Author Topic: NEW TSO TPG-30 Parallel Guide  (Read 28909 times)
Offline Reed Hoyer
Re: NEW TSO TPG-30 Parallel Guide
« Reply #270 on: May 15, 2019, 07:31 PM »
That makes sense, I suppose.  And I certainly understand the multifunctionalty of having the squares and the guides.  Still, for someone starting from zero, like I am, it makes this an almost 600.00 proposition.  I am sure it's worth it- just makes it a bit harder to jump on.
@Dane $600 is a big number, I agree. If I were starting my woodworking journey today, instead of 6 years ago, I think I would purchase the full TSO setup before I bought my MFT/3. While I really like the table and use it in other ways than making crosscuts, I think I'd much rather have worked from the floor on a 2" sheet of XPS foam with the TSO setup than standing up on a tiny table. It's trivial to make/purchase an inexpensive surface to use for clamping or assembly. Perfect squares and repeatable parallel cuts are tough to come by.
Offline Reed Hoyer
« Reply #271 on: May 15, 2019, 07:33 PM »
From here it looks like the tso parallel guide suffers from the same clumsy ness as the Festool. That the guide stops have to be at the ends of the material being cut. What makes the Seneca and woodpecker easier to handle is that the guide rails that connect to the cutting rails can be at at any distance as they rest on top of what they are cutting as opposed to be at the ends.
@glass1 - please help us understand what makes for "clumsiness" in the FESTOOL parallel guide (- and what you have so far seen of the TSO TPG System) ?
Your feedback may help us decide to speed up the availability of our optional TPG Rail Adapter (p/n 610-409) which accomplishes exactly what you are referring to.
Hans
The clumsiness of the Festool guides is their desire to be perpendicular to the floor rather than parallel. It appears TSO's solution eliminates that by resting its rails on the material rather than next to it.
Offline Mike Goetzke
« Reply #272 on: May 15, 2019, 09:42 PM »
Hans
When making test cuts before my first project I found my cuts to be off and initially blamed the TSO square but it was my rail. I have two 55"and one 118" Makita rails plus a 75" Festool rail. One of the 55" Makita rails was off by 3/16" over the 55" (it was new so I got it replaced). So first make sure the rail is straight.
I used my TSO GRS 16-PE square on a real project (simple bookcase) for the first time a couple weeks ago. I had to make a few 48" cross cuts. I marked both the near and far end with my cut line. I registered the square and anti-chip edge at the near side and the far end of the anti-chip was spot on the other pencil mark. I measured across the corners and dimensions were within 1/32".
I made several 10" to 12" cross cuts and had excellent results but had to mark every piece while I wait for the TSO TPG.
So, if you are cutting at least up to 48" I see no need for two squares and two sets of parallel guides putting you under $300. I haven't tried the square for a cut with my 118" rail for a full 96" rip but that may require two parallel stops. I use another jig for ripping long lengths.
Mike
« Last Edit: May 16, 2019, 08:44 AM by Mike Goetzke »
Offline BarneyD
« Reply #273 on: May 17, 2019, 04:44 PM »
I just received my TPG 20 & 30 RH kit today (had previously purchased the GRS-16) and I'm very impressed. Took me about 30 seconds to calibrate it to my guide rails. I've not tried the narrow rip rod and likely never will. I prefer to do that on the table saw. But the fit, finish, and packaging are all superb.  So kudos to Hans and Eric for a very well designed and executed product.
Barney
