Author Topic: CT26 Bluetooth Remote  (Read 2375 times)
Offline cpw
« on: September 10, 2018, 08:37 PM »
I purchased a CT26 from my local dealer today.  It was a returned item, but they said it checked out in their VAC.  I installed it into mine; and went through the pairing steps of pressing the vac button for 3 seconds until the light "spun".  Then I pressed the man button on the remote.  It seemed to indicate success.  When I press the man button on the remote, the bluetooth module on the CT lights up; but the vac does not turn on.  Any suggestions before I too return it?
Offline Dick Mahany
Re: CT26 Bluetooth Remote
« Reply #1 on: September 10, 2018, 09:01 PM »
There are two pairing modes.........try holding the button down longer.  It will flash a different patttern (faster spinning?) and should work.  That happened to me until I read the instructions [embarassed]
« Last Edit: September 10, 2018, 09:03 PM by Dick Mahany »
Offline HarveyWildes
« Reply #2 on: September 10, 2018, 09:36 PM »
Did you set the vacuum to auto?
Offline cpw
« Reply #3 on: September 10, 2018, 09:41 PM »
I set the vac to auto.  I read the manual and reset both the vac and the remote.  Then I tried pairing the remote by holding the button for the 10 seconds until it blinked quickly.  I pushed the man button on the remote.  The pairing light went off.  When I pressed the man button on the remote, the CT just blinked.
Here is a video of the steps I took:
Offline Frank-Jan
« Reply #4 on: September 11, 2018, 02:01 AM »
Have you tried removing and re-seating the module? (I remember some one having problems with his auto switching accessory outlet which were fixed after re-installing)
Offline cpw
« Reply #5 on: October 08, 2018, 01:13 PM »
I ended up exchanging the module today; and the new one works perfectly.
Offline rst
« Reply #6 on: October 08, 2018, 06:26 PM »
I just installed mine in a CT36AC.  I also had problems, turned vac to auto, pressed module button, slow rotating blue...would not pair.  Looked at video again, tried again.  Started over several times, always slow rotation, finally pressed module button second time...fast rotation finally, pressed remote, finally paired.  I work with electronic automatic doors and am used to instructions not always making machine function as set out in manual.  Software instructions are still developed by aliens.
Offline Vec
« Reply #7 on: October 11, 2018, 09:49 PM »
Had a similar thing happen... would intermittently work.
Tried replacing the battery and it worked worse.
Took a piece of the cardboard that held the battery, folded it in two, and stuck it behind the battery to apply more pressure to the contacts... now it works 100%.
