Pages: 1 2 [3] 4 5 6 7 8  All   Go Down
  Print
Author Topic: Domiplate Order Thread  (Read 57213 times)
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #60 on: April 07, 2011, 06:51 PM »
Hey, I see you have changed the name of your product from the Domiplate to the Domplate.     Blink Big Grin Unsure
I must have missed the contest for the new name.   Tongue Out
Corwin,  ??
Just kidding.  It has been corrected.
P
Tim2178
Offline Offline
« Reply #61 on: April 07, 2011, 07:10 PM »
Aw Man!
I thought it got changed it to my suggestion Sad.  I was all excited. HaHa.  Let the competition begin!
-Tim
TS55, FS 2700/2 raiil,  ETS 125, CT26, Domino
Corwin
Offline Offline
« Reply #62 on: April 07, 2011, 07:13 PM »
Well, when it comes to a vote, the i's will have it...   Tongue Out
To explain, while moving the thread, it was renamed "Domplate Order Thread" -- so, I couldn't resist...    Wink
PS  Tim, I thought that your suggestion was the DummyPlate?    Unsure
Shirt Size:  L
Tim2178
Offline Offline
« Reply #63 on: April 07, 2011, 07:17 PM »
No No No thats what my wife calls me so there is NO way I would suggest that!
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #64 on: April 07, 2011, 07:43 PM »
The official contest hasn't started yet.  Peter just wanted to enter early...  Big Grin
Now that you have announced an intent for a new contest, where are you going to to pst the details.  Foggers are interested.
ROCK ON RON!   Big Grin
Tim2178
Offline Offline
« Reply #65 on: April 07, 2011, 08:23 PM »
Im stickin with DomPlate. Smile I love a competition.  I can still design the logo of the winning name for you to machine into the plate if you'd like.  I'll do it free of charge.
-Tim
tms0425
Offline Offline
« Reply #66 on: April 07, 2011, 08:50 PM »
Just sent my payment.  Thanks! Tom
tms0425
Offline Offline
« Reply #67 on: April 08, 2011, 12:55 PM »
TMS0425 -- I've got you covered.  Smile
Thanks Ron!
zapdafish
Offline Offline
« Reply #68 on: April 16, 2011, 01:16 PM »
New domino owner here. Plate and domino came in about the same time but I was late in ordering the extra hardware from Festool so started experimenting without it making test joins and boxes. The domino rocks, aligns all my joints beautifully.
The domiplate is an awesome accessory. Those slots where the domino has to go vertical gave me some trouble and I could never really tell if everything was truly square. Once I slapped on the domiplate, it never came off  Big Grin. It really sped up the process as I didn't have to keep checking, double/triple checking to see if everything were flush before plunging.. I highly recommend this when he gets them back in stock.
Michael Kellough
Offline Offline
Southern New York
« Reply #69 on: April 18, 2011, 10:22 AM »
I bought a Domiplate from Ron because I didn't trust my fence.
Too often the mortise was not parallel to the work surface and using
the Domiplate the potential error in the fence is by-passed.
Turned out even with the Domiplate the mortise was still not parallel
to the work surface so there is probably a problem with my machine.
Fortunately, since the Domiplate offers a nice flat surface for mounting
to the flat bottom of the machine I could shim between the Domiplate
and the machine and get perfectly parallel mortises after all.
Highly recommended!
Michael Kellough
Offline Offline
Southern New York
« Reply #70 on: April 18, 2011, 11:15 AM »
Ron, I used plastic shim stock of .004" thickness which is held down with
3M clear packing tape so the total thickness is probably .005+.
I put a 12" rule on top of an installed domino and when the rule looked parallel
to the work shimming was done. I use color coded plastic shim stock from McMaster-Carr, item 9513K42.
Michael Kellough
Offline Offline
Southern New York
« Reply #71 on: April 18, 2011, 01:52 PM »
April 18, 2011 -- I am restocked with a good supply so if you are interested please follow the ordering instructions at the beginning of this thread.  Thanks, Ron
Just a friendly bump boost.
RonWen
Retailer
Offline Offline
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #72 on: April 28, 2011, 07:16 PM »
Here are some pictures of the Domino/LR32 bracket.  The cross strap sets angles of 0, 15, 22.5, 30, 45, 60, 67.5, 75, 90 degrees.  I should have them available for ordering next week.
« Last Edit: April 28, 2011, 07:20 PM by RonWen » Logged
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #73 on: April 28, 2011, 07:23 PM »
That Rocks!
Pricing?
