Author Topic: Cadex Systainer Compressors Available for Pre-order! (US)  (Read 21494 times)
Offline Shane Holland
  • Festool Dealer
« on: November 22, 2016, 05:13 PM »
For you guys who appreciate the Systainer system, here are two new compressors coming from Cadex that will be in Systainers. The 1HP model will feature 1.9CFM at 90PSI and come in a SYS 3, available in February 2017. The 1½HP model will have 3.8CFM at 90PSI and come in a SYS 4, available in Spring 2017. You can pre-order the Cadex Systainer Compressors now from The Tool Nut.
877-866-5688
Offline Steve Rowe
  • Teach them safety when they are young.
Re: Cadex Systainer Compressors Available for Pre-order! (US)
« Reply #1 on: November 22, 2016, 05:40 PM »
Neat.  How does the noise level compare to the Rolair JC-10 compressor?
Offline bnaboatbuilder
« Reply #2 on: November 22, 2016, 06:27 PM »
This will sound nitpicky, but for what those cost $499 and $639, I hope the production units show a little more effort, the air vent grilles were hand drilled by a less than skilled person. Wonky and random holes drilled on those 2 grilles shown. Adhesive or caulk around the right air gauge. I know all this has no effect on the performance, but price and attention to detail not fully in sync. So what do the insides look like?
« Last Edit: November 22, 2016, 06:31 PM by bnaboatbuilder »
- John
Offline Samo
« Reply #3 on: November 22, 2016, 06:33 PM »
Yes, and will the 1-1/2 hp run on a 15 amp circuit without tripping the breaker?
Low amp draw motor?
Prices are steep, so want to know more about the build quality.
Offline Scarpia
  • Fairfax, Virginia USA
« Reply #4 on: November 22, 2016, 07:08 PM »
Here is a  short video from someone's instagram account https://www.instagram.com/p/BMozJWND8zC/?taken-by=krugerconstruction
(I hope it works for non-instagram account holders)
Offline Sean Ackerman
  • Festool Dealer
  • Festool Dealer near NYC - 10,000 sq feet!
    • Festoolproducts.com
« Reply #5 on: November 22, 2016, 09:44 PM »
Gents, we'll get you some of those answers ASAP or potentially get a Cadex rep in here soon 'nuff.
Offline Nat X
« Reply #6 on: November 22, 2016, 10:23 PM »
I've busted so many Systainers I'm not sure I could even consider paying this much for something that lives inside a heavily customized one I couldn't replace easily. They just aren't that durable.
  • Festool Dealer
« Reply #7 on: November 23, 2016, 08:35 AM »
@Steve Rowe, the JC10 is 62db and this unit is 68db, so very similar.
@bnaboatbuilder, I'm pretty sure this is a pre-production model. So, there will likely be some minor changes and refinements. Adding a photo of the inside below.
877-866-5688
Offline 2ooladdict
« Reply #8 on: November 23, 2016, 09:10 AM »
Db is a logarithmic scale so roughly speaking at these levels a 10db difference makes the noise level double. Difference between 62 and 68 should be seen in this context.
  • Festool Dealer
« Reply #9 on: November 23, 2016, 09:12 AM »
True, it is logarithmic. But, at lower levels, the curve is more flat, so the change is less drastic. It's 6dB more than the JC10. An increase of 3 dB is barely perceptible to the human ear.
For more context, 60-70db is the level of a normal conversation or soft music. I think the video shows the sound level pretty well.
« Last Edit: November 23, 2016, 10:01 AM by Shane Holland »
877-866-5688
  • Festool Dealer
« Reply #10 on: November 23, 2016, 11:24 AM »
Low amp draw motor?
@Samo, got a response from Cadex. They say that both models will run on a 15A circuit without issues.
To add some new info, the SYS3 will have a ½-gallon tank and the SYS4 will have a 1½-gallon tank capacity.
877-866-5688
  • Festool Dealer
« Reply #11 on: November 23, 2016, 01:38 PM »
Confirmed, the photos are of a pre-production model that was made just for demo at STAFDA.
877-866-5688
Offline CadexJamie
« Reply #12 on: November 23, 2016, 04:40 PM »
Jamie from Cadex here. The new compressor in Systainer case will be here in February and will be slightly different than the one pictured. It will have a grey lid and different gauges on it plus a lighted switch. These units are very quiet and the quality is very high. Duty cycle is 60% rather than 40% or less that is seen on most units in the construction field. The compressor may be used at at 100% duty cycle for up to 3 hours. There is virtually no vibration as the pumps and motors are balanced so as to eliminate this.
Offline rnt80
    • Agape Wood Design
« Reply #13 on: November 23, 2016, 10:15 PM »
For the record I am ready for this now.  After loading and unloading my van, including my 40+ pound awkward to carry jc10, ten times in the last three days I am really looking forward to something that fits into the systainer system.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
Offline sigmatango
  • Challenge Accepted
« Reply #14 on: November 23, 2016, 10:21 PM »
Available in Canada too?
TS55REQ - OF1400 - RO150 - CXS - T18+3 - CT26E - BR10 - KAL - MFT3 - SYS2(x1) - SYS-StorageBox - SYS-Toolbox2 -Dewalt DWS709 - Ryobi  P854 - Milwaukee 5616-20 - Kreg PRS2100 - Fuji Semi-Pro 2
Offline mattdh
« Reply #15 on: November 24, 2016, 12:22 AM »
there is a weight spec on the sys 3 - do you have a weight on the sys 4 version?  thanks!
Offline Pykie
« Reply #16 on: November 24, 2016, 03:17 AM »
Any plan to make them in 230-240v?
  • Festool Dealer
« Reply #17 on: November 24, 2016, 05:08 PM »
@CadexJamie Tagging Jamie so he sees everyone's questions.
Also, here's another video (with Jamie) talking about this new compressor. Thanks for the orders so far. If you pre-order, we will not charge your card until it ships.
« Last Edit: November 24, 2016, 05:11 PM by Shane Holland »
877-866-5688
Offline CadexJamie
« Reply #18 on: November 24, 2016, 05:39 PM »
The compressors from Cadex in Systainer cases will be available in Canada. We will make a 220 volt version in 50 Hz for overseas markets. This one will be ready in March 2017. Currently most of the first order are sold. Toolnut.com still has availability for delivery in February.
Offline antss
« Reply #19 on: November 24, 2016, 05:50 PM »
Does that mean you'll actually be able to deliver all of the pre orders in March that Shane takes ?
Offline Steve Rowe
« Reply #20 on: November 24, 2016, 05:59 PM »
Just a thought to ponder: It is interesting that Cadex can figure out a way to get a compressor in a systainer to North America but Festool can't figure a way to get a vacuum pump in a systainer to North America.
Offline antss
« Reply #21 on: November 24, 2016, 08:33 PM »
I think it's more a question of economics Steve.
Cadex pretty much has a potential customer for everyone that buys one of their nailers and will likely sell a lot of these things to non Festool customers as well as their own nail gun buyers.
Festool Vac SYS has got to be a low volume item and is not really applicable across the entire product line.  I wouldn't use one if you gave it to me for any operation we bill customers for.  I'll wager the amount of non Festool customers that buy a vac sys is pretty close to none.
So, given the UL approval process and cost it's most likely FT feels it's not worth it given sales numbers.
Offline DashZero
« Reply #22 on: April 24, 2017, 05:29 PM »
What is the status of these?
  • Festool Dealer
« Reply #23 on: April 24, 2017, 07:29 PM »
@DashZero
The latest information that I got from Cadex was that they were expected to be available some time in mid-to-late May. However, the launch date has been changed a few times, so we temporarily stopped taking orders for them until we had a solid date for our customers.
Shane
877-866-5688
Offline antss
« Reply #24 on: April 30, 2017, 07:35 PM »
Perhaps you could get Jamie to return and talk about what the production model actually has in terms of features and looks ?
That is if it's actually in production.  [unsure].
First it was Feb. then March. Now it's late May which I'm sure means June. I understand manufacturing ; and that targets move. But , to be off by two quarters usually means there's a problem with the design - or - marketing sold everyone a bill of goods.
Offline jdm5
« Reply #25 on: June 11, 2017, 06:54 AM »
Hi @Shane Holland - just curious if you had any updates on availability on these.  I'd ordered, then cancelled due to delays but would consider it again - it keeps seeming like something I could really use.
