Author Topic: Cadex Systainer Compressors Available for Pre-order! (US)  (Read 21769 times)
Offline Shane Holland
  • Festool Dealer
« on: November 22, 2016, 05:13 PM »
For you guys who appreciate the Systainer system, here are two new compressors coming from Cadex that will be in Systainers. The 1HP model will feature 1.9CFM at 90PSI and come in a SYS 3, available in February 2017. The 1½HP model will have 3.8CFM at 90PSI and come in a SYS 4, available in Spring 2017. You can pre-order the Cadex Systainer Compressors now from The Tool Nut.
877-866-5688
Offline Steve Rowe
  • Teach them safety when they are young.
Re: Cadex Systainer Compressors Available for Pre-order! (US)
« Reply #1 on: November 22, 2016, 05:40 PM »
Neat.  How does the noise level compare to the Rolair JC-10 compressor?
Offline bnaboatbuilder
« Reply #2 on: November 22, 2016, 06:27 PM »
This will sound nitpicky, but for what those cost $499 and $639, I hope the production units show a little more effort, the air vent grilles were hand drilled by a less than skilled person. Wonky and random holes drilled on those 2 grilles shown. Adhesive or caulk around the right air gauge. I know all this has no effect on the performance, but price and attention to detail not fully in sync. So what do the insides look like?
« Last Edit: November 22, 2016, 06:31 PM by bnaboatbuilder »
- John
Offline Samo
« Reply #3 on: November 22, 2016, 06:33 PM »
Yes, and will the 1-1/2 hp run on a 15 amp circuit without tripping the breaker?
Low amp draw motor?
Prices are steep, so want to know more about the build quality.
Offline Scarpia
  • Fairfax, Virginia USA
« Reply #4 on: November 22, 2016, 07:08 PM »
Here is a  short video from someone's instagram account https://www.instagram.com/p/BMozJWND8zC/?taken-by=krugerconstruction
(I hope it works for non-instagram account holders)
Offline Sean Ackerman
  • Festool Dealer
  • Festool Dealer near NYC - 10,000 sq feet!
    • Festoolproducts.com
« Reply #5 on: November 22, 2016, 09:44 PM »
Gents, we'll get you some of those answers ASAP or potentially get a Cadex rep in here soon 'nuff.
Offline Nat X
« Reply #6 on: November 22, 2016, 10:23 PM »
I've busted so many Systainers I'm not sure I could even consider paying this much for something that lives inside a heavily customized one I couldn't replace easily. They just aren't that durable.
  • Festool Dealer
« Reply #7 on: November 23, 2016, 08:35 AM »
@Steve Rowe, the JC10 is 62db and this unit is 68db, so very similar.
@bnaboatbuilder, I'm pretty sure this is a pre-production model. So, there will likely be some minor changes and refinements. Adding a photo of the inside below.
877-866-5688
Offline 2ooladdict
« Reply #8 on: November 23, 2016, 09:10 AM »
Db is a logarithmic scale so roughly speaking at these levels a 10db difference makes the noise level double. Difference between 62 and 68 should be seen in this context.
  • Festool Dealer
« Reply #9 on: November 23, 2016, 09:12 AM »
True, it is logarithmic. But, at lower levels, the curve is more flat, so the change is less drastic. It's 6dB more than the JC10. An increase of 3 dB is barely perceptible to the human ear.
For more context, 60-70db is the level of a normal conversation or soft music. I think the video shows the sound level pretty well.
« Last Edit: November 23, 2016, 10:01 AM by Shane Holland »
877-866-5688
  • Festool Dealer
« Reply #10 on: November 23, 2016, 11:24 AM »
Low amp draw motor?
@Samo, got a response from Cadex. They say that both models will run on a 15A circuit without issues.
To add some new info, the SYS3 will have a ½-gallon tank and the SYS4 will have a 1½-gallon tank capacity.
877-866-5688
  • Festool Dealer
« Reply #11 on: November 23, 2016, 01:38 PM »
Confirmed, the photos are of a pre-production model that was made just for demo at STAFDA.
877-866-5688
Offline CadexJamie
« Reply #12 on: November 23, 2016, 04:40 PM »
Jamie from Cadex here. The new compressor in Systainer case will be here in February and will be slightly different than the one pictured. It will have a grey lid and different gauges on it plus a lighted switch. These units are very quiet and the quality is very high. Duty cycle is 60% rather than 40% or less that is seen on most units in the construction field. The compressor may be used at at 100% duty cycle for up to 3 hours. There is virtually no vibration as the pumps and motors are balanced so as to eliminate this.
Offline rnt80
    • Agape Wood Design
« Reply #13 on: November 23, 2016, 10:15 PM »
For the record I am ready for this now.  After loading and unloading my van, including my 40+ pound awkward to carry jc10, ten times in the last three days I am really looking forward to something that fits into the systainer system.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
Offline sigmatango
  • Challenge Accepted
« Reply #14 on: November 23, 2016, 10:21 PM »
Available in Canada too?
TS55REQ - OF1400 - RO150 - CXS - T18+3 - CT26E - BR10 - KAL - MFT3 - SYS2(x1) - SYS-StorageBox - SYS-Toolbox2 -Dewalt DWS709 - Ryobi  P854 - Milwaukee 5616-20 - Kreg PRS2100 - Fuji Semi-Pro 2
Online mattdh
« Reply #15 on: November 24, 2016, 12:22 AM »
there is a weight spec on the sys 3 - do you have a weight on the sys 4 version?  thanks!
Offline Pykie
« Reply #16 on: November 24, 2016, 03:17 AM »
Any plan to make them in 230-240v?
  • Festool Dealer
« Reply #17 on: November 24, 2016, 05:08 PM »
@CadexJamie Tagging Jamie so he sees everyone's questions.
Also, here's another video (with Jamie) talking about this new compressor. Thanks for the orders so far. If you pre-order, we will not charge your card until it ships.
« Last Edit: November 24, 2016, 05:11 PM by Shane Holland »
877-866-5688
Offline CadexJamie
« Reply #18 on: November 24, 2016, 05:39 PM »
The compressors from Cadex in Systainer cases will be available in Canada. We will make a 220 volt version in 50 Hz for overseas markets. This one will be ready in March 2017. Currently most of the first order are sold. Toolnut.com still has availability for delivery in February.
Offline antss
« Reply #19 on: November 24, 2016, 05:50 PM »
Does that mean you'll actually be able to deliver all of the pre orders in March that Shane takes ?
Offline Steve Rowe
« Reply #20 on: November 24, 2016, 05:59 PM »
Just a thought to ponder: It is interesting that Cadex can figure out a way to get a compressor in a systainer to North America but Festool can't figure a way to get a vacuum pump in a systainer to North America.
Offline antss
« Reply #21 on: November 24, 2016, 08:33 PM »
I think it's more a question of economics Steve.
Cadex pretty much has a potential customer for everyone that buys one of their nailers and will likely sell a lot of these things to non Festool customers as well as their own nail gun buyers.
Festool Vac SYS has got to be a low volume item and is not really applicable across the entire product line.  I wouldn't use one if you gave it to me for any operation we bill customers for.  I'll wager the amount of non Festool customers that buy a vac sys is pretty close to none.
So, given the UL approval process and cost it's most likely FT feels it's not worth it given sales numbers.
Offline DashZero
« Reply #22 on: April 24, 2017, 05:29 PM »
What is the status of these?
  • Festool Dealer
« Reply #23 on: April 24, 2017, 07:29 PM »
@DashZero
The latest information that I got from Cadex was that they were expected to be available some time in mid-to-late May. However, the launch date has been changed a few times, so we temporarily stopped taking orders for them until we had a solid date for our customers.
Shane
877-866-5688
Offline antss
« Reply #24 on: April 30, 2017, 07:35 PM »
Perhaps you could get Jamie to return and talk about what the production model actually has in terms of features and looks ?
That is if it's actually in production.  [unsure].
First it was Feb. then March. Now it's late May which I'm sure means June. I understand manufacturing ; and that targets move. But , to be off by two quarters usually means there's a problem with the design - or - marketing sold everyone a bill of goods.
Online jdm5
« Reply #25 on: June 11, 2017, 06:54 AM »
Hi @Shane Holland - just curious if you had any updates on availability on these.  I'd ordered, then cancelled due to delays but would consider it again - it keeps seeming like something I could really use.
Let us know - thanks!
Drank the green Kool-Aid...gave up counting long ago.
  • Festool Dealer
« Reply #26 on: June 11, 2017, 10:13 AM »
@jdm5 the latest info from Cadex is a September availability. But they have also changed the launch date multiple times at this point so we will not take orders until we have them sitting in our warehouse. I will keep everyone posted. Thanks.
877-866-5688
Offline antss
« Reply #27 on: June 20, 2017, 06:09 PM »
@CadexJamie   @Shane Holland
Perhaps it's time for Jamie to come back and give us an update.  What's the status on these things ?  Why has delivery been delayed soooooo long ? Projection has been missed three times already and is logging six months.
Was or is this vapor ware ?  I don't think you're doing anyone any favors by dangling a product in front of qualified and market making customers, then stringing them along.  You should NEVER over promise and under deliver.  It's the biggest sin a salesman can make.
Perhaps a realistic pitch should have been made:   " this is a prototype , what do you think ?  If we get enough interest, we'll put it into production. "
Offline CadexJamie
« Reply #28 on: June 20, 2017, 06:43 PM »
It's been a lot longer than the factory thought due to sourcing motor components that are UL and CSA approved. Cadex Systainer compressors are in production now and are shipping in late August with a due date of late September. The two units I have here in Vancouver are great and preform exceptionally. Cheers
Offline antss
« Reply #29 on: June 21, 2017, 01:48 PM »
Bravo .
Thanks for the update.
So in a nutshell , the impediment was government regulation .