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #74 on: April 28, 2011, 08:31 PM »
How do you know where you mortise is going to be located?  Are there known and repeatable offset distances for positioning/index the rig for each angle?
Corwin
Offline Offline
« Reply #75 on: April 28, 2011, 08:32 PM »
WOW!  What an interesting and unexpected design, Ron.  Well done!  I am particularly glad to see that the Domino is in direct contact with the material being machined.  Sweet!    Thumbs Up
Shirt Size:  L
VictorL
Offline Offline
« Reply #76 on: April 28, 2011, 08:39 PM »
Will it have the same center as pin hole? It's crucial for using with 32 mm grid doors.
Thank you,
VictorL
« Last Edit: April 28, 2011, 08:42 PM by VictorL » Logged
VictorL
Offline Offline
« Reply #77 on: April 28, 2011, 09:32 PM »
Thank you,
VictorL
Tell me more about that.  What you want is to be able to put in a series of round pin holes then go back through with the Domino & add a shallower mortise (centered on the hole)?  What does that get used for?
Yes.  That's for Euro style cabinets. Let say tall cabinet has two or more doors (one over another one). I need to place shelf in place where doors meet together.  With present design I have to reposition rail too. It would be helpful to place domino mortise exactly over 5mm shelf pin hole.
Thank you,
VictorL
Brice Burrell
Offline Offline
WWW
« Reply #78 on: April 28, 2011, 10:03 PM »
Thank you,
VictorL
That's what I would have liked to see.  That way you could have used the stops on the end stops to index the rail.  I'm not use what you mean by "32 mm grid doors".
VictorL
Offline Offline
« Reply #79 on: April 28, 2011, 11:35 PM »
Thank you,
VictorL
I mean door height should be H = 32mm * T
Alan m
Offline Offline
« Reply #80 on: April 29, 2011, 12:27 PM »
im not 100 % sold on this yet. a few details to conferm yet.
i would like to see a video showing it moving , setting up and cutting etc.
how ridged is it .
i would be more than willing to do a review if i got one sent over
if the price is right i will  probable buy one
now
wish list
Alan m
Offline Offline
« Reply #81 on: April 29, 2011, 04:14 PM »
im not sure i follow what people want . are they needing to drill a series of holes and then follow along with a few domino slots cut on the same centers as the holes.
i can see a benifit to this in that if you were doing a wardrobe (with 32 mm system ) and wanted to cut
slots for the bottom
a series of holes for adjustable shelfs
another row of slots for a fixed shelf
more holes
top slots.
now
wish list
GPowers
Offline Offline
Metric convert
WWW
« Reply #82 on: April 29, 2011, 06:15 PM »
I'am with you Alan, a picture would help Big Grin
I see the new Domino lr32 jig being used to insert Domino tenets as shelf pins?
« Last Edit: April 29, 2011, 06:17 PM by GPowers » Logged
Greg Powers
CutsTwice
Offline Offline
Crazy Cabinet Monkey
« Reply #83 on: June 21, 2011, 06:45 PM »
This looks very interesting. Any idea when prices and maybe a video will be available? Cheers
Life is an endless, toiled endeavor... yet tonight, I yearn for rest.
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #84 on: June 21, 2011, 07:28 PM »
As far as prices, you can go to the very first post in this thread, or:
Note, the links in this image won't work, go to the first post in this thread  Scared
As far as a video, that is a wait and see.
CutsTwice
Offline Offline
« Reply #85 on: June 21, 2011, 07:43 PM »
Oh, sorry, I was asking for the guide rail jig just above.
JimRay
Offline Offline
« Reply #86 on: June 21, 2011, 11:14 PM »
Wow! I'm late to the thread, and may have missed a comment along these lines, but the first thing I thought of when I saw the angle- adjustable design using the LR32 was the idea of using it for making louvered shutters. Don't know whether this is possible, but it is certainly moving in that direction. Has pricing been set for this new accessory yet?
Jim Ray
Jim Ray
Brian Buckley
Offline Offline
« Reply #87 on: June 25, 2011, 03:12 PM »
Jim,
   I was also thinking the jig would be super for louvered shutters. You would have to have the rail the same height as your rail's and stiles.
pugilato
Offline Offline
« Reply #88 on: July 31, 2011, 11:56 AM »
I hate to sound ignorant, but I dont understand what the dominoplate does... I searched and there's some photos of the device and not much more other than enhancements to the design.
dazzer
Offline Offline
« Reply #89 on: September 19, 2011, 11:35 AM »
bring on the video please.
Pages: 1 2 [3] 4 5 6 7 8  All   Go Up
  Print
Jump to:
