Pages: [1]   Go Down
  Print
Author Topic: C12 Trigger Intermittent  (Read 1712 times)
wood pulp
Offline Offline
Each another's audience...
« on: February 27, 2011, 09:26 PM »
Lately, and randomly, my C12 trigger when pulled does not work.  I may pull it once and nothing, then again and it is fine???  Does, or has anybody experienced the same?  The drill is maybe a year old.
Shane Holland
Festool USA Employee
FOG Administrator
Offline Offline
WWW
« Reply #1 on: February 27, 2011, 09:35 PM »
Within the first year of warranty, we pay shipping to and from the repair center. The next two years, you're responsible for shipping to the repair center. Since it's under warranty, I'd call the service department. Their number is below in my signature. I'm sure they will take good care of you. Alternatively, send me your contact information and a convenient time and I'll have them call you.
If the trigger has been gummed up with dust, etc. then you might be able to try some contact cleaner.
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
WarnerConstCo.
Offline Offline
WWW
« Reply #2 on: February 27, 2011, 09:44 PM »
I may be wrong but, isn't the trigger in the c-12's solid state?
Festoolfootstool
Offline Offline
The trouble with Bob is its all about Bob
« Reply #3 on: February 28, 2011, 03:34 AM »
I think shane is sugesting spraying the switch area from the outside of the machine,but this advice could be misunderstood as if it was sugested to me I would take the machine apart to gain access to the switch and i'm sure shane is not sugesting that.
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Rick Christopherson
Retailer
Online Online
WWW
« Reply #4 on: February 28, 2011, 01:16 PM »
The first thing that came to mind as I read this is that it might sound like a suggestion to take the switch apart. Whatever you do (the OP), Don't Take the Switch Apart!! I took one apart 5 years ago to learn about it, and I still haven't found the spring that flew out into my office somewhere.  Scared
The switch is a combination of mechanical and solidstate contacts, with a printed circuit resistor for speed control. Unlike normal drills without EC-TEC technology, battery power does not pass through the switch. The switch is just a low-power resistor that controls a "clock" inside the PWM controller. There is a safety feature of the EC-TEC controller on the C12 drill that prevents the motor from starting if you are pulling the power trigger at the same time the controller receives power (like plugging in the battery). An effect of this safety feature is if the controller sees a sudden jump in the resistor position, it activates the safety feature. This is to prevent injury by not allowing the drill to start unexpectedly during a battery change. (If memory serves me).
As Shane pointed out, your best solution is to send the drill in for repair.
I don't recommend spraying in a contact cleaner through the handle because none of it will make it into the switch body. I also don't recommend taking the drill apart (unless instructed to do so by a service technician) because you will have to cut or remove the clutch position decal.
The best "quick fix" is to simply "exercise" the trigger in and out. If there is a piece of dust between the solidstate resistor and the wiper, this will frequently swipe it out of the way.
wood pulp
Offline Offline
« Reply #5 on: March 03, 2011, 12:36 AM »
Thanks for the info!  Shane, so if I took your advise and cant get it back together, after spraying it with contact cleaner, is it fair to think you will be sending me a new T-15 for replacement. Grin
I will keep an eye on it.  So far it only does it when I am feathering the trigger a few times in a row.  By the way, how do you quote others and have it show up in a space all by itself?  Or, quote only part of comments?
Pages: [1]   Go Up
  Print
Jump to:
