Pages: [1]   Go Down
  Print
Author Topic: Kapex guide rails  (Read 2090 times)
rmy1299
Offline Offline
« on: May 19, 2012, 02:26 AM »
Does anyone know whether to use lithium grease or wd-40 on the kapex guide rails for smother action?
Kev
Online Online
« Reply #1 on: May 19, 2012, 03:08 AM »
Go with wax.
ccmviking
Offline Offline
WWW
« Reply #2 on: May 19, 2012, 09:27 AM »
a couple of drops of light machine or pnuematic oil on each rail, work it back and forth, then wipe away any excess.
Chris...
« Last Edit: May 19, 2012, 12:36 PM by ccmviking » Logged
RvB
Offline Offline
« Reply #3 on: May 19, 2012, 12:06 PM »
I just spray them with WD-40 and then wipe off the excess..
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 -  FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
Shane Holland
Festool USA Employee
FOG Administrator
Offline Offline
WWW
« Reply #4 on: May 19, 2012, 12:27 PM »
Welcome to the forum.
I would highly recommend that you contact our service department for a recommendation. Generally, a lightweight machine oil is recommended, but I would defer to our experts for a recommendation.
Shane Holland
Festool USA
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
rmy1299
Offline Offline
« Reply #5 on: May 19, 2012, 12:32 PM »
Thanks guys for the responses,and thank you Shane.I think I will confirm with festool just to be sure,because for $1400 I don't want to make a mistake.
ccmviking
Offline Offline
WWW
« Reply #6 on: May 19, 2012, 12:37 PM »
It was discussed in this thread along with Rick chiming in with David's support.  No need to call Festool on it... read this
Kapex Lubrication
Chris...
rmy1299
Offline Offline
« Reply #7 on: May 19, 2012, 03:30 PM »
What about using a teflon spray?
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #8 on: May 19, 2012, 08:19 PM »
As I mentioned in a previous posting, the bearings in the Kapex slides are recirculating ball linear slides. These are different from other slides used in some of the other Festool products. How you choose to lubricate these is less critical, but I would still refrain from using any type of lubricant that contains solvents. In my personal opinion, a grease is too thick, but a thin machine oil is too thin. Something between a medium to thin oil would be ideal.
I got distracted today before posting this, but I had previously pulled up a graphic of the type of bearing used in the slides. This is not an actual image of a Festool bearing, but is representative of the type being used. In it you can see how the ball bearings are exposed in one portion of their track where they contact the rail. In the portion where they recirculate back to the beginning they are contained within an enclosed race.
BlueRidgeWoodworksLLC
Offline Offline
WWW
« Reply #9 on: May 19, 2012, 09:22 PM »
I have used Renaissance wax in the past for my OF 1400 and domino slides and it's worked out really well.  My Kapex is about 2-3 years old now but I've never had to do anything but wipe the rails or vac them off.  I would think any kind of oil, even after it's wiped off would still attract dust, where as this wax dries thin and hard, fills in small imperfections and would seem to allow those bearings to glide really nice.
Sorek
Sorek Minery
WarnerConstCo.
Offline Offline
WWW
« Reply #10 on: May 19, 2012, 10:09 PM »
I just spit on them.
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #11 on: May 19, 2012, 11:04 PM »
Sorek
Even though I previously stated that what you use is not all that critical, I take that back. I would not recommend using a wax here.
Pages: [1]   Go Up
  Print
Jump to:
