Pages: 1 [2]  All   Go Down
  Print
Author Topic: Long centrotec bits rubbish?  (Read 5321 times)
Greg Lock
Offline Offline
« Reply #30 on: June 22, 2012, 06:14 PM »
I was not being personal just opening a debate which i thought was a reasonable thing to do. Crying
G.L (also having an early night due to an early start as i am oiling a 4m oak hall table)
SRSemenza
Global Moderator
Offline Offline
« Reply #31 on: June 23, 2012, 12:49 AM »
Sofar I have broken three of the longer centrotec bits, they were all of the flat kind, trying to remove painted over old hinge screws.
Try this tip  removing painted screws
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
b_m_hart
Offline Offline
WWW
« Reply #32 on: June 23, 2012, 03:28 AM »
I had the #2 phillips head version break on me the very first time I used it.  The screws were not painted over, however they were fairly firmly in place.  I lost grip, and as soon as I could release the trigger, I stopped and looked at the bit.  Sure enough, it was jacked.  I'll grab a pic of it later on.  I was on the fence about buying the centrotec kit, but figured I'd go ahead and grab it since I got a new drill, but after having that happen, I'm not planning on ever buying another festool centrotec bit.
TS 55 EQ, ETS 150/5, RO 150 FEQ, OF 1010 EQ, DF 500 Q, C12, CT Midi, OF 2200 EB, MFT/3s, DTS 400 EQ, parallel guides, and seemingly growing by the day...
Timtool
Retailer
Online Online
WWW
« Reply #33 on: June 23, 2012, 06:56 AM »
A member pointed out to me that Spax screws have their own special heads, and indeed on the box there is a white circle drawn inside the torx head, it's not security torx and i cannot find it anywhere else on the internet.
Apparently you are supposed to buy the spax heads because they fit a little better. the box is empty so i can't check how it looks, but i probably won't buy spax again and stick with reisser.
Peter Parfitt
Magazine/Blog Author
Offline Offline
« Reply #34 on: June 23, 2012, 07:02 AM »
Hi Timtool
I may be wrong but I think that there might be a 3td Torx variant, normal, security plus a new one - I might be thinking of something else.
Kapex 120, OF 2200, OF1400, TS55, TS55R, CMS-TS55R, PSC420, Domino 500, MFT3, Rotex 90, Rotex 150, CTL26, 1400 & 2700 Guide Rails and a lovely watch
Wish List: C15, HL850, BS75, DF700, Second Extractor, new secretary
Vindingo
Offline Offline
« Reply #35 on: June 23, 2012, 07:13 AM »
The Spax torx head is the opposite of a security torx.  There is a round nib on the end of the Spax bit which fits into a circle recess inside of the star shape of the torx.
I was not happy with how my Wera or Festool torx bits fit in the head of Spax screws, but the bit which Spax provided was definitely superior.    I have never had a problem with GRK torx screws and Wear or Festool bits though.
GRK T15 size fit the Wera and Festool bits better than Spax T15 IMO.
Frank-Jan
Offline Offline
« Reply #36 on: June 23, 2012, 07:45 AM »
I mistakenly bought a spax bitset once thinking it were regular torx, on regular torxscrews the bits don't work too well, because the little round end prevents them to seat at the bottom of the screwhead, thus are more likely to strip the screwhead.
I mostly use hecofix or spax screws, but mainly with pozidrive heads, but not so long ago we got a few boxes of the longer reisser screws from our lumberyard, and we like them a lot, and they were cheaper too.
At least you know now what caused your bit to wear prematurely, the combination of the softer steel and the spax screws that only use the very tip of a regular torx bit.
/edit: removed double quote
« Last Edit: June 23, 2012, 10:04 AM by Frank-Jan » Logged
neeleman
Offline Offline
« Reply #37 on: June 23, 2012, 09:49 AM »
Recently I bought some new screws named MaxxFast (http://www.maxxfast.com).
The also use the Torx head with the little knob and it's called TTAP.
I also think other manufactures use this kind of Torx today.
The new type of screws are also pretty good to use.
Precisio CS50 EB-Set, Kapex KS120-UG Set, TS55 R EBQ, Carvex PS420 EQ, BS75 E, RAS115.04 E, Rotex RO90 DX, Rotex RO150 FEQ, DTS400 EQ, RS400 EQ, RTS400 EQ, RS300 EQ, Duplex LS130 EQ, Deltex DX93 E, ETS150/5 EQ, Domino DF500 Q, OF1010 EBQ, OF1400 EBQ, OFK500 Q, MFK700 EQ, C12-Li, T15+3, TI15 Impact, T18+3, CTL26 E, CTL22 E SG, CTL Midi, EHL65 E, D27-AS Plug-it, D36 UNI-RS, FS800, FS1400/2, Gecko Dosh, Toolie, CE-SYS-2010, RB-SYS CART, Syslite KAL, LEV1400, Protool PDC 18-4, Protool FLC UNI.
green fever
Online Online
« Reply #38 on: July 08, 2012, 06:07 AM »
hi peter , never mind about winning the lottery you have just found the cure for insomnia, [ just kidding ] the bit issue will carry on no doubt but in my own experience i have found wera to be a very good choice although not without faults though , last year whilst replacing a garage roof i was using an impact drill with the wera bits all new with the appropriate screws, first three bits sheered off and after a quick call to the supplier i was put in contact with a wera rep who was very concerned about the bits breaking , i was then asked to send the offending bits and the holder back to wera u.k. and i was told the offending bits would be sent back to germany for testing, a few days later i received a whole set of wera impact bits and the holders x 2 . very happy with them so far, now wera have just brought out another version of the bits and holders impactor i believe, any how i am just putting the message out there that the good tool companys such as festool etc will always be looking to improve on their products for the good of all of us the end users, love the videos buy the way , if you would care to pm me i shall be more than happy to send you one of the sets i received  the least i can do after all the information you put out there for us.
jmbfestool
Online Online
« Reply #39 on: July 08, 2012, 07:16 AM »
Not for UK  Sad wanted to try them out.
Oh well
Deansocial
Offline Offline
« Reply #40 on: July 08, 2012, 08:03 AM »
Those maxxfast screws do look tidy, i want some decent priced screws in the uk that are good other than spax or reisser. The ultimate screws have changed and are rubbish now
jmbfestool
Online Online
« Reply #41 on: July 08, 2012, 08:57 AM »
I use timberfix  they look IDENTICAL to the Mazzfast ones above apart from they dont have the TTAP  and the ones I get are PZ2 heads but you can get them in torx also.   You get a bit in every box and they are cheap compared to spax, ultimates.    AND I think for some applications are actually better than the spax and ultimates.
JMB
Deansocial
Offline Offline
« Reply #42 on: July 08, 2012, 09:53 AM »
Come to think of it the fruldser vbu screws that warren sells are the same
Kev
Offline Offline
« Reply #43 on: July 08, 2012, 09:55 AM »
I wish we had a better range of this stuff down under. I'm still putting a thread on nails and carving slots on the heads!
Deansocial
Offline Offline
« Reply #44 on: July 08, 2012, 12:06 PM »
You only need the slot if you need to take it out you daft aussie Tongue Out
Pages: 1 [2]  All   Go Up
  Print
Jump to:
