Author Topic: Announcing: MAXSYS Wireless Remote for CT-vacs  (Read 129317 times)
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« on: March 26, 2016, 04:02 AM »
The secrecy has been killing me, but I'm excited to finally announce completion of the Maxsys wireless remote control for the CT-series of Festool dust extractors. Maxsys is not just an in-line outlet, but is custom engineered to communicate directly with the vacuum's internal control board, and fully utilize the existing, yet hidden, capabilities of the CT-Series vacuums.
Do you own a cordless TSC55 track saw, or cordless PSC420 Carvex, or any other power tool that can't automatically trigger your vac? Do you have your vac tied in to your tablesaw, or to multiple tools throughout your shop? Or do you simply have times you wish you could trigger the vac without having to walk over to it?
Well that's exactly what the Maxsys wireless remote is designed for. But most importantly of all, it doesn't interfere with any of the normal functions of your CT-vac. It will passively sit dormant and hidden, until you need it. Your power tools will still trigger the vac as normal. The Auto/Manual/Off switch still works the same as it always has. The only change to your vac is that you now have a new function that it didn't have before....wireless activation.
Maxsys talks directly with the CT-vac control board to activate the built-in autostart function, and installs in seconds. Maxsys is completely self-contained and integrated inside the existing accessory module bay, so you never have to remember to bring it with you or plug it in.
Maxsys is compatible with all Festool CT-xx series dust extractors throughout the world, regardless of voltage. (Maxsys is not available for CT-Mini/Midi extractors. Nor will it fit into CT22/33 without the accessory module bay.)
As with any RTS Engineering product, Maxsys exceeds the quality expectations that Festool owners demand. The heavy-duty remote keyfob uses a polished aluminum subframe and brushed aluminum face for durability in a rugged workshop environment, and has a protective slide cover over the buttons to prevent inadvertent activation while in your pocket. The fob is very compact, and even includes a small lanyard hook, so you can slip it in your pocket, or hang it from your tool.
Quality Control:
As with all RTS Engineering products, I perform 100% sample-rate testing. Every Maxsys module that ships will be actively tested in a live CT-vac before it ships.
Status/Pre-Order:
All research, design, testing, and prototyping is complete, and Maxsys is ready to enter the production phase. Initial orders are expected to be ready to ship within a month. The cost for Maxsys is $129.
Initial demand is expected to be high. So I will be accepting pre-orders now to get the first orders complete as quickly as possible. To get yours before the rush, visit rts-engineering.com
If you have any questions, please feel free to ask here or by emailing maxsys@rts-engineering.com.
« Last Edit: March 26, 2016, 02:03 PM by Rick Christopherson »
Online GarryMartin
Re: Announcing: MAXSYS Wireless Remote for CT-vacs
« Reply #1 on: March 26, 2016, 06:37 AM »
This looks great. Just one question; does installation invalidate the Festool warranty on the extractor?
Online neeleman
« Reply #2 on: March 26, 2016, 06:45 AM »
Does it only switch ON/OFF or also the Auto/Man?
A wireless automated outlet switch is way cheaper then.
I've got this one and it only cost €30.
Festoolian since 1998.
FESTOOL:
CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline rvieceli
« Reply #3 on: March 26, 2016, 07:08 AM »
Very nice Rick... what kind of range does it have?
What does this mean?
Online GarryMartin
« Reply #4 on: March 26, 2016, 07:27 AM »
From what I understood from the text, it doesn't interfere with the normal AUTO working of the standard outlet whereas your wireless switch would. It's a *supplement* to the standard operation allowing you to also switch the extractor on remotely.
Offline joiner1970
« Reply #5 on: March 26, 2016, 07:55 AM »
What would be better is a wireless signal from all cordless tools that triggers the extractor. Trouble is Festool would have to do that
Offline RJNeal
« Reply #6 on: March 26, 2016, 08:13 AM »
Sweet Rick. Nice add on. Been wanting one for awhile.
Rick
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
« Reply #7 on: March 26, 2016, 08:21 AM »
It means under the cover and part of the festools circuit board are two pins which are connected together by a simple relay which forms part of the aftermarket receiver.
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Offline RKA
« Reply #8 on: March 26, 2016, 09:02 AM »
I poke myself in the gut with the sliding table components on my CMS every time I'm reaching around to switch from tool activated mode to manual. I picked up a remote switch, but this is even better for the CT.  Looking forward to it!
-Raj
Offline Stoli
« Reply #9 on: March 26, 2016, 09:09 AM »
Why not run a line from the vac to a user made duplex outlet, plug your normal tool into one half, then the remote into the other.  Finally, plug a lamp into the remote outlet to simulate a load.  This seems a lot cheaper.  (BTW, I think I first saw Peter Parfait do this).
It is what I'll have to do, since I have a midi.
But, a few questions for Rick:
1) Why exclude the mini and midi?  Do they not have the module bay?
2) Is there an option to purchase extra remotes?  I could envision wanting to leave one at specific tools, and having one in my shop apron.
3) There appears to be an "A" and a "B" switch.  Could you control 2 items if an extra CT module was purchased, or is this set up as "off/on"?  In my case, I have both a CT and a full on DC, so I would love to have a remote the could interact with either.  Of course, I'd have to wire up my own relay for the DC, but could use your switch.
4) Could I complete the above by purchasing 2 sets?  This would mean that I'd somehow need to get in and hack at the frequencies.
DF500; OF1400; ETS125; CXS; installer Kit;  Kapex
Offline mike_aa
« Reply #10 on: March 26, 2016, 12:33 PM »
Looks like a nice solution.  Will you also be coming out with something similar for the Midi?
Mike A.
Offline bkharman
« Reply #11 on: March 26, 2016, 01:07 PM »
Hey @Rick Christopherson ,
I went ahead and ordered one for the simple fact that it will look seamless when installed.  I was looking at some other units that needed one part plugged in and one remote which would absolutely work, but look a bit clunky.  Glad I waited a few days!
One suggestion maybe for round two, but perhaps you could engineer the remote into a velcro sleeve like the one here.  I really like that as it would be "one less thing to misplace".  I am sure I can jerry-rig something in the meantime.
Look forward to getting this and immediately put it to use!
Cheers.  Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
« Reply #12 on: March 26, 2016, 01:12 PM »
1) Unfortunately, the Mini/Midi control board is not designed for remote activation.
2) I'll have to double check. I'm not sure that the receiver can pair to more than one remote at a time.
3) Interesting question. Yes, by default one button starts the vac and the other button turns it off. However, it can be changed with a jumper, so the same button toggles the output on/off. I'd have to experiment to see if I can pair one button to one receiver and the other button to another receiver. However, I can get a 4-button remote for you. I would have to test whether I can pair separate buttons to separate receivers. I could set up receiver to handle you dust collector.
4) No hacking required. The receivers can be paired to fobs easily.
Offline rvieceli
« Reply #13 on: March 26, 2016, 01:24 PM »
Rick - So with my CT22 there is no accessory module but the control board does have the pins for the activator for the air module. SO is it fairly easy plug and play to install your receiver? Is there a spot to install the receiver securely in the CT22?
thanks Ron
« Reply #14 on: March 26, 2016, 01:28 PM »
No. You're not modifying the vac in any way. Opening the module accessory bay is not a modification, as Festool already sells accessories for this bay.
« Reply #15 on: March 26, 2016, 01:32 PM »
Interesting Idea. I've got a friend that is doing a few things in that type of industry. He is actually looking for a product idea like the one you just mentioned. So I'll pass it along to him.
« Reply #16 on: March 26, 2016, 01:49 PM »
thanks Ron
Without a module bay, I can't specifically produce a Maxsys for the CT22. However, I have a CT22 myself, so I could look into it privately for you.
Offline rvieceli
« Reply #17 on: March 26, 2016, 02:00 PM »
Thanks, but not necessary...Yet...
You might want to change the wording on your description to make sure that folks understand that your product is designed for the CT models that have the accessory module bay. So those would be the current generation of CTs... the 26,36 and the 48 BUT not the prior CT22 and CT33.
Ron
« Reply #18 on: March 26, 2016, 02:01 PM »
Yes, there are a lot of plug-in products like that. The problem with them is that you lose all other functionality of your vac. You can no longer use tool-activated auto start, or even manual start. The only control you have is with the remote.
Maxsys works in conjunction with the CT's built-in functions. So you could literally start the vac using a TS55, and while the saw was running, press the remote, and the remote would continue to operate the vac until the other button was pressed.
Here's an example that I run into all the time: I'm running the router ploughing out dados, or something, and after a pass, I want to vacuum up the stray sawdust. So I pull the hose off the router, and then have to pull the trigger on the router to make the vacuum run. That's not very safe. With Maxsys, I can run the vac in tool-mode, and without having to change anything, I can press the button and trigger the vac without needing to turn the router on.  [thumbs up]
« Reply #19 on: March 26, 2016, 02:04 PM »
Thanks for pointing that out. I modified my original post to reflect this.
Offline Alex
« Reply #20 on: March 26, 2016, 02:47 PM »
Sorry, but this is not correct. This definitely counts as a modification when Festool does it themselves, let alone when it's done with a 3rd party module. If Festool suspects any failure is due to the use of this contraption, they can and will refuse a warranty claim.
Remember the original Dust Deputy that handled the static wrongly and fried some CT boards? Festool refused warranty. And you didn't even have to open the vac for that.
Just wondering, do they sell these accessories in the USA?
On European websites they state any module has to be installed by an authorised installer. One can deduct that not using an authorised installer will automatically void your warranty. After all, you're electrically modifying your vac.
Also wondering, is this product certified by Festool for use with the CT vacs, or any other organisation, like for instance UL? This might be of significance for those who use their tools professionally.
« Reply #21 on: March 26, 2016, 02:57 PM »
I'm sorry Alex, but you're making blanket statements without even knowing anything about the product. Unfortunately I can't debate this with you publicly because it would involve confidential information regarding Festool that I am not at liberty to discuss.
Offline Alex
« Reply #22 on: March 26, 2016, 03:22 PM »
Rick, since this requires an electrical modification of the CT vac, you'd think a multinational company like Festool has some safeguards in place. Blanket statement? This is warranty class 101. Deny every warranty on materials or modifications not specifically certified by your own company. OR done by a qualified installer.
Second, not wanting to discuss this in public is a really poor show and does not show a lot of confidence on your side.
If for instance, Festool or UL would have certified your product, it most certainly would be public information. Furthermore, considering America's eagerness to sue for large sums of money when something goes wrong I'd urge you to take all these things into consideration for your own financial security.
Offline jdm5
« Reply #23 on: March 26, 2016, 03:48 PM »
I've pre-ordered - have been toying with the idea of making something like this for exactly what Rick describes - using the router (with auto on/off functionality) and then needing to vacuum up the table/floor - really annoying to have to go back to the vac to switch it into 'on' mode.
Keep up the great ideas Rick!
Drank the green Kool-Aid...gave up counting long ago.
« Reply #24 on: March 26, 2016, 04:01 PM »
Rick, since this requires an electrical modification of the CT vac.....
Here is where you are going astray. There is no electrical modification to the vacuum. Not only am I an electrical engineer, but I am a Festool-trusted electrical engineer. My confidentiality agreement with Festool precludes me from explaining that further, but I have served as a consultant in that capacity. I'm not being shady. I'm contractually precluded from explaining.
The answer is pretty simple; if you're not comfortable, then don't buy the product. But if you do, then I will personally guarantee that it cannot, and will not, damage your CT vac. I can make that statement because I have gone to great extents to ensure that it can't happen.
Offline bobfog
« Reply #25 on: March 26, 2016, 04:04 PM »
Playing devil's advocate. Given Festool's love of expensive accessories and "system" approach, why have Festool not made one of these themselves if there's no down side to it?
« Reply #26 on: March 26, 2016, 04:09 PM »
There is no real possibility that this device could damage your vac, I would say near impossible. so a warrantee issue would not happen. If I had one fitted to my ct and the vacuum broke I would remove the remote module before it went for service. Im just surprised festool don't sell it themselves.
« Reply #27 on: March 26, 2016, 04:20 PM »
I can't answer that. I actually offered this concept to Festool over a year ago as a freebie idea to them. I had no intention to pursue it, until I realized that if I didn't, no one would. With all of the cordless tools coming out, I saw it as just too important of a feature for woodworkers to let the idea die. I sat on this idea for over 6 months before deciding to tackle it.
Offline thedude306
« Reply #28 on: March 26, 2016, 04:34 PM »
absolutely brilliant idea!  Congrats.
next step... RF module that hooks into the cordless on/off to turn on the vac.  and voila no silly remote to lose!!
Brad T.
Offline Alan m
« Reply #29 on: March 26, 2016, 04:36 PM »
this is great news rick.
given your close relationship with festool.I wonder could you get an approved by manufacturer status.
will this work on all vacs , even those out side of the usa
