Author Topic: UJK Parf Guide System - Videos  (Read 189921 times)
0 Members and 3 Guests are viewing this topic.
Offline skinee
Re: UJK Parf Guide System - Videos
« Reply #60 on: March 17, 2016, 05:35 PM »
Peter I have a question/concern,it appears from the videos that the 3mm drill guide only rides on top of the holey rule rather than positively inserting into the holes and acting like a hardened guide bush,is that the case?,if so I would be concerned that with repeated use the 3mm drill bit will wear and enlarge the holes on the rule thereby throwing off the accuracy of the whole system,perhaps a larger hole in the rule in which a hardened guide bush could locate would avoid this problem
The steel rule is hardened steel and needs a hugely expensive drill to cut it on the CNC. The very slight abrasive action of a relatively soft 3 mm drill is unlikely to cause any problems. Next time you go to your workshop try cutting a hole in one of your steel rules.    Peter
most of these jobber type drill bits are in fact not "relatively soft" as they are made of high speed steel(HSS),they are intended to drill through steel and therefore will abrade and wear the holes in this rule which will, with repeated use, enlarge them,what degree of hardness(Rockwell) are the rules? this is the only weakness in an otherwise excellent system,i suggest further production runs adopt a positively locating hardened guide bush,it would only require larger hole in the rule and a modification of the drill guide,this in my opinion would make this system bulletproof
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
« Reply #61 on: March 17, 2016, 05:44 PM »
Or you could just buy some new rulers if they eventually wear out.
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Offline Stoli
« Reply #62 on: March 17, 2016, 09:04 PM »
As others have said, very nice idea.
But the engineer in me wants to know "how square" you were able to actually achieve, instead of a simple, but unquantifiable "perfect cut".
Can you follow up with a four-cut measurement of the squareness of the cutting sheet you just created?  I actually thought you were going in this direction when you had "first cut" written on the board.  The quantification I am looking for is along the lines of: "the setup is out of square by Xmm out of Ymm".
And then compare the result to your MFT.
« Last Edit: March 17, 2016, 09:08 PM by Stoli »
DF500; OF1400; ETS125; CXS; installer Kit;  Kapex
Offline Richard/RMW
« Reply #63 on: March 17, 2016, 09:15 PM »
Hi Richard,
You have an interesting idea but it may not be necessary. The final prototype Parf Sticks show the same marks and have been used for so many holes that I could not even guess. I think it might be a pattern due to heat caused by MDF clogging of the 3mm drill. You may have noticed in the videos the higher pitch squeak when I do the 3 mm drilling - that is due to some minor MDF clogging of the small drill. The drill does get warm as one would expect.
Fair enough Peter. One of my faults is continual tinkering.
And I will repeat Kudos to you for navigating the complex design process and getting a major manufacturer to take on the project.
I have no doubt the set I ordered will be put to good use. Looking forward to the follow-on thread to this one, where everyone starts coming up with clever new ways to use holey sheet goods in the shop.
RMW
Offline bkharman
« Reply #64 on: March 17, 2016, 10:15 PM »
...  use holey sheet goods in the shop.
RMW
All I hear is a Hispanic accent saying this Richard...
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Online Peter Parfitt
  • Magazine/Blog Author
« Reply #65 on: March 18, 2016, 06:26 AM »
I have just done this and captured it on video in one take - in order to try and counter an sceptics. I started by marking my piece of board so viewers could see if I was up to mischief. I filmed the cutting in one go. I am keeping the pieces as they are and I am happy for any visitor to examine them.
The results will be up with the video in about 8 hours from now - I have a string of very interesting visitors at the moment !
Offline bobfog
« Reply #66 on: March 18, 2016, 06:43 AM »
Don't think it's about "sceptics". £100 is far too expensive if it doesn't cut the holes absolutely square and an absolute bargain if it does as you'll have MFT tops for life. Don't take people's question as scepticism, just due diligence and curiosity.
Looking forward to the 4 cut video.
Offline Pizza Steve
« Reply #67 on: March 18, 2016, 07:25 AM »
Overuse of "PGS" for sure!  [eek]
When I see PGS I think Parallel Guide System.  A unique product needs a unique name.  Now I'm going to be confused...  [unsure]
Nice idea.  Lots of passes required, though.
