RL
Offline
« Reply #60 on: September 20, 2010, 05:19 PM » |
Hopefully the North American models will have the fixes incorporated before they arrive here in 2011.
I like green.
jmbfestool
Offline
« Reply #61 on: September 20, 2010, 05:41 PM » |
Carvex Update
I have now had my re worked Carvex back for about 10 days and have given it a very thorough shake down before posting back here.
I received it back from Germany with a letter of explanation as to the cause of the problems and a list of the parts that have been replaced or upgraded.
The guy who became involved, to sort it out, holds a very senior post in Festool Germany and over saw the whole process of the reworks, modifications and upgrades. He states in the report that he did the final QC and test cuts and that the operation my Carvex now is to his standards and expectations. I thought my standards and expectations were high but they are dwarfed by his.
The thing is amazing; I even checked the serial numbers and the work blemishes as I could not believe it was the same saw. It s cut and operation is remarkable and beyond anything I thought a jigsaw was capable of producing.
I have just about done everything and anything you can do with a jigsaw over the last few days and cut every material I could think of . In every case the Carvex performed above and beyond my expectations.
Some here will say what is the point of this post, well it's simple.
If you own a Carvex and are having problem with it, e.g.
Blade jumps out of the v guide.
It is not cutting square.
The quality of the cut is poor.
You have any rotational movement in any of the bases.
You are burning and bluing blades more than normal
It will not follow a straight line.
It will not follow smoothly curves.
It will not follow on the guide rail or any other fence (i.e. Speed square or guide baton)
You cannot get near perfect circles using the attachment.
The dust port does not firmly attach to the bases and pulls out easily during use
The blades release over shoots the mechanism.
The above are problems know to Festool and they now have reworks to correct them.( By now this information should have been disseminated to the various national companies and service departments of the countries into which the Carvex is now being sold ) and you should return it for repair.
Just one more point, there has been posted on here a ?fix? for the Carvex, (removing and bending a spring) I would not do it . This item was not replaced and you may invalidate your warranty.
Its a simple spring something like that shouldn't void the warranty if it does its ridiculous. Also how can they prove you have done something to the spring you cant tell. I will be showing this post to my festool rep as he is still saying their is nothing mentioned about any carvex problems so basically he doesnt believe me. Thank you for that info by the way! JMB
Rob-GB
Offline
« Reply #62 on: September 21, 2010, 12:26 PM » |
Sorry to jump in here, as I don't have a Carvex (yet!) but going back a few posts it was mentioned that the carvex does not have the carbide guides that are adjustable. Instead it has a 'V' guide and a leaf spring (visible in JMB's pics, Ta for those by the way) does this arrangement make or is it meant to make the guide self adjusting to suit differing jigsaw blade thicknesses? You know what Festool is like they come up with a clever idea and try not to let us in on it!  If it is an auto adjuster system then I think it is flippin clever! I don't mind adjusting my Trion guides because I appreciate the benefit of doing so, but if I can save some time I'll drop Santa a brief missive.  Rob.
Problem? No such thing! Only a solution waiting to be found:- RJ
"A $2 guppy swims......" Deke
windmill man
Offline
« Reply #63 on: September 21, 2010, 12:35 PM » |
Hi Rob, Yes it is a type of auto adjustment system. You can swap between any blades with out having to adjust anything.Just tell Santa to get you one manufactured after June 2010 and all will be good.  John
jmbfestool
Offline
« Reply #64 on: September 21, 2010, 01:55 PM » |
Yes just like John said its its kinda like a auto adjuster. The thinner the blade further it goes into the groove. It is clever! I own a cordless Milwaukee M18 jigsaw aswell and I have some really long blades which are also thicker well they dont fit in the wheel they just sits in front of it not very good really. Still good jigsaw thought! Still didnt stop me from buy the cordless carvex though lol The Milwueakee one of for site work well thats what I tell my self any way.
Using the jigsaw a lot maybe a year down the line the V groove must wear out how would you replace it?!?! Looking at it it wont come off easy. Like my Milwaukee most jigsaws have a wheel so it turns when the blade goes up and down so it wont wear the wheel out but the V is stationary and the blade is rubbing it up and down all the time. I know its harder metal but it must still wear eventually.
JMB
windmill man
Offline
« Reply #65 on: September 21, 2010, 02:50 PM » |
Evening JMB
If memory serves me right, The V guide plate is sprung loaded. The piece you removed in you video is the bit that gives it , its loading. That`s one reason I would no bug about with it. Above the V guide is a hardend steel nub.
The Carvex carries its blade slightly more forward than most Jigsaws. So as you cut the blade is not against this nub but is "supported" by the sprung loaded V guide. If you increase the cutting pressure the guide retreats and the blade rubs against the hardened nub . If you increase cutting pressure again it will start to blue the blade because of the friction. The nub is a lot harder than the blade. So wear should not be a problem.
John
joiner1970
Offline
« Reply #66 on: September 21, 2010, 03:59 PM » |
I wonder if those carbide guides that were on the Trion have been scrapped for good reason. I have just been sent Bosch's new jigsaw the GST 150 CE to test out and give my opinion on, and the first thing I noticed was that they have also removed the carbide guides that they had on their other model. I seem to remember lots of people moaning about blades burning etc on both the Trion and the Bosch jigsaws. By the way the Bosch is a very nice jigsaw
Brice Burrell
Offline
Remodeling Contractor
« Reply #67 on: September 21, 2010, 04:41 PM » |
I wonder if those carbide guides that were on the Trion have been scrapped for good reason. I have just been sent Bosch's new jigsaw the GST 150 CE to test out and give my opinion on, and the first thing I noticed was that they have also removed the carbide guides that they had on their other model. I seem to remember lots of people moaning about blades burning etc on both the Trion and the Bosch jigsaws. By the way the Bosch is a very nice jigsaw  Can you share your opinion of the Bosch here on the forum?
Ken Nagrod
Restricted
Offline
« Reply #68 on: September 21, 2010, 04:45 PM » |
Here's my 2 cents. I've owned the Bosch 1591 barrel grip since it came out. Love the thing. I've cut almost everything imaginable, except myself. Never had a problem with it. I tried the newer version at the Baltimore trade show and even though it's got a bigger, more powerful motor, I didn't like it. Too big and bulky, so no advantage to me. Also the blade change mechanism is different. Softer blade ejection. I like the old ejection a little better, but that's not the deal breaker for me. The weight and larger barrel grip are the killers. They also got rid of the toolless base (bevel) adjustment in favor of an on-board hex wrench. I didn't notice the new blade guide being any better than mine and never had an issue with blade problems, even using the push-in guides frequently.
« Last Edit: September 21, 2010, 04:50 PM by Ken Nagrod »
windmill man
Offline
« Reply #69 on: September 21, 2010, 05:21 PM » |
Festool are keeping the Trion in its Jigsaw line up.
From what I can gather the Carvex with the new V guide is supposed to be more of an all rounder and better at curved work.
Ken Nagrod
Restricted
Offline
« Reply #70 on: September 21, 2010, 05:27 PM » |
Brian Sedgeley told me that the Carvex has a more refined and comfortable grip. He thought they couldn't improve their previous design, but they did. Maybe you guys that already have one can comment on that too?
jmbfestool
Offline
« Reply #71 on: September 21, 2010, 05:27 PM » |
Evening JMB
John
Alrite John I understand. Just to confirm when I meant the V is stationary I didnt mean it as it doenst move but I ment it doesnt move with the blade up or down so the blade is running up and down while the V stays in the same place but just moves back and forth as more pressure is applied like you said. Increasing the strength of the spring by bending it will increase the V pressure which should hold the blade more which should in theory keep the blade straighter. I really only did the video on how to remove the spring because the other guy was showing how to remove it with some pliers but I found a easier how to remove and attach the spring back thats all really. Showing off [embarassed]lol JMB
windmill man
Offline
« Reply #72 on: September 21, 2010, 05:29 PM » |
Ergonomically and design wise it is superior to the Trion
windmill man
Offline
« Reply #73 on: September 21, 2010, 05:37 PM » |
Hi JMB Think there is more to the design of the Carvex than meets the eye. The V guide is just a guide . ( In the trion it seems to act more like a lateral support)Think the spindle and how it works and its position in relationship to the guide is the key to its performance. I also think the way the blade locks into the spindle and how it is held also have a lot to do with it.
John
jmbfestool
Offline
« Reply #74 on: September 21, 2010, 05:43 PM » |
John
How a blade is held is import like you said well the Maffel Jigsaw just rely on that welll held blade and nothing els! The advantage to that is you can turn the blade around and have if facing backwards so you can jigsaw backwards away from a wall so you can start closer to a wall. Innovative CUmax sawblade clamping ensures a positive fit because of a wedge pushing against the blade. This design reliably fastens the sawblade so that it cannot be displaced.  JMB
Michael_MA
Offline
« Reply #75 on: September 21, 2010, 06:56 PM » |
Just to add some information to the V-Guide of the Carvex..
it is definitly out of best machined CARBIDE MATERIAL, which required erosion or laser cutting to get in shape. This V-Guide is soldered to the holder like the teeth of the blades of the TS circular saws.
So, there is simply no way to wear out the groove by using regular Jigsaw blades, even if you push the blade as heck. And Yes, it does an Auto Adjustment, as it is pressing the V-Groove against the saw blade and therefore centering and guiding the blade.
kind regards, Mike
"..The only thing necessary for the triumph of evil is for good men to do nothing.." - Edmund Burke, British Statesman and Philosopher -
Festool addicted since 2004
Michael_MA
Offline
« Reply #76 on: September 21, 2010, 07:15 PM » |
John
How a blade is held is import like you said well the Maffel Jigsaw just rely on that welll held blade and nothing els! The advantage to that is you can turn the blade around and have if facing backwards so you can jigsaw backwards away from a wall so you can start closer to a wall. Innovative CUmax sawblade clamping ensures a positive fit because of a wedge pushing against the blade. This design reliably fastens the sawblade so that it cannot be displaced. [ ERROR: SPECIFIED ATTACHMENT MISSING ] JMB Well, the Mafell Jigsaw is also very nice from it's design and features.. besides, it's weight (2,5 Kg) and size, it requires special CUMax Sawblades, which are rarely to get on the market, except from mafell, because they have welded two saw blades together and nobody else does this.. The Shortcoming of this is the price - in Germany, 2 CUMax sawblades cost about 30 Euro, which is raughly 37 $.. In the German Woodworker forum, some colleagues told from the Fair in April, that the people at the booth of mafell showed their Jigsaw with 1 inch chipboard and ply telling the people near by, they should stand clear, as the saw blade could simply pop off during curve cutting.. and it did ! - nobody was hurt furtunatly.. Festool showed the Carvex first time with 40mm melamin lam?nated Kitchen tops and ply wood.. notheing fell of.. actually, there is also a video from the fair on youtube:
joiner1970
Offline
« Reply #77 on: September 22, 2010, 01:05 PM » |
I wonder if those carbide guides that were on the Trion have been scrapped for good reason. I have just been sent Bosch's new jigsaw the GST 150 CE to test out and give my opinion on, and the first thing I noticed was that they have also removed the carbide guides that they had on their other model. I seem to remember lots of people moaning about blades burning etc on both the Trion and the Bosch jigsaws. By the way the Bosch is a very nice jigsaw  Can you share your opinion of the Bosch here on the forum? Yeah Brice Im sure Bosch wont mind its all good publicity for them I suppose. When I get a chance I will do a review. Ive only had it a week and a half now not really put it to the test properly yet. I put my name down about a month or so ago on the Bosch website to become a tester and I was lucky enough to be picked they then sent me out the gst 150 ce as it was what I chose to test. I wanted to try out a barrel grip jigsaw as Ive never used one, here in the UK most people use the D grip type jigsaw. It looks like the barrel grip is much more popular your side of the pond. Chris
William Herrold
Offline
"failure is imminent"
« Reply #78 on: September 24, 2010, 03:04 PM » |
John