Let us know - thanks!
Drank the green Kool-Aid...gave up counting long ago.
  • Festool Dealer
« Reply #26 on: June 11, 2017, 10:13 AM »
@jdm5 the latest info from Cadex is a September availability. But they have also changed the launch date multiple times at this point so we will not take orders until we have them sitting in our warehouse. I will keep everyone posted. Thanks.
877-866-5688
Offline antss
« Reply #27 on: June 20, 2017, 06:09 PM »
@CadexJamie   @Shane Holland
Perhaps it's time for Jamie to come back and give us an update.  What's the status on these things ?  Why has delivery been delayed soooooo long ? Projection has been missed three times already and is logging six months.
Was or is this vapor ware ?  I don't think you're doing anyone any favors by dangling a product in front of qualified and market making customers, then stringing them along.  You should NEVER over promise and under deliver.  It's the biggest sin a salesman can make.
Perhaps a realistic pitch should have been made:   " this is a prototype , what do you think ?  If we get enough interest, we'll put it into production. "
Offline CadexJamie
« Reply #28 on: June 20, 2017, 06:43 PM »
It's been a lot longer than the factory thought due to sourcing motor components that are UL and CSA approved. Cadex Systainer compressors are in production now and are shipping in late August with a due date of late September. The two units I have here in Vancouver are great and preform exceptionally. Cheers
Offline antss
« Reply #29 on: June 21, 2017, 01:48 PM »
Bravo .
Thanks for the update.
So in a nutshell , the impediment was government regulation .
Offline ben_r_
« Reply #30 on: June 21, 2017, 10:38 PM »
Do we know what the retail cost of these will be?
  • Festool Dealer
« Reply #31 on: June 21, 2017, 10:44 PM »
@ben_r_ we were taking preorders at $499 for the 1hp, $639 for the 1-1/2hp.
877-866-5688
Offline jdm5
« Reply #32 on: September 14, 2017, 04:10 PM »
Any updates?
Offline antss
« Reply #33 on: September 14, 2017, 10:23 PM »
They were supposed to shop last month, but there have been at least four delays on this project so far.
Might make a nice Xmas gift.
Next year  [tongue]
  • Festool Dealer
« Reply #34 on: September 15, 2017, 08:25 AM »
@CadexJamie, can you offer the forum members an update please?
877-866-5688
  • Festool Dealer
« Reply #35 on: September 15, 2017, 02:16 PM »
Jamie responded to my email inquiry for an update.
He said the latest information is that they will be delivered to Cadex at the end of October from their manufacturer.
Shane
877-866-5688
Offline Jozsef Kozma
« Reply #36 on: September 15, 2017, 07:10 PM »
I hate to say it ,but I don't believe
anything they say anymore
Offline ben_r_
« Reply #37 on: September 15, 2017, 08:23 PM »
Nope, I gave up waiting and got a very nice, much more powerful, with a larger tank, cheaper, super quiet and very light weight California Air Tools compressor and haven't looked back.
« Reply #38 on: September 16, 2017, 01:52 PM »
Which model
Offline antss
« Reply #39 on: October 12, 2017, 10:02 PM »
Hey Shane , what is Caddx saying is responsible for all the delays?
Not only are they numerous, the length of them is substantial too.
Are these things getting rushed to market as soon as they can be built or are there actual production models being tested out in the real world ?
  • Festool Dealer
« Reply #40 on: October 12, 2017, 10:06 PM »
I would have to defer to @CadexJamie to comment on the reason for delays and what steps are being done prior to introduction to the market.
Latest I have seen is their Instagram post that these would be available in September.
https://www.instagram.com/p/BVaW5IygSVY/?taken-by=cadextools
But I have not been contacted by Cadex about their availability yet.
Shane
877-866-5688
« Reply #41 on: October 13, 2017, 12:35 AM »
I have no affiliation with Cadex, and will in all likelihood probably not purchase their new compressor, however, introducing new product into the marketplace is not an easy task, especially if you want to do due diligence and ensure the newly released product will perform to the customer's expectation level.
I understand that once a new product is announced, everyone wants to purchase it, however, even after the announcement, there will still be some alpha and beta testing of the product, and any issues found in the initial testing phases will still need to be addressed from an engineering/manufacturing/quality analysis view point. This stuff all takes time...if it was simple everyone in the world would be producing salable product.
My thought process is that it's better to have product delivered late that WORKS, than product that's delivered on time that FAILS.
Hmmmmm......Kapex just crossed my mind....
Offline antss
« Reply #42 on: October 13, 2017, 11:13 AM »
Coming from a manufacturing family, I understand what it takes to get a widget into the hands of a buyer.
What I cannot stand though is marketing with their glass half full mentality telling everyone the widget will go on sale next March, then in May telling everyone it will be Q3 only to say on Xmas eve it'll be next year.   Then nothing , then we have a big splash saying it's finally here , you can have one in Sept., I'm looking at one right now.  And six weeks later what do we have ........................
I saw better vaporware delivery times during the .com bubble days.
« Last Edit: October 13, 2017, 01:58 PM by antss »
Offline scary
« Reply #43 on: October 23, 2017, 05:03 PM »
90psi?? What can i do with that,almost set a brad?
When you order them do you pay fir them then or when they ship?
  • Festool Dealer
« Reply #44 on: October 23, 2017, 05:09 PM »
We will not be accepting any orders for these until they are in stock and ready to ship. Credit cards are billed when product(s) ship from us.
Shane
877-866-5688
Offline antss
« Reply #45 on: October 23, 2017, 06:12 PM »
Shane - have you heard from Cadex on this lately ?
Seems we are back on the merry go round.   [unsure]
They were coming in September, then October for sure; as Cadex man had actually seen a unicorn.   October is over within a couple of days.   Is xmas (next) hoping for too much ?
Offline Peter Halle
« Reply #46 on: October 23, 2017, 06:38 PM »
Didn't you read Shane's last post?  That seemed to me at least that there wasn't any more info available.
Offline antss
« Reply #47 on: October 23, 2017, 07:13 PM »
No Peter,  Shane said he didn't have them in stock.
He didn't say anything about a new release date - which is why I asked.   The last news was it would be available in October.   And that doesn't look promising .
  • Festool Dealer
« Reply #48 on: October 23, 2017, 07:24 PM »
No new information on an ETA. I will be sure to announce broadly once we have them in stock and ready to ship.
877-866-5688
« Reply #49 on: October 23, 2017, 09:36 PM »
Just to clarify Shane this company is putting you in
a sticky situation
Don’t let them ruin your reputation
This units were already on preorder a year ago
Some people paid for it full and then approximately 5 months
after they paid for it your company announces sorry
Offline live4ever
« Reply #50 on: January 31, 2018, 02:07 PM »
@Shane Holland
Any word on these from you guys, given Dan's recent post about availability up north?   [big grin]
  • Festool Dealer
« Reply #51 on: January 31, 2018, 02:11 PM »
@live4ever,
If there's still interest in the Cadex Systainer compressors, it looks like they're finally available to us now. I checked with Cadex last night when I was surprised to see Dan's post and they said they won't have more inventory until around April.
At this point, we've already started taking orders for the Rolair AirStak Systainer Compressor, which is also available in April.
Post if you're still interested in the Cadex offerings so we can gauge demand.
Thanks,
Shane
« Last Edit: January 31, 2018, 02:19 PM by Shane Holland »
877-866-5688
Offline live4ever
« Reply #52 on: January 31, 2018, 02:15 PM »
@live4ever,
I don't want to steal Dan's thread, so head over to my original thread and post if you're still interested in the Cadex offerings so we can gauge demand.
Thanks,
Shane
But...but...this IS your original thread.   [poke]
« Reply #53 on: February 01, 2018, 11:03 AM »
I like the AirStak... [cool]
I also like the price.  [smile]
Offline live4ever
« Reply #54 on: February 01, 2018, 11:22 AM »
I like the Airstak's price more, but given we're already in crazytown as far as pricing for a small compressor goes, I'd want it to be as capable as possible.
That's where the larger Cadex's 3.8 CFM is appealing.  Both the Rolair and larger Cadex are SYS4's with similar noise levels (and weights I believe?), so why not have more power in the same package?
