Timtool
Retailer
Offline
« on: June 21, 2012, 03:14 PM » |
I have the centrotec installer set with the long yellow coated bits, and i had the perfect situation for them. Driving 5x80 spax screws with a TX20 head through a 10mm hole where any regular bit holder cannot go through. Those are relatively big screws, but the holes were predrilled and i was using the T15 with the driving mode engaged to stop at the right tension. All went well untill i very slightly slipped, and noticed how badly it damaged the bit, with the bit damaged it happened more and more and after 100 screws and 20 minutes of work this is how the bit looks, completely useless. On the left i added my regular festool TX20 bit which i have been using daily for over a year, and driven thousands and thousands of screws with it. it's worn, but still works perfectly.
« Last Edit: June 21, 2012, 03:18 PM by Timtool »
Brice Burrell
Offline
Remodeling Contractor
« Reply #1 on: June 21, 2012, 03:29 PM » |
I've never bought any of the long Festool bit because I heard from several people who's opinions I respect ,that are no good. So you aren't alone on this.
Steve R
Offline
« Reply #2 on: June 21, 2012, 04:03 PM » |
Wow, that is one worn bit. Glad to know about the long bits.
Cheers, Steve
Guy Ashley
Offline
« Reply #3 on: June 21, 2012, 04:16 PM » |
Yup! I have broken two of the long PZ2's, but thought it was just me, I bust things!!
DIPLOMACY:
Peter Parfitt
Magazine/Blog Author
Offline
« Reply #4 on: June 21, 2012, 04:39 PM » |
Hi Timtool and Guy
I get a sort of chill running down my spine when I discover any Festool failing or failure - it is almost like being reminded of one's own mortality.
If Festool rely on items like these bits and perhaps other non 'electric tool' items to be made for them by other manufacturers then they must ensure that the right quality control mechanisms are in place so that customers are not let down.
I hope that someone from Festool UK reads this and sends you a replacement, maybe with a couple of spares. I know that Shane would have fixed it for someone in NA by now! Is there anyone from Festool Belgium or Germany reading this?
« Last Edit: June 21, 2012, 04:41 PM by Stone Message »
Kapex 120, OF 2200, OF1400, TS55, TS55R, CMS-TS55R, PSC420, Domino 500, MFT3, Rotex 90, Rotex 150, CTL26, 1400 & 2700 Guide Rails and a lovely watch Wish List: C15, HL850, BS75, DF700, Second Extractor, new secretary
Mauri Motti
Offline
« Reply #5 on: June 21, 2012, 05:19 PM » |
I also have the Centrotec set (2011) and though I've used the long bits in a T12, I do think they are meant to be used with the hand crank thingy that comes in your set. (just my intuition, no expert here ) In the Centro set there is a bit extension holder too. You could use it with regular fest bits and reach your desired depth with it.
Mauri Motti
Offline
« Reply #6 on: June 21, 2012, 05:25 PM » |
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
Sorry, misread something here. I thought it concerned depth, not width
Greg Lock
Offline
« Reply #7 on: June 21, 2012, 05:32 PM » |
Hi Peter I use all sorts of driver bits and accept that at somepoint they will wear, round over or break, this i accept as a consumable cost when used. The tips are under huge force when used. The best i have used are the 50mm Makita £10.00 for a tub of 50 and rarely break, i just loose them instead!! Just because Festool does not mean it will last. I keep the Festool set for Furniture/ Cabinet use only. The big benefit of the green ones is the ability to swap and change. G.L
Shane Holland
Festool USA Employee FOG Administrator
Offline
« Reply #8 on: June 21, 2012, 06:18 PM » |
Having had a background in the screw business, just a reminder that the tolerances and quality of screws also play a factor in the fit of the bit. The photo shows that the bit cammed out, which can happen for a number of reasons. But regardless of the reason, camming will severely wear and even destroy the best of bits. I'm not trying to dispute your opinion of our bits, but there's more than just the bit that plays a factor in wear. Shane
« Last Edit: June 21, 2012, 06:21 PM by Shane Holland »
Peter Parfitt
Offline
« Reply #9 on: June 21, 2012, 11:56 PM » |
Hi Greg I used to buy bits, especially Pozidrives, in bulk but have now switched to Wera. They must be made of very special steel as they really do last a long time. Peter
optimistisch
Offline
« Reply #10 on: June 22, 2012, 01:45 AM » |
Hi guys, the Festool bits are made by WIHA. WIHA is at least on the quality level with Wera, I would rate them a litle bit above Wera. Ingo
ETS125EQ+, TS55EBQ+, OF2200EB & Metric Set, DF500Q Set, C12 Li 1,3+, PRECISIO CS 50 with an Sliding table, RO150FEQ+ MFS 700 & MFS-VP 1000 and 2 x FS1400/2 in a wooden case, a self designed installers kit for CentroTec tools a self designed work bench in an MFT Style with a lot on enhancements
Twitter: @optimistisch
Timtool
Retailer
Offline
« Reply #11 on: June 22, 2012, 01:50 AM » |
Having had a background in the screw business, just a reminder that the tolerances and quality of screws also play a factor in the fit of the bit. The photo shows that the bit cammed out, which can happen for a number of reasons. But regardless of the reason, camming will severely wear and even destroy the best of bits. I'm not trying to dispute your opinion of our bits, but there's more than just the bit that plays a factor in wear. Shane I know that camming them out can quickly destroy a bit, but this bit reacted to the camming like a cheap bit would by disintegrating instantly. I am however impressed by the quality of the small Festool bits, as the one left on the picture had driven thousands of screws and probably cammed out quite a few times. the thing is that then the bit would destroy the screw head, and not the opposite. I also have a TX15 bit, same age, that i used quite a few times by error on aTX20 screw resulting in camming out. And each time i expect the bit to be ruined, and yet i find it nearly intact and perfectly usable. I don't usually use spax screws, maybe the metal is harder. Thing is that at around €17 to replace the long bit, i probably will go looking elsewhere. Edit: Shane, could you maybe confirm or not that these long bits are intented to be used on a power driver, and not just the hand driver that sits next to it in the set? I get the feeling these are for special cases to get get you out of trouble, and certainly not for frequent use. Seeing the thinness and length of the shaft i suspect the metal needs to have different requirement in order not to snap, maybe it's less hard.
« Last Edit: June 22, 2012, 02:09 AM by Timtool »
Festoller
Offline
« Reply #12 on: June 22, 2012, 03:30 AM » |
Tim we've had similar experience with the golden short and long bits in direct comparison to the other version you have on your photo. It also doesn't matter if it's Torx, PZ or any other kind! If I remember right Festool now only offers the long version, the shorter one is available from Protool.
I don't think the golden Centrotec are intended to be used only by hand!
Anyway we've compared both bits (golden Centrotec to grey) on a deck (same number and conditions of screws, as well as the same T15) and came to the same conclusion! Although we got replacements from Festool the problem is still the same and in the end you just stop using them on many projects, they just wear out so fast!
It's quite sad since I really love the golden long and short Centrotec bits, they don't get stuck in the screw, they are easy to switch, and much easier to locate. I prefer the long ones for 95% of the work.
The question is why they can't be manufactured with the same steel than the small grey ones.
I hope there's a better version coming out soon, it seems silly with so many other inovative and durable products!
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
Greg Lock
Offline
« Reply #13 on: June 22, 2012, 07:26 AM » |
Peter, are you paid by Wera to promote after a review? G.L
Shane Holland
Offline
« Reply #14 on: June 22, 2012, 09:08 AM » |
They are for use in drills or the hand driver, either. Those bits existed long before the hand driver was introduced.
Deansocial
Offline
« Reply #15 on: June 22, 2012, 09:08 AM » |
Hi Timtool and Guy
Peter Parfitt
Offline
« Reply #16 on: June 22, 2012, 10:36 AM » |
I do not accept payment from anyone for the video review work that I do - it is all free. I earn a small amount from my magazine for articles of mine that get published. I am an independent reviewer who just happens to be a great fan of Festool, Wera, Cyclone Central and Osmo. I try to make sure that all of my reviews are positive - there have been things that I have refused to review. I did contact Wera UK and told them that I had already bought a number of their tools and that I was going to review them on a woodworking forum and in a woodworking magazine. I was trying to get some woodworking specific literature. The person that I spoke to said that Wera were not particularly interested in the woodworking market as they focus on electricians and plumbers. I made a tiny dig at them in the video for saying that. I expect to be visiting Wera HQ in Germany next year with an aim of making them aware of the woodworking community. Any other questions? Peter
ericbuggeln
Guest
« Reply #17 on: June 22, 2012, 10:37 AM » |
These bits are the same as the little three packs of small bits made out of the same material? I got some at ToolNut awhile back and have been using them exclusively with no wear. Not sure yet if they are worth $3.33 a piece but so far so good. I have had the installers set for some time and ran out of some stuff supplied with it, but had left the long bits for the "perfect" job. Would these be the same ones? Eric
Greg Lock
Offline
« Reply #18 on: June 22, 2012, 02:32 PM » |
Hi Peter Yes, another question - So you are not sponsored or supported by any company/business then, as some reviews are sliding towards other manufacturers products - oil, wera ? Do not get me wrong, free speech and all that. I ask as i like the video sections and prefer not to be sold 'on the sly' so to speak. G.L
Peter Parfitt
Offline
« Reply #19 on: June 22, 2012, 02:49 PM » |
Greg I do understand - it is a common prejudice especially when you see some of the workshops of the reviewers full of the lastest 'must have' kit. I have to remain independent otherwise manufacturers and suppliers would not approach me. I have a huge wish list of kit, especially Festool stuff and so if anyone would like to give me a C15 or a CMS Router insert then just give me a call! Back to reality...I hope to get one for Christmas and the other for my birthday unless I win the lottery. Peter
promark747
Offline
« Reply #20 on: June 22, 2012, 03:18 PM » |
For the cost of these things (I just paid $19 each for the P1, P2, and P3 two-packs), they should be top quality.
Greg Lock
Offline
« Reply #21 on: June 22, 2012, 03:19 PM » |
Hi So from that, i take it you are 100% not on a promo drive for certain manufacturers, including Festool. A fine line exists between providing balanced information for others in a community of like minded souls and pushing/promoting from a supplier (s) who provides free kit and gains favourable representation in a noted forum such as FOG. I would guess those who contribute on a regular basis are aware of this anyway. I have used the forum (not posting)over a couple of years to gain balanced information which is the great strength of this site and personally i hope it continues without direct/indirect advertising. I have been a trade 'woody' for many years and am Festool all the way through. If a product is given for free it is difficult to be objective as the basis of being given it is for a positive result. If a product is directly purchased and reviewed then the end result is possibly more equal as loyalty is not present. G.L
Steve R
Offline
« Reply #22 on: June 22, 2012, 03:23 PM » |
Interesting topic twist of how reviews are interpreted by viewers.  waiting for next volley. Cheers, Steve
Peter Parfitt
Offline
« Reply #23 on: June 22, 2012, 03:55 PM » |
Greg
This is becoming tedious and boring the pants off the regular guys...
I am an absolute Festool fan and have been since I sold up all of my heavy machinery and bought the brand. I have answered your original question. I have owned Wera products for years and have bought every single one and I pay all of my taxes - but the that surely won't be your next question - will it? I think that we should get back to enjoying the FOG now rather than putting on a side show.
Shane...SHANE!!
luke1984
Offline
my festool
« Reply #24 on: June 22, 2012, 04:06 PM » |
Hi people the long gold bits are rubbish I've snapped / broke about 7 so I've stopped buying them .spoke to my dealer about exchanging them and he said they wouldn't because they are classed as a consumable. All the bits I used were pz2 so I ground 2 of them into slotted bits work quite well. Luke
ts-55, ehl 65e, ctl mini, t18+3 set, carvex, kapex 120 with ug stand and both wings, mft3, of1400, c15,cms with ts-55 module lr32 and lots of systainers,sortainers and accessories.
Kev
Online
« Reply #25 on: June 22, 2012, 04:08 PM » |
I'd like to jump in and argue that point ... If something is free it is "given" and it comes down to the integrity of the reviewer. My area of concern has always been "reviews" in publications that accept paid advertising ... if you've ever seen how that side of the industry works - that's where you should level your integrity concerns. Back on your earlier point and as far as Peter is concerned - he is a true gentleman and a person I have come to highly respect from my time here on the FOG - though I certainly don't share his taste in music  Kev
Shane Holland
Offline
« Reply #26 on: June 22, 2012, 04:27 PM » |
Guys, let's stay on topic and not get into personal attacks. I think the question of Peter's acquisition of the products he reviews has been answered. I would expect any member of the forum to have the courtesy of disclosing if they were given a product for review. I know that any time I send a Festool product to someone I ask that they include that disclosure in their review, whether it be written or video. Any additional posts that seem to be personal attacks will be removed without warning. Thank you. Now... back to bashing the driver bits.
« Last Edit: June 22, 2012, 04:43 PM by Shane Holland »
Peter Parfitt
Offline
« Reply #27 on: June 22, 2012, 04:58 PM » |
Thanks Shane.
I think I might have an early night!
Take care.
Frank-Jan
Offline
« Reply #28 on: June 22, 2012, 05:37 PM » |
Just after I got my protool drill (the pdc 18-4, which was my first drill with the centrotec system) I was looking into which centrotec systainer I would get for my drill, the protool version, with the trays that would fit the (then new) systainer attic-lid. or the soon to be introduced festool centrotec 2008 set, which came with an adapter to use the centrotec stuff with a non-centrotec drill aswell. (needless to say I ended up getting both sets  ) When I asked about the protool set only having the 55 mm centrotec bits instead of the longer ones, which were in the festool version, the protool rep said that was because the longer bits weren't suited for the high torque of the protool drill. Sofar I have broken three of the longer centrotec bits, they were all of the flat kind, trying to remove painted over old hinge screws. Since I was warned about the long bits being less strong I'm probably a bit more carefull using them, but I do use them regularly, often in conjunction with the long bitholder. But I wouldn't call them rubbish, in some cases they're very handy. (For the regular short bits I prefer the wera diamant bits, I used quite a lot of different ones: witte, wekador, wiha, kwb,festool, dewalt,... but I settled on the wera diamant (some of the kwb bits were actually rebranded wera diamant bits))
waynelang2001
Offline
« Reply #29 on: June 22, 2012, 05:48 PM » |
The first time i got a festool cordless drill I decided to buy some of the festool pozi bits. I went through 4 of them in one week. I then bought some wera pozi bits and I only broke 1 every few months. I wont buy festool bits again. The centrotec drill bits though are great though.
