Author Topic: Domino Mortise is too narrow  (Read 17089 times)
Offline Birdhunter
Re: Domino Mortise is too narrow
« Reply #60 on: August 04, 2017, 02:28 PM »
Any info on what part was replaced?
Birdhunter
Offline grbmds
« Reply #61 on: August 04, 2017, 03:57 PM »
The Dominos must fit very snugly. That is the design. Just because there are some 500's out there that might not be right, doesn't mean they all are. Having used the 500 for awhile, I appreciate the fact that the dominos fit into the slot tightly so that the alignment is always dead-on. If that means I need to scrape a ridge off the edges when humidity is higher, then it's worth it for the result. We shouldn't all suddenly feel our 500's are faulty just because the domino fits tightly in the hole. The subject of this post is an excessively tight fitting domino; one that you have difficulty even forcing into the slot.
Randy
Offline iamnothim
« Reply #62 on: August 04, 2017, 05:19 PM »
@grbmds
You are correct.  This was just a defective unit.   It works great now.
I'm in Southern California so I don't have moisture issues.
I think there are one or two members that have a similar problem.  I'd recommend sending the unit in for repair.  I'll dig up the receipt and post it.  Thanks to all for your support.
My reputation pre-deceases me.
Offline Birdhunter
« Reply #63 on: August 04, 2017, 06:32 PM »
I have both the 500 and the 700. I have to tap in the tenons with both units and with various sizes. I have to use pliers to remove the tenons.
Birdhunter
Offline DB10
« Reply #64 on: August 04, 2017, 07:59 PM »
That is a firm fit and that's the same as mine, It's how I like the machine to be.
Offline sac3848
« Reply #65 on: August 04, 2017, 08:57 PM »
use sandpaper on the narrow edges
Offline iamnothim
« Reply #66 on: August 21, 2017, 01:16 PM »
I am delighted with the repair.   The dominos are quite tight as to where you can insert them with your fingers with mild pain.  Pliers are required for extraction.
Here's the parts that were installed the second time.
Offline Birdhunter
« Reply #67 on: August 21, 2017, 01:59 PM »
Great outcome. Thanks for the update.
Birdhunter
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #68 on: August 21, 2017, 02:27 PM »
@iamnothim
I think that this illustrates that a cool, calm and almost inquisitive approach to a problem is far better than a pugilistic one. Well done for taking the sensible route and letting Festool handle the issue.
I am glad that everything is sorted out and that your lovely Domino is now in fine shape.
Offline Dick Mahany
« Reply #69 on: August 21, 2017, 09:51 PM »
Excellent outcome.  I'm surprised to see that 5 parts were replaced, but it gives me some needed confidence in Festool Service after reading a few other threads that had shaken my confidence.
My DF500 was an absolute game changer for me and enabled new ways to improve my methods (after 40 years ).  Thanks for posting the follow up and now go and have fun with a truly innovative tool.
Offline LDBecker
« Reply #70 on: August 31, 2017, 01:39 PM »
My DF 500 was making odd-sized mortises and was breaking bits - I had somehow damaged the mechanism that changes the width of the mortise - I guess you need to change it only when the tool is running. Festool fixed mine for free - two years out of warranty. Hard not to be impressed with that!