How a blade is held is import like you said well the Maffel Jigsaw just rely on that welll held blade and nothing els! The advantage to that is you can turn the blade around and have if facing backwards so you can jigsaw backwards away from a wall so you can start closer to a wall. Innovative CUmax sawblade clamping ensures a positive fit because of a wedge pushing against the blade. This design reliably fastens the sawblade so that it cannot be displaced. [ ERROR: SPECIFIED ATTACHMENT MISSING ] JMB Well, the Mafell Jigsaw is also very nice from it's design and features.. besides, it's weight (2,5 Kg) and size, it requires special CUMax Sawblades, which are rarely to get on the market, except from mafell, because they have welded two saw blades together and nobody else does this.. The Shortcoming of this is the price - in Germany, 2 CUMax sawblades cost about 30 Euro, which is raughly 37 $.. In the German Woodworker forum, some colleagues told from the Fair in April, that the people at the booth of mafell showed their Jigsaw with 1 inch chipboard and ply telling the people near by, they should stand clear, as the saw blade could simply pop off during curve cutting.. and it did ! - nobody was hurt furtunatly.. Festool showed the Carvex first time with 40mm melamin lam?nated Kitchen tops and ply wood.. notheing fell of.. actually, there is also a video from the fair on youtube: Festool Carvex on the German Woodworker Fair 2010Thanks for posting that video Michael... I almost fell off my stool. I have been a little confused over why folks have been so wound up over the Carvex until now- thinking...*how could a jigsaw really be improved?* Iv'e been satisfied with my Trion, and even the Bosch industrial models for many years. It looks like What that rep did in the video with the Carvex is astounding.
"I don't believe anything, but I have a lot of suspicions" R.A.W.
decoy
Offline
« Reply #79 on: October 29, 2010, 05:53 AM » |
I haven't experienced any of the mentioned problems with my Carvex (ps400), but am I the only one who finds the autospeed-function kinda annoying for precision work? It slows down so much that the vacuum has trouble removing the MDF dust, making it hard to see where I cut. I'm not 100% sure how Carvex-speed is connected to dust extraction, but the visibility does get worse when I slow down :-/
Also, the top-speed on auto seems to be higher than the top-speed I can set manually?
« Last Edit: October 29, 2010, 06:40 AM by decoy »
T18+3, KS 120 UG-Set, TS 55 EBQ, RO 125 FEQ, PS 400 EBQ, QF 1010 EBQ, DF 500, MFT/3, 2xCTL 26E , TS&PS-CMS + loads of extra gadgets. Junkie.
jmbfestool
Offline
« Reply #80 on: October 29, 2010, 08:31 AM » |
Yes thats true! I noticed that when you set the manual at the highest its no where near as fast as when its on auto! I dont know why that is. I think it should have a second auto! Auto on/off! Soon as you put pressure it slowly turns on to full speed and when you stop after 1 second it turns off. Its because I still have not go use to using barrel grip jigsaws. I can not see how people think barrel grip you have more control than D handle. With D handle you can slowly pull the trigger to gradually increase the speed to full and then stop straight away by releasing the trigger. I often have to reach for the off switch on the Carvex barrel grip so it takes my attention away from the blade cutting the material. Its okay if your cutting material off its just when you stop half way in the material. You have alot more control with D handle.
woodguy7
Offline
« Reply #81 on: October 29, 2010, 01:21 PM » |
Decoy You don't have to use the "auto" function. If doing fine work & you want it fast then just turn the dial up
If its made of wood, i can make it smaller. Shirt size medium p.s- ive started reading these too
decoy
Offline
« Reply #82 on: October 29, 2010, 02:25 PM » |
You don't have to use the "auto" function. If doing fine work & you want it fast then just turn the dial up  Eh.. of course I have to use it. It's something my previous jigsaw didn't have. It's cool!  But it doesn't work as good as I hoped.
jvsteenb
Offline
« Reply #83 on: October 30, 2010, 12:42 PM » |
I can not see how people think barrel grip you have more control than D handle. I like a D handle as much as the next guy, but when sawing from underneath ( you look on top but the saw is under the workpiece ) the barrelgrip shines. It is a fine way to get the best part of the cut in visual range. Guiderail work is hardly possible when sawing from underneath, but I hardly ever use the guide rail when using my Trion. However, following a scribed line is easy when the machine isn't blocking the view. Most of the dust will be below the plate as well, and the efficiency of dustcollection wiyh my Trion is significantly improved if I saw from underneath. Sawing in this position is close to impossible with a D-grip saw, unless it has a locking switch. For "sawing from the top" I too prefer the D-handle, but in that setting the barrelgrip works OK as well, so in my book it's the best of both worlds, really. Regards, Job
TS55, OF1010, RO150, RTS400, PS300, T15+3, CTL22E, CMS-TS55+Basis5A (OF1010), MFT/3, MFS400/700, FS800-1080-1400-1900, Centrotec-SYS 09, DF 500 full set, some accessories
Frank Pellow
Offline
Location: Toronto, Ontario, Canada Member Since: Jan 2007
Toronto, Ontario, CANADA
« Reply #84 on: October 30, 2010, 01:39 PM » |
Have you heard from a reliable source that they will arrive here in 2011?
Cheers, Frank (Festool connoisseur)
RL
Offline
« Reply #85 on: October 30, 2010, 03:18 PM » |
Yes, when I was recently talking to Festool's customer service about what to bring back when I visit the UK shortly, I was told that the Carvex would be here next year, probably in the spring, but that the Vac Sys was a no-go for the foreseeable future. I can't remember what I was told about the centrotec 2010 set but it is going to be a permanent part of the line-up so should be here soon. Those were the three items I was interested in. None of this was confidential info and obviously everything could change but this was straight from the source in mid-September.
« Last Edit: October 30, 2010, 03:22 PM by Richard Leon »
I like green.
Frank Pellow
Offline
« Reply #86 on: October 30, 2010, 03:21 PM » |
Yes.
That's good.  Who is the reliable source?
Michael_MA
Offline
« Reply #87 on: October 30, 2010, 04:04 PM » |
You don't have to use the "auto" function. If doing fine work & you want it fast then just turn the dial up  Eh.. of course I have to use it. It's something my previous jigsaw didn't have. It's cool!  But it doesn't work as good as I hoped. Just as an additional info.. the Auto Setting on the Carvex is mainly to avoid kick back, when using the pendulum action. That means, once you set it on Auto, it not only reduces the speed until the workpiece edge has been properly detected.. it also holds off the pendulum action.. and starts it after the speed is finally ramped up. kind regards, Mike
Shane Holland
Festool USA Employee FOG Administrator
Offline
« Reply #88 on: October 30, 2010, 04:18 PM » |
Frank, yes, we expect to see the Carvex in North America in the first half of 2011. I can be trusted as a reliable source.
Henk
Offline
« Reply #89 on: November 21, 2010, 06:54 PM » |
I have a Carvex battery model,bought it 2 months ago. Its been back to the service department 3 times now. Its a b**h to work with,its cuts awfull,the flickering light disturbs me,the battery is drained quickly,sawblades burn,etc etc. I did,n buy any battery Festools for a long time,and I hoped they improved the battery when I bought the jigsaw. Big mistake. Really you need 2 batterys. The jigsaw is for sale now,because I dont trust it and hate working with it. Interested?  My other battery tools or from Panasonic,absoluty perfect. Good battery stamina,light weight,strong etc. I bought a jigsaw,(14,4 volts battery) from them,and it works fine. I must admit its a smaller and not very accurate,but you can do a decent cutting job with it. The Festool won,t.  For the rest I must say that this is the first Festool that dis-appoints me. All other Festools work fine.
« Last Edit: November 21, 2010, 07:06 PM by Henk »
