Jim Andrada
Offline
« on: April 16, 2011, 03:09 AM » |
One of the spring loaded pins is stuck in the retracted position and won't pop out. Any suggestions for getting it to pop out as usual.
William Herrold
Offline
"failure is imminent"
« Reply #1 on: April 16, 2011, 04:45 AM » |
try a dust extractor with a narrow nozzle or a strong magnet? the base is aluminum, so that might work.
"I don't believe anything, but I have a lot of suspicions" R.A.W.
Eli
Offline
A Yankee in Kangaroo Court
« Reply #2 on: April 16, 2011, 06:56 AM » |
poke it from the back with a small allen wrench?
Do nothing, stay ahead.
Brice Burrell
Offline
Remodeling Contractor
« Reply #3 on: April 16, 2011, 08:11 AM » |
Yeah, that will work, check out Jerry Work's thread here.
Jim Andrada
Offline
« Reply #4 on: April 16, 2011, 08:48 PM » |
I couldn't see a hole on the back but I will look harder
I think my problem was also due to having to suddenly re-bore an already glued mortise that wasn't quite deep enouh
Eli
Offline
« Reply #5 on: April 17, 2011, 05:33 AM » |
yeah, glue or pitch, I've had that happen once or twice. Not a super common problem fortunately.
jonny round boy
Offline
« Reply #6 on: April 17, 2011, 05:53 AM » |
My domino has paddles, so I'm not 100% sure of the pin version, but doesn't the whole pin/spring assembly unscrew from the fence casting so you can clean it up?
Jim Andrada
Offline
« Reply #7 on: April 18, 2011, 09:43 PM » |
Well, I got it working. Had to pull the motor/cutter assembly off and remove the extractor port to get at it, but a small Allen wrench did indeed succeed - I also spritzed some WD040 on the pin and twisted it around a while and all seems well.
Thanks again
