Pages: [1]   Go Down
  Print
Author Topic: TS-55 cut alignment problems  (Read 1218 times)
Fitzy44
Offline Offline
« on: May 28, 2012, 08:13 PM »
Hi guys
This is my first post, but I've been gathering all kinds of great information on the site.  I've got a problem....
Dropped my TS-55 off my MFT the other day onto the concrete floor (yes, already bought some floor mats).  It landed on the protruding splinter guard.  Broke the guard and the blade housing.  I ordered and replaced both, but I've noticed that the riving knife is misaligned.  It catches slightly as it begins into the kerf and it seems to drag through the entire cut.  I am assuming it was bent in the fall, and plan to replace it as well.
What I'm wondering about is this:  With every cut I make now, regardless of the board width or depth, the blade seems to gouge into the in feed side of the cut a mil or so, but just as the back of the blade is leaving the cut.  The rest of the cut appears fine.  It's as though the toe in on the blade is slightly splayed outward or something like that.  I'm wondering if a misaligned riving knife could cause this type of thing or whether I might have a larger issue.  The blade does not appear to be warped in any way.
I've looked at the supplemental guide by Rick Christopherson, but the symptoms he provides adjustments for don't seem to match my problem.  I'd love to get some feedback/suggestions about what might be wrong.  Thanks!
SRSemenza
Global Moderator
Offline Offline
« Reply #1 on: May 28, 2012, 11:59 PM »
Hi guys
Hi Fitzy44,
Welcome to the FOG!
I suggest you have Festool service deal with the problem.  Is the saw still under warranty?  Even if it isn't  call the service department, they are excellent. They will help you decide wether you need to send it in or not.  Even if not under warranty repair cost is generally quite reasonable.  The # is on the saw label as well as in my sig line  below.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Fitzy44
Offline Offline
« Reply #2 on: May 29, 2012, 08:15 PM »
Thanks Seth.  I'll be calling the service folks tomorrow.  Hate to depart with the saw, but best get it done while it's under warranty.
Pages: [1]   Go Up
  Print
Jump to:
