Pages: [1] 2  All   Go Down
  Print
Author Topic: PS400 Carvex problem  (Read 5771 times)
lee1984
Offline Offline
« on: April 05, 2012, 12:38 PM »
Hi all new to festool and this forum, just bought a ps400 carvex jigsaw from an ebay auction, tried it out on 9mm mdf and the blade wanders all over the place tried it on 40mm maple and the same again im using festool blades, is there anyway of returning it to festool as its been bought in an auction and i dont have the warranty, also what does the level on the left side labeled 0-3 do?
woodguy7
Offline Offline
« Reply #1 on: April 05, 2012, 12:47 PM »
Lee, first of all welcome.
This is a very common problem.  It's funny you should post this just now as I called TTS about 1 hour ago to arrange collection of mine for the exact same problem.  This will be the 3rd time it has been back to them.  I told them I was reluctant to give it to them again but they said if it is the same problem for the 3rd time they will give me a new jigsaw.  We will see.  It appears it is the early models that have this problem.  Phone TTS & they will tell you if it is still in warranty.
It is a well documented problem & don't let them tell you otherwise.
Rant over, this is a bit of a sore point with me  Mad
Woodguy.
Shirt size medium
lee1984
Offline Offline
« Reply #2 on: April 05, 2012, 01:03 PM »
cheers for that, its mental that it costs all that money and wanders around like that after all the videos ive watched on youtube of perfect 90 degree cuts with it, and its worse than my old makita that cost me £50
Alan m
Offline Offline
« Reply #3 on: April 05, 2012, 06:17 PM »
welcome . there is a reason why the seller sold it . unfortunitly your laboured with it.  the warrenty should stand. calle tts and find out what they will do to  fix it. if not sell it on.
maybe ship it to the us . they would love it
now
wish list
lee1984
Offline Offline
« Reply #4 on: April 19, 2012, 08:00 AM »
well sent it to TTS and they fixed it had it going a good half hour of random cuts and it seems to do as its supposed to, working fine
woodguy7
Offline Offline
« Reply #5 on: April 19, 2012, 09:14 AM »
Lee, try to trim a slither off the edge of a sheet of 18mm ply or chipboard.  That's when mine is at its worst.  It's not too bad when the whole blade is in material but out on the edge it is unusable.
Cheers.
Shirt size medium
green fever
Offline Offline
« Reply #6 on: May 27, 2012, 12:36 PM »
hi to one and all,  my first post so here goes i had a problem with my 400 where it was burning the rear of the blades just below the bayonet area and around 25mm/ 1inch down this was also wearing a small section out of the blades, i contacted festool UK and explained the problems , no problem as its only 18months old so under warranty , festool arranged for a courier to collect it from me i wrapped up the saw and enclosed one of the damaged blades , festool not only fixed it but also sent me out a pack Of twenty new blades now that's why i buy festool, parts they changed were gear cover and roller retainer, i just wondered if as you said some early ones had a few problems , cant fault the service very fast indeed.
woodguy7
Offline Offline
« Reply #7 on: May 28, 2012, 04:14 AM »
Is it totally faultless now ?  Mine had those parts replaced twice & it's still as bad as ever ?
Shirt size medium
jonathan-m
Online Online
« Reply #8 on: May 28, 2012, 11:10 AM »
The Carvex... Bite your tongue  censored
Green: MFT/3, MFT/3-QT, OF-1400, MFS-400, MFS-700, MFS-FS, RO-90, SYS-ROLL, VAC-SYS SET SE1, VAC SYS AD MFT/3
Orange: VCP 260 LE AC
Red: MT55cc, P1cc, DD40P
Timtool
Retailer
Offline Offline
WWW
« Reply #9 on: May 28, 2012, 11:44 AM »
I bought mine a couple weeks ago with cramps in my belly because of all the bad things you hear about it, but i must say it is the best jigsaw i have ever used.
Initially it is awkward because it is so light and slim and when cutting thick hard stock it required more pressure to be stable. But once you get over that it is great.
I sold my Bosch GST135 for it, it was good, but the base was crooked from new and it could simply not make square cuts. had allot of weight and guts though but totally ineffective DC.
the automatic cut mode of the carvex does seem to live a life on it's own, its' not very predictable so far. but it works.
Davej
Offline Offline
« Reply #10 on: May 28, 2012, 12:32 PM »
i've had mine for a few months and as Timtool says the lightness takes a bit of getting used to ( i had a makita but got fed up of wobbly blade syndrome in thick worktops ) my carvex is excellent at taking thin ,straight slices off worktop but you do need to use the fsg blades as they are a lot stiffer , i also have the base for the guiderail but you have to push it into the rail or it can wobble as there is a bit of slack and as the base is just moulded plastic you cant adjust anything .
I dont mind growing old but i refuse to grow up
woodguy7
Offline Offline
« Reply #11 on: May 28, 2012, 01:36 PM »
Is there not a screw in the side of the plastic base to take op the slack ?
Shirt size medium
Davej
Offline Offline
« Reply #12 on: May 28, 2012, 03:40 PM »
No absolutely nothing , i reckon the slack is about .5 mm which doesnt sound much but try running a ts with that much slack and you will see what i mean . im thinking of gluing a sliver of laminate in the rebate to keep it straight  Huh?
Bobwessex
Offline Offline
« Reply #13 on: May 31, 2012, 06:44 PM »
Hi all, am new to the FOG. I received my carvex PS400 yesterday and used it in anger today laying oak flooring. I had been looking forward to using it but I must say at the end of the day I'm, at the moment, unimpressed. I own a few festool tools and absolutely love them but this carvex might be the first festool I try and send back.
The carvex was to replace my DeWalt XRP jigsaw. Admittedly I've gone for the different grip with the carvex over the DeWalt and am finding it a bit awkward to reach the on/off switch.  What does surprise me though is I'm finding the dust collection is worse (connected to CT midi) than the DeWalt. I appreciate your never going to get good dust collection with a jigsaw but I just assumed the festool wood be better in that respect. I have found the blade can wonder around on scribe cuts too, but that might be me getting used to the saw.
It's such a shame because the jigsaw feels (as all festools) so well engineered and I really want to love it, but after 1days use Im feeling it's not worth twice the price of my old jigsaw, and I have to buy an angle base separately...
Allan1888
Offline Offline
« Reply #14 on: February 15, 2013, 12:49 PM »
Sorry to bring up an old topic, has anyone had the issues with the ps400 carvex resolved by sending it away for repair, I only ask as mine is currently away for a second time to TTS. The first time they replaced the electronics which solved one issue but the jigsaw still won't cut properly and they have said they can't find an issue with it. The blade still wanders and doesn't cut plumb. It's being sent to the local rep to bring it back to me and run through some things with me.
woodguy7
Offline Offline
« Reply #15 on: February 15, 2013, 02:05 PM »
Mine was back at least 3 times & never fixed.  Complain to TTS, you will get a free upgrade to the 420.  That's what I got.  Much better.
Welcome by the way.
Good to have another "Jock" as some here would say  Big Grin
Shirt size medium
Allan1888
Offline Offline
« Reply #16 on: February 15, 2013, 02:31 PM »
Thanks for the welcome  Big Grin. Hopefully the rep see's sense when he brings my machine back to me as he knew all about the issues with the carvex but I have a feeling it's not going to end well
Allan1888
Offline Offline
« Reply #17 on: March 20, 2013, 09:11 PM »
Quick update on this. its still not resolved festool uk are hopeless and my local rep doesnt seem to be much better will try sending it to them for a third tiime and hopefully a miracle will happen and they might actually solve the issue with the machine.
woodguy7
Offline Offline
« Reply #18 on: March 21, 2013, 02:55 PM »
Tel TTS that if they don't change it to the 420 then you are going to deal direct with Germany.  You will get a replacement !
Shirt size medium
Allan1888
Offline Offline
« Reply #19 on: March 21, 2013, 03:03 PM »
I have already told them that. They have told me that Germany will just pass it onto them to deal with it. Will contact Germany myself I think and see what they say
woodguy7
Offline Offline
« Reply #20 on: March 21, 2013, 03:07 PM »
I can't understand that !  I kicked up one heck of a stink & they changed mine & loads of other people's.  I think I might have contact details for the head bummer at Festool Germany.  If I find then you could vent your anger to him.
