Peter Halle
Global Moderator
Online
« Reply #60 on: April 07, 2011, 06:51 PM » |
Corwin, ?? Just kidding. It has been corrected. P
Tim2178
Offline
« Reply #61 on: April 07, 2011, 07:10 PM » |
Aw Man! I thought it got changed it to my suggestion  . I was all excited. HaHa. Let the competition begin! -Tim
TS55, FS 2700/2 raiil, ETS 125, CT26, Domino
Corwin
Offline
« Reply #62 on: April 07, 2011, 07:13 PM » |
Well, when it comes to a vote, the i's will have it...  To explain, while moving the thread, it was renamed "Domplate Order Thread" -- so, I couldn't resist...  PS Tim, I thought that your suggestion was the DummyPlate?
Shirt Size: L
Tim2178
Offline
« Reply #63 on: April 07, 2011, 07:17 PM » |
Well, when it comes to a vote, the i's will have it...  To explain, while moving the thread, it was renamed "Domplate Order Thread" -- so, I couldn't resist...  PS Tim, I thought that your suggestion was the DummyPlate?  No No No thats what my wife calls me so there is NO way I would suggest that!
Peter Halle
Global Moderator
Online
« Reply #64 on: April 07, 2011, 07:43 PM » |
The official contest hasn't started yet. Peter just wanted to enter early...  Now that you have announced an intent for a new contest, where are you going to to pst the details. Foggers are interested. ROCK ON RON!  Peter
Tim2178
Offline
« Reply #65 on: April 07, 2011, 08:23 PM » |
Im stickin with DomPlate.  I love a competition. I can still design the logo of the winning name for you to machine into the plate if you'd like. I'll do it free of charge. -Tim
tms0425
Offline
« Reply #66 on: April 07, 2011, 08:50 PM » |
Just sent my payment. Thanks! Tom
tms0425
Offline
« Reply #67 on: April 08, 2011, 12:55 PM » |
TMS0425 -- I've got you covered.  Thanks Ron!
zapdafish
Offline
« Reply #68 on: April 16, 2011, 01:16 PM » |
New domino owner here. Plate and domino came in about the same time but I was late in ordering the extra hardware from Festool so started experimenting without it making test joins and boxes. The domino rocks, aligns all my joints beautifully. The domiplate is an awesome accessory. Those slots where the domino has to go vertical gave me some trouble and I could never really tell if everything was truly square. Once I slapped on the domiplate, it never came off  . It really sped up the process as I didn't have to keep checking, double/triple checking to see if everything were flush before plunging.. I highly recommend this when he gets them back in stock.
Michael Kellough
Offline
Southern New York
« Reply #69 on: April 18, 2011, 10:22 AM » |
I bought a Domiplate from Ron because I didn't trust my fence. Too often the mortise was not parallel to the work surface and using the Domiplate the potential error in the fence is by-passed.
Turned out even with the Domiplate the mortise was still not parallel to the work surface so there is probably a problem with my machine.
Fortunately, since the Domiplate offers a nice flat surface for mounting to the flat bottom of the machine I could shim between the Domiplate and the machine and get perfectly parallel mortises after all.
Highly recommended!
Michael Kellough
Offline
Southern New York
« Reply #70 on: April 18, 2011, 11:15 AM » |
Ron, I used plastic shim stock of .004" thickness which is held down with 3M clear packing tape so the total thickness is probably .005+. I put a 12" rule on top of an installed domino and when the rule looked parallel to the work shimming was done. I use color coded plastic shim stock from McMaster-Carr, item 9513K42.
Michael Kellough
Offline
Southern New York
« Reply #71 on: April 18, 2011, 01:52 PM » |
April 18, 2011 -- I am restocked with a good supply so if you are interested please follow the ordering instructions at the beginning of this thread. Thanks, Ron
Just a friendly bump boost.
RonWen
Retailer
Offline
« Reply #72 on: April 28, 2011, 07:16 PM » |
Here are some pictures of the Domino/LR32 bracket. The cross strap sets angles of 0, 15, 22.5, 30, 45, 60, 67.5, 75, 90 degrees. I should have them available for ordering next week.
« Last Edit: April 28, 2011, 07:20 PM by RonWen »
Peter Halle
Global Moderator
Online
« Reply #73 on: April 28, 2011, 07:23 PM » |
That Rocks!
Pricing?
Brice Burrell
Online
Remodeling Contractor
« Reply #74 on: April 28, 2011, 08:31 PM » |
How do you know where you mortise is going to be located? Are there known and repeatable offset distances for positioning/index the rig for each angle?
Corwin
Offline
« Reply #75 on: April 28, 2011, 08:32 PM » |
WOW! What an interesting and unexpected design, Ron. Well done! I am particularly glad to see that the Domino is in direct contact with the material being machined. Sweet!
Shirt Size: L
VictorL
Offline
« Reply #76 on: April 28, 2011, 08:39 PM » |
Will it have the same center as pin hole? It's crucial for using with 32 mm grid doors.
Thank you, VictorL
VictorL
Offline
« Reply #77 on: April 28, 2011, 09:32 PM » |
Thank you, VictorL
Tell me more about that. What you want is to be able to put in a series of round pin holes then go back through with the Domino & add a shallower mortise (centered on the hole)? What does that get used for? Yes. That's for Euro style cabinets. Let say tall cabinet has two or more doors (one over another one). I need to place shelf in place where doors meet together. With present design I have to reposition rail too. It would be helpful to place domino mortise exactly over 5mm shelf pin hole. Thank you, VictorL
Brice Burrell
Online
« Reply #78 on: April 28, 2011, 10:03 PM » |
Thank you, VictorL
That's what I would have liked to see. That way you could have used the stops on the end stops to index the rail. I'm not use what you mean by "32 mm grid doors".
VictorL
Offline
« Reply #79 on: April 28, 2011, 11:35 PM » |
Thank you, VictorL
That's what I would have liked to see. That way you could have used the stops on the end stops to index the rail. I'm not use what you mean by "32 mm grid doors". I mean door height should be H = 32mm * T
Alan m
Online
« Reply #80 on: April 29, 2011, 12:27 PM » |
im not 100 % sold on this yet. a few details to conferm yet.
i would like to see a video showing it moving , setting up and cutting etc. how ridged is it . i would be more than willing to do a review if i got one sent over if the price is right i will probable buy one
Alan m
Online
« Reply #81 on: April 29, 2011, 04:14 PM » |
im not sure i follow what people want . are they needing to drill a series of holes and then follow along with a few domino slots cut on the same centers as the holes.
i can see a benifit to this in that if you were doing a wardrobe (with 32 mm system ) and wanted to cut slots for the bottom a series of holes for adjustable shelfs another row of slots for a fixed shelf more holes top slots.
GPowers
Offline
Metric convert
« Reply #82 on: April 29, 2011, 06:15 PM » |
I'am with you Alan, a picture would help  I see the new Domino lr32 jig being used to insert Domino tenets as shelf pins?
« Last Edit: April 29, 2011, 06:17 PM by GPowers »
Greg Powers Size:XL
CutsTwice
Offline
Crazy Cabinet Monkey
« Reply #83 on: June 21, 2011, 06:45 PM » |
This looks very interesting. Any idea when prices and maybe a video will be available? Cheers
Life is an endless, toiled endeavor... yet tonight, I yearn for rest.
Peter Halle
Global Moderator
Online
« Reply #84 on: June 21, 2011, 07:28 PM » |
As far as prices, you can go to the very first post in this thread, or:  Note, the links in this image won't work, go to the first post in this thread  As far as a video, that is a wait and see. Peter
CutsTwice
Offline
« Reply #85 on: June 21, 2011, 07:43 PM » |
Oh, sorry, I was asking for the guide rail jig just above.
JimRay
Offline
« Reply #86 on: June 21, 2011, 11:14 PM » |
Wow! I'm late to the thread, and may have missed a comment along these lines, but the first thing I thought of when I saw the angle- adjustable design using the LR32 was the idea of using it for making louvered shutters. Don't know whether this is possible, but it is certainly moving in that direction. Has pricing been set for this new accessory yet?
Jim Ray
Jim Ray
Brian Buckley
Online
« Reply #87 on: June 25, 2011, 03:12 PM » |
Jim, I was also thinking the jig would be super for louvered shutters. You would have to have the rail the same height as your rail's and stiles.
pugilato
Offline
« Reply #88 on: July 31, 2011, 11:56 AM » |
I hate to sound ignorant, but I dont understand what the dominoplate does... I searched and there's some photos of the device and not much more other than enhancements to the design.
dazzer
Offline
« Reply #89 on: September 19, 2011, 11:35 AM » |
bring on the video please.