The Cadex uses an Italian pump.  The Rolair uses one from....not sure, but China/Taiwan seems likely?  Rolair has a significant track record as a compressor manufacturer.  Cadex has barely managed to get theirs to market after many delays.
475 vs 639 (would that still be the price on the larger Cadex @Shane Holland ?).  Hmm.
« Reply #55 on: February 01, 2018, 11:34 AM »
I'd like to see a better picture of how the power cord fits (on the Cadex too).
I'd also like to see pics of how the equipment is secured inside the Sys.
The front of the AirStak looks better but what's behind the curtain?
Offline foggyideas
« Reply #56 on: February 01, 2018, 11:43 AM »
Quick peek inside via ToolNut's YouTube video:
https://youtu.be/ZOOH8x2JGg0?t=47s
« Last Edit: February 01, 2018, 11:48 AM by foggyideas »
Offline Dick Mahany
« Reply #57 on: February 01, 2018, 12:34 PM »
I like the Rolair.  I'm wondering if it is branded for them by Schneider (Sys Comp) who I believe produce 3 or 4 nearly identical units possibly  rebranded for the European market?  They've been in the compressor business for a long time
« Last Edit: February 01, 2018, 01:34 PM by Dick Mahany »
Offline ben_r_
« Reply #58 on: February 01, 2018, 01:23 PM »
Shows nothing but a metal cover. Why didnt they take that cover off and show the guts!
  • Festool Dealer
« Reply #59 on: February 01, 2018, 02:06 PM »
Guys, it's not practical for us to disassemble the Rolair Airstak that we have, especially since it's being loaned to us by Rolair. The compressor is made in China or Taiwan. Overhead pic of the interior attached, but it's all covered in sheet metal. Also, a close up of the front panel.
877-866-5688
« Reply #60 on: February 01, 2018, 02:48 PM »
@Shane Holland   how does the power cord fit in? Is the socket recessed?
  • Festool Dealer
« Reply #61 on: February 01, 2018, 04:04 PM »
@Michael Kellough, here's some pics of the power connector. The socket is recessed.
877-866-5688
« Reply #62 on: February 01, 2018, 04:11 PM »
...here's some pics of the power connector. The socket is recessed.
Nicely done Rolair. 🙏
Offline Dick Mahany
« Reply #63 on: February 01, 2018, 04:21 PM »
I just rec'd an email from Rolair Customer Service.  They verified that the new Airstack is made for them by one of their partner companies however it is NOT Schneider.  They are excited to see it realeased.
Offline TinyShop
« Reply #64 on: March 12, 2019, 02:20 PM »
Just took advantage of a site-wide coupon on that well known online auction site to purchase a Cadex Sys 4 Comp. Right before doing so, however, I called Cadex to clear up some of the confusion that exists out there regarding this compressor. According to the gentleman I spoke with, the compressor is oil-free, features a steel (not aluminum) tank, comes with a 12-month warranty and Cadex guarantees parts availability for seven years after they discontinue a product. He also offered up the name of the Italian manufacturer, FIAC, which produces compressors for the shipping industry. A quick Google search produced the following website
http://web.fiac.it/en/Index.aspx
... and marketing brochure for the "AirBox 2":
http://b2b.fiac.it/backend/Uploads/Catalogs/depl%20NUOVO%20AIRBOX2_7.pdf
Now crossing my fingers that I didn't just make an expensive mistake. lol
ETS 150/5 EQ (DE) [PO], TS 75 EQ (DE) [PO], OF 1400 EQ-F (DE) [N], CXS (DE) [N], CMS-GE [DE], CMS TS 75 (DE) [N], LA-CS 50/CMS (DE) [PO], VB-CMS (DE) [N], MFT/3 (CZ) [N], DF 700 EQ w/Seneca Small Mortise Kit (DE) [PO], FEIN Multimaster 350 QSL (DE) [N], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [N], BOSCH 1590EVS w/dust collection (CH) [N], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [N], CT SYS (DE) [PO], Milwaukee 0302-20 (US) [N], Two (2) Porter Cable 862 (TW) [N], Porter Cable 447 (US) [N], Zyliss Vise (CH) [N], Hitachi C 8FB (JP) [H]
[PO] Pre-owned   [N] New   [H] Heirloom   (XX) country of origin