Shirt size medium
Festoolfootstool
Online Online
The trouble with Bob is its all about Bob
« Reply #21 on: March 21, 2013, 03:13 PM »
I have to say I do not understand why tts UK have not replaced your jigsaw virtually everyone is aware that the 400 is not fit for purpose
and all they are doing is alienating customers with their tardiness
SHAME ON THEM..
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Allan1888
Offline Offline
« Reply #22 on: March 21, 2013, 03:14 PM »
That would be good. They have already admitted to me that there was an issue with the psc400 that's why the new model was brought out so soon even the rep admitted it too but The guys at the repair centre say they can't find an issue with it. So they shipped it back to Alloa tool hire as that is closer to the local rep who then delivered it to kelvin power tools for me to collect as he was to busy to get it to me direct. Somewhere along the journey the insert inside the systainer has been broken into several parts.
What the woman at tts said to me was people could be just trying it on to get the newer model.
Festoolfootstool
Online Online
« Reply #23 on: March 21, 2013, 03:26 PM »
I WOULD GUESS THAT THERE IS SOME TRUTH IN THAT STATEMENT, PEOPLE WILL WANT THE 420 AS THE 400 IS OF NO USE AS A JIGSAW WHAT DO THEY EXPECT?
Alan m
Offline Offline
« Reply #24 on: March 21, 2013, 07:40 PM »
at statment makes no sence to me.
people went out and bought the new model  . it is crap and was replaced with a better version. they are not looking for an upgrade. they are looking for what they paid money from.
tell them it still doesnt work and send it back again. tell them if the same saw comes back again you will want your money back
now
wish list
Timtool
Retailer
Offline Offline
WWW
« Reply #25 on: March 22, 2013, 03:27 AM »
Festool employees told me a couple weeks ago there was no problem with the 400 itself, the problem was that the saw was so complex to use that you would have needed to train users. That it could work perfectly but only with the right blade.
Now i understand why when i bought mine it came with a box of all different blades, i can say i tried them all when i had a problem and it didn't solve it.
I mailed them once about it, and they told me to go and exchange it at my local dealer for an 420 6 months after purchase!
I lol'ed when i re read my comment about the 400 being the best i ever used, jigsaws are versatile tools and in a few weeks of use you can't encounter every situation with it.
After months of use you encounter many situations and thats' where the problems show up.
« Last Edit: March 22, 2013, 03:31 AM by Timtool » Logged
green fever
Offline Offline
« Reply #26 on: March 23, 2013, 07:01 PM »
as woodguy7 stated they will replace it , that said i had problems with an early 400 and that was fixed in the end and i had posted how well it worked in all types of cuts , like woodguy i had the 400 replaced but i must say they are not all duds there must still be a load out there that are doing the job well, i would go back to the rep and ask him to put yours next to a new 420 and test them side by side then point out the difference get him to call tts with the results in front of you , as for him being busy try to get him to come to you i have had festool come out to me on site in the past to test a tool and yes that tool was replaced, i don't see why i should receive better treatment down south after all its the same company with the same goal customer satisfaction surely, i hope it gets sorted, post again with an update.
Allan1888
Offline Offline
« Reply #27 on: March 23, 2013, 08:43 PM »
The rep has not got back in contact nor has he returned any of my calls. I have left him several voicemail messages asking him to contact me to arrange a meeting so that he can visit me on site and have a look at how my jigsaw cuts as he and Festool uk promised. I'm happy with all my Festool products except my carvex and i only use Festool blades in my ts55 and my carvex yet no matter what blade the carvex has it will not cut plumb.
Kev
Offline Offline
« Reply #28 on: March 23, 2013, 09:01 PM »
I'm hoping my 400 is "a good one" then. I haven't experienced the sorts of problems people have reported - but it hasn't had a lot of use either. I've recently added a 420 cordless to the stable, but I haven't studied the differences.
If there are setup issues with the 400, I would have thought some comprehensive setup videos would have found their way onto the web!
Allan1888
Offline Offline
« Reply #29 on: March 26, 2013, 09:05 AM »
Been on to TTS again today was told that my local rep has been on holiday the past 2 weeks and now he has joined the tour currently going round the UK. so i will have to wait until he is free to visit me. i have been told they will call him and try and get him to call me today or tomorrow. Really getting fed up with TTS now its clear they don't really care about customers in the UK Undecided. They are probably sitting reading this now anyways  Blink
Pages: [1] 2  All   Go Up
  Print
Jump to:
