone that has a woodpeckers framing square check the to see if the 2 metal silver rods that align the square are flush to the surface of the square.
I just recieved my 660mm square from the latest run and on one side they are sitting high by 1mm
Cheers
Bryan
Offline bnaboatbuilder
Re: Woodpeckers framing square
« Reply #1 on: April 20, 2017, 08:04 AM »
My framing square from Woodpeckers is the same. One side pins are flush, one side pins are high. I noticed it when I received it in March. thought is was odd, but I haven't contacted them to understand why.
- John
Offline SouthRider
« Reply #2 on: April 20, 2017, 08:33 AM »
Just checked mine - both in the set have a slight rise, as well as my several year old 1281 square.
Must just be a part of the manufacturing process.
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline mlkm18
« Reply #3 on: April 21, 2017, 06:01 AM »
Same on my 1281 and the 26" one
Offline JerseyDan
« Reply #4 on: February 08, 2018, 01:51 PM »
Considering the 26", but $40 for the case - one expensive piece of MDF...  https://www.woodpeck.com/psq2018.html
Offline ben_r_
« Reply #5 on: February 14, 2018, 02:19 PM »
Yea dont bother with the MDF board. Waste of money and takes up too much space to store it. Also check out ordering Woodpeckers tools from CarbideProcessors.com and use the code "creekers" to save 10%. Buying directly from Woodpeckers is never the best price no matter what they're selling.
Offline android
« Reply #6 on: February 14, 2018, 05:14 PM »
Arg, just ordered the coping sled yesterday. At least it was on sale and included the larger template that I do need.
I also ordered the 26" square. I finally realized I had no measurement tools that were actually square and I've filled in the smaller sizes with some Starrett combination and machinists squares, but I want one big square I know is correct. Big Starretts are $500 and up, so $229 doesn't seem all that bad.
Offline JerseyDan
« Reply #7 on: February 21, 2018, 10:23 AM »
Anyone know if these will accept the stops/gauges for laying out stringers?  The small brass kind...  The WP seems to be a bit thicker than a usual framing square.
Offline blaszcsj
« Reply #8 on: February 21, 2018, 12:48 PM »
@JerseyDan  I just made a cleat style holster on the side of my work bench. It was free, made from scraps and keeps it readily accessible.
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TS55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII
Offline JerseyDan
« Reply #9 on: February 26, 2018, 05:56 PM »
Thanks for the info guys. Pre ordered the 26”.
Offline Peter_C
« Reply #10 on: February 26, 2018, 09:39 PM »
It is pretty easy to make a holder out of MDF or whatever material you want. I bought a used 670mm square that came with the board, and modified it to fit my 26" square very easily with a router and a track, but I did have to add material onto the end. Wouldn't be hard to just make one from scratch. After all that is why we have tools isn't it?
Offline android
« Reply #11 on: February 27, 2018, 11:12 AM »
You would need to buy some sort of device to make sure the cutout for the square was at the correct 90 degree angle.  [big grin]
