Author Topic: Woodpecker Slab Flattening Mill  (Read 800 times)
Offline Dan Clermont
  • Festool Dealer
  • Canadian Festool Dealer
    • Ultimate Tools
« on: March 13, 2019, 02:14 AM »
Hello Everyone
We are pleased to announce we will be carrying the new Slab Flattening Mill for our Canadian Customers. This is a pre-order for the Mills and we hope to have stock shortly
We suggest you consider purchasing the Festool OF2200 for the process
OF2200EB Routah!!!
and one of our Spoil Board Bits
Dimar Spoil Board Bit with Carbide Inserts
or
Whiteside 2" Spoil Board Bit
Best Regards
Dan Clermont
Canadian Festool Dealer and User!!!
https://www.ultimatetools.ca/
604.291.9663
Offline Brian Livingstone
Re: Woodpecker Slab Flattening Mill
« Reply #1 on: March 13, 2019, 07:24 AM »
Hi Dan,
Good to know.  I am saving up for one.
I already own a 2200.  Looks like an impressive tool !
Talk to you soon I hope.
Brian
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
  • Festool Dealer
    • Ultimate Tools
« Reply #2 on: March 13, 2019, 06:45 PM »
Hi Dan,
Brian
Hello Brian
You know who to call once you are ready!!!!
Best Regards
Dan Clermont
604.291.9663
Offline ear3
« Reply #3 on: March 16, 2019, 08:28 AM »
It would be nice if Woodpecker offered up shorter extrusions as an extra/add on.  The extended kit gives you another pair of 6ft extrusions, but that means if you have to cut, say, an 8ft slab, you have to switch the router sled over to the first pair of 6ft extrusions and then build out the rails to 10 ft. long by combining the 6ft. + 4ft.  Or use the 6ft. rails and then move them to get at the last two ft. of the slab.
It would be nice if they offered the option of an extra pair of 2ft. or even 4 ft. extensions.
I assume the profile they are using is proprietary, and not available in the 80/20 catalog?
Offline rst
« Reply #4 on: March 16, 2019, 02:37 PM »
Just cut a 6'er into two 3'ers..gives you 9', should be enough to rout 8'.