Offline Richard/RMW
« Reply #68 on: March 18, 2016, 07:37 AM »
RMW
Cheers. Bryan.
Bryan, picture me reading this, puzzled look, re-reading it, still no comprehension, slowly saying it out loud in my best Baba Looey imitation (eh', Queeksdraw...") and finally comprehending...
Yes, I laughed out loud.
RMW
Offline Amalix
« Reply #69 on: March 18, 2016, 12:03 PM »
Absolutely fantastic Peter! This will surely be on my shopping list the next time I order from Axminster, they ought to be quite happy with your recommendations. I'm sure I'm not the only one placing repeated orders solely because you recommended them.
I do have a question, I plan on making an assembly table with holes and would like to double up on the MDF for strength. Due to space constraints the table will also function as router table. Probably with the Incra LS as fence. Will the drill-bit be long enough for drilling 40 millimeter deep allowing me to screw fasten my parf dogs from underneath?
Offline bkharman
« Reply #70 on: March 18, 2016, 12:49 PM »
RMW
Cheers. Bryan.
RMW
Same genre but I was hearing Speedy Gonzalez!
Man I miss the 70's and 80's!!
Glad you got a laugh out of it.
Cheers. Bryan.
« Reply #71 on: March 18, 2016, 01:34 PM »
I think that it will be about 8 mm short of going through without having a really short amount in the chuck. It is not much of a problem if you would be happy to complete the last 8-10 mm by hand - by then the 20 mm hole already drilled will provide the accuracy for Parf Dog alignment.
« Reply #72 on: March 18, 2016, 02:38 PM »
Hi Everyone
I have made a video that shows the 4 cut test being done in the track saw cutting station that I created using the UJK Parf Guide System. Here is the link:
Offline promark747
« Reply #73 on: March 18, 2016, 04:18 PM »
Hi Everyone
Thanks Peter.  If my trig is right, your result of 0.34mm over 402mm is about 1/20 of 1 degree.  I've done 5-cut tests on my Festool MFT/3 (using Parf dogs, of course) and the results have been about the same as that.
Edit: Actually, your results may be better than 1/20 of a degree -- I forgot to divide by 4 for the 4 cuts.  You may be closer to 1/80 of a degree.
« Last Edit: March 18, 2016, 04:21 PM by promark747 »
« Reply #74 on: March 18, 2016, 04:21 PM »
Excellent. The MFT3 is probably produced on a CNC so I am pleased with that.
Many thanks.
Offline Stoli
« Reply #75 on: March 18, 2016, 05:42 PM »
Thanks -- I guess I was the one that provided the "challenge", but I hope it did not come across as confrontational.
What those numbers mean is that if you were to do a cut that was 1608mm long, you'd be out of square by 0.3mm, which by all measures should be acceptable.
Your value of 0.0002 is in radians.  This can easily be converted to 0.2millirad.  To convert to degrees (for angles this small) you multiply by 180/pi which comes out to 0.011 deg, or 0.69 minutes of arc (arc minutes), or 41 seconds of arc (arc seconds).
« Last Edit: March 18, 2016, 05:50 PM by Stoli »
« Reply #76 on: March 18, 2016, 05:55 PM »
What those numbers mean is that if you were to do a cut that was 1406mm long, you'd be out of square by 0.3mm, which by all measures should be acceptable.
Those who know my real background will understand that I love a challenge and I must say that I am really grateful to be encouraged to check this out. I did not realise just how accurate the PGS might be other tan putting my engineer's square across a cut.
I think that in all fairness that results may vary by a little up and down depending on so many other factors. Even so, the overall accuracy is such that even with a poor following wind the results are still far better than most woodworking tasks demand.
Thank you.
Offline bobfog
« Reply #77 on: March 18, 2016, 05:59 PM »
I don't understand half of that [big grin]. But the headline figure of 0.3 MM over 1.6 metres should be more than acceptable for any form of joinery.
Offline mwildt
« Reply #78 on: March 18, 2016, 06:01 PM »
Great video Peter, and thank you going above and beyond and doing the test. I also hope that my request wasn't seen as negative, which certainly wasn't the intention. Always good to have a test to back it up.
Looking forward to see it on this side of the pond.
Spot on!
« Reply #79 on: March 18, 2016, 06:03 PM »
... you managed to get to half - well done. I ran out of fingers  before we got to the clock stuff - I think I will stick to woodwork and leave this detail to Steven Hawking.
Offline Stoli
« Reply #80 on: March 18, 2016, 06:28 PM »
It would still be interesting to compare this value to one from an MFT.  Then you can make quantifiable claims.
BTW, you pointed out the "squishiness" of the MFT as a factor in the measurement.  That is true.  The measurement is also more than just the errors in the layout.  How well the parf dogs fit in the holes, as well as your "process" (e.g. always pushing one one side) are included.
« Reply #81 on: March 19, 2016, 01:50 AM »
The Parf Guide System uses a very precise "20 mm" drill which with the equally precise Veritas Parf and Small Bench Dogs produces an excellent fit. Those same dogs in the MFT move around a little more and hence may contribute to some loss of accuracy.
It is not right for me to criticise the Festool design as they did not originally intend the MFT3 to be used with dogs for accurate cutting - they have their own solution (which adds more than the cost of the PGS to the price).
« Reply #82 on: March 19, 2016, 03:02 AM »
It was silly of me to think that you need to drill the dog holes all the way through. On my own mobile bench the place where the Parf Dogs go is 55 mm thick. I have drilled the 20 mm holes about 25 mm deep and then, by hand with no guide, continued those holes but with an 8mm brad point to allow for the bolt to fix the Parf Dogs in place.
I do not routinely fix the Veritas Small Bench Dogs in place and so those holes can just stop at about 25 mm. In my 4 cut test video the Small Dogs were just loose and not secured at all. The Parf Dogs were screwed from undersneath in the normal way.
Offline VW MICK
« Reply #83 on: March 19, 2016, 05:07 AM »
Hi Peter
Looks Like a very well thought out idea. I'm ok for holes at the moment but will definatly get one as the need arises. I could see it become addictive and every horizontal surface becoming peperd with holes
Just a thought. With another guide bush and drill bit and maybe a couple more holes it could it be used as a LR32 system ?
« Reply #84 on: March 19, 2016, 01:05 PM »
Hi Peter
There will be some optional extras in due course to enhance the system as it stands.
Offline Ollie
« Reply #85 on: March 19, 2016, 04:25 PM »
Hi Peter
I will certainly be getting this set up once they are back in stock.
It is simple and effective as are almost all the great ideas, a classic case of "why didn't I think of that".
I plan to make a new top for my MFT along with one for a set of Toughbuilt trestles to make a large sturdy portable set up.
Also I think I could use this in making jigs for use on the spindle moulder and all sorts of stuff.
I must say thank you for your excellent video content on youtube, I appreciate your thorough approach and unlike many other woodworking videos I am seldom left with more questions than answers at the end.
I wish you great success with your invention and hope to see more good woodworking content soon.
Ollie
« Reply #86 on: March 20, 2016, 02:50 AM »
Hi Ollie,
Thank you so much for your post - it has really made my day and has helped me decide to do the rest of the work on the first "PGS Xtras" video.
Cheers.
Offline Jonnio
« Reply #87 on: March 20, 2016, 12:23 PM »
Thanks Peter for the 4 cut test. I was on the edge of my seat!! Dont think anyone would think you would cheat! Ive just ordered mine from axminsters on backorder to make myself one for my 8ft x 4ft workbench that ive just made with a completley coplanar surface. Cant wait. Keep up the good work, cheers. (Youtube subscriber, jwardimages)
« Reply #88 on: March 20, 2016, 01:24 PM »
The only thing to watch on your 8 x 4 work bench is how to clamp the Parf Sticks as you create the core set of 3 mm holes (the first row along the top and the first two columns on the left and right). I can do this with my small collection so if you need help just say.
You will have to post some pictures when you are done.
Offline Jonnio
« Reply #89 on: March 20, 2016, 03:03 PM »
Will do Peter. Thanks for the offer of help!
