Pages: [1]   Go Down
  Print
Author Topic: Cutting at 45 deg. with TS55 ( Solved by actually READING the manual !)  (Read 762 times)
morts10n
Offline Offline
« on: March 28, 2012, 01:18 PM »
I ripped a couple panels with the saw set to 45 ( angle pointer actually appears to be at about 46 when set to max, and points to zero when square)and my two panels met at approx 93 deg. I noticed this after cutting all the biscuit slots!  What is happening here?
« Last Edit: March 28, 2012, 05:20 PM by morts10n » Logged
Ken Nagrod
Restricted
Offline Offline
« Reply #1 on: March 28, 2012, 04:43 PM »
Check the saw with a good reference machinists 45* triangle and adjust the saw's bevel stop before continuing or guessing, would be the first thing I'd do.
SRSemenza
Global Moderator
Offline Offline
« Reply #2 on: March 28, 2012, 04:57 PM »
Yup, check it with a square. And if you lock the plunge (like for blade changing) it will be easier to check.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
morts10n
Offline Offline
« Reply #3 on: March 28, 2012, 05:19 PM »
Thanks guys. I saw the screws for the 90 deg. setting but not the 45 deg. setting. A lesson in reading the manuals!!!
Pages: [1]   Go Up
  Print
Jump to:
